Welcome to the North American Subaru Impreza Owners Club Monday January 26, 2015
Old 04-10-2004, 02:08 PM   #1
AntonioS
Member#: 23233
2000 2.5RS-T
white
Default car won't rev more than 4000rpm
I took my turbo out to fix a leak and now my speedometer doesn't work and my car won't rev more than 4000rpm. I check al the plugs on the harness and they were connected I have to check the speed sensor on the tranny that maybe it disconnected.
AntonioS is offline   Reply With Quote
Old 04-10-2004, 02:56 PM   #2
Pi7467mp
Member#: 19124
2009 Nissan GTR
RED Premium
yes that is exactly what it is..
Pi7467mp is offline   Reply With Quote
Old 04-10-2004, 08:53 PM   #3
marcus12
Member#: 45613
2005 Legacy GT Ltd.
Satin White Pearl
Pi7467mp any luck with your problem? I'm having same issue
//marcus
marcus12 is offline   Reply With Quote
Old 04-11-2004, 02:33 PM   #4
Pi7467mp
Member#: 19124
2009 Nissan GTR
RED Premium
NOt yet.. I am going to take off the cat section of my exhaust this week sometime, and put on a test pipe to see if there is any restriction in the cat.. I know I will have a CEL P0420, but at least this way I can see if it still has the hesitation or not.. Another possibility would/could be the primary O2 sensor.. I usually replace mine every 6 months due to them fouling out (still in desperate need of a tune) I have a spare sitting around so I might see if this works too.. either way I will keep you posted.
Old 04-11-2004, 08:16 PM   #5
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
ok so have you checked the voltage coming through the lines when you are driving?...should be 5V I believe...
Old 04-11-2004, 09:13 PM   #6
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
if you are talking about the vehicle speed sensor, just remember that the signal is in AC so you will need a multimeter that reads AC and set it accordingly.
no-coast-punk is offline   Reply With Quote
stg 4 won't boost more than 14 spoolinred UTEC 10 01-14-2008 10:25 PM
HELP!! WRX won't make more than 8 psi. BobbyStylz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 01-09-2007 11:41 AM
help~ car won't rev culmination Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 09-05-2005 03:14 PM
utec problem car wont rev over 3500-4000rpm mastershakewrx Engine Management & Tuning 10 03-05-2005 03:41 PM
Help My STi won't do more than 150 mph txjunglist Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 60 12-12-2004 01:10 PM
