Old 04-10-2004, 03:16 PM   #1
Kripski
Member#: 17853
2005 Legacy GT
Exclamation Tuners! 02 Rst Need Serious Help Please!!!
I installed the Ludespeed Stage III on my 2002 RS. The Link Plus that came with the kit has fried my coil for some reason. I got a new one and every time I go to start the car the coil gets hot again. Eventually it will fry again.
Is there a difference between the Link Plus 2001 and 2002 plug/play harness? That would explain the coil burnout. If so I was sent the wrong harness. By the way I'm also using a J&S safeguard.
What engine management systems are people using on their 2002 RST's?
I was looking at selling the Link Plus because it isn't user friendly and getting the Super AFC II along with the VC1 by Splitsecond (voltage sensor). I don't want CEL. And with 6.6 psi I need good engine management for a daily driver. Tuners only PLEASE HELP!!
Thankx,
Kripski
Kripski is offline   Reply With Quote
Old 04-10-2004, 04:54 PM   #2
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
If you don't know how to tune the Link, find some one who can or learn how. The SAFC will not get you nearly as reliable as the Link can. The Greddy e-manage would be much better than an SAFC, but still not as good as the Link. Seriously, take it to get it professionally dyno tuned if you don't know how to use it, that's the best option.
lotusTT is offline   Reply With Quote
Old 04-10-2004, 08:40 PM   #3
Kripski
Member#: 17853
2005 Legacy GT
If I went with the SAFC what exactly would I be missing out on? What are the major differences between the two set-ups?
Old 04-10-2004, 10:22 PM   #4
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
Everything. The SAFC does fuel only. And only lets you do it based on RPM and throttle position. It has no input to adjust fuel in relation to boost. Or any sort of timing control. Or the ability to add more fuel when you are at the limit of the stock MAP sensor (3 psi). Its really not a good solution. The Link is a full standalone ECU that lets you control any parameter of the engine management that you want. Its the safest way to have an RS-T, assuming you get it professionally tuned.
Old 04-12-2004, 10:26 AM   #5
Kripski
Member#: 17853
2005 Legacy GT
Do you know if there is a difference between the 2001 RS and 2002 RS in terms of ECU wiring?
Old 04-12-2004, 10:47 AM   #6
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
call link usa, ask for terreck, he helped me out and described the different functions of the controller boards, though i dont really remember it...wish i could help
alex
Old 04-12-2004, 11:08 AM   #7
Kripski
Member#: 17853
2005 Legacy GT
I appreciate the help guys. Does anyone know where to get a Link+ fuel map for a Ludespeed Stage 3 set-up? WRXhackers doesn't have one.
Old 04-13-2004, 04:29 PM   #8
Delicious Tuning
Member#: 1990
Default Maps For Free
Check out our site under the downloads area later today. I will have some Link Plus Maps up there that were in my car from years ago. Free maps...
STi Injectors
440cc Injectors
Different Boost Levels
Different Octane Maps
Late,
Bill Knose
I-Speed USA
Delicious Tuning is offline   Reply With Quote
serious help please Greddysaur Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 16 04-18-2008 03:30 PM
Need serious help please thrasher679 Transmission (AT/MT) & Driveline 7 01-22-2008 12:59 AM
Need serious help 9 Service & Maintenance 3 09-06-2003 01:41 PM
Need serious help Pochebum Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-06-2002 11:02 AM
Need serious help fast with brake pad/rotor issue. Jasno999 Tri-State Area Forum 13 05-01-2002 08:04 AM
