Old 04-10-2004, 11:39 AM   #1
attitude
Member#: 52043
04 sti
Default wiring up the tein edfc
ok just wired it up to the clock....so that you dont have to chase down the wires like i did
Blue on the clock - constant power supply (yellow on edfc)
White on the clock - Illumination power supply (green on edfc)
Yellow on the clock - Accessory power supply (red on edfc)
Black on the clock - ground (not used on edfc)
attitude is offline   Reply With Quote
Old 04-11-2004, 02:54 PM   #2
i eat meat
Member#: 13755
give G-force a PM. He's had luck in the past with this install. Mattjk may also be of help.
i eat meat is offline   Reply With Quote
Old 04-12-2004, 01:08 PM   #3
AllSeven
Member#: 32798
i'm doing mine this week so after i'll let you know if you pm me
AllSeven is offline   Reply With Quote
Old 04-13-2004, 05:07 PM   #4
StarDogChampion
Member#: 10276
2001 Impreza RS
2002 WRX, 2012 535i
StarDogChampion is offline   Reply With Quote
Old 04-14-2004, 03:46 AM   #5
2000LegacySti
Member#: 47005
I installed mine relatively quickly, there's not much too it...
What sucks is the P-1 P-2 and P-3 buttons do not hold their programming when you power the unit off. You have to set them each time you get in the car...
2000LegacySti is offline   Reply With Quote
Old 04-17-2004, 12:45 AM   #6
StarDogChampion
Member#: 10276
2001 Impreza RS
2002 WRX, 2012 535i
why not just leave the power on, mine is wired into the accessory (clock) harness and holds the memory fine, i only lose the settings when i disconnect the battery. The unit turns off with the key out, but keeps the memory just like the clock.
Old 04-17-2004, 01:41 AM   #7
G-force
Member#: 14104
UBER ILikeItLongAndH
ardDeepandSmoothEverSoCoo
maybe that's why he installed his relatively quickly?
should be 4 wires - ground, switched power, constant power and illumination - all found on the factory clock wiring. Looks like you forgot to hookup the yellow wire to constant power.
http://www.tein.com/ti/inst/edfcu.pdf
G-force is offline   Reply With Quote
Old 04-23-2004, 11:24 AM   #8
attitude
Member#: 52043
04 sti
Who has sexed up the real GTF? DrDRum Off-Topic 4 08-19-2013 07:39 PM
Who has run up the most miles? AWDPilot General Community 616 07-27-2011 02:23 PM
Who has made up their minds? bunot Political Playground 36 08-26-2004 11:41 AM
who has custom up/down pipes? Impreza25RS Normally Aspirated with bolt-on Forced Induction Powertrain 11 02-18-2003 05:27 PM
who has best prices on TEIN? Eric SS General Forum Archive 4 10-12-2000 03:19 PM
