Old 04-10-2004, 02:39 PM   #1
FC3S1
Member#: 58922
Default NOS tubo spooling system
Has anyone else heard about these turbo spooling systems that use a small shot at low RPM to spool up the turbo faster? Are they actually effective in cars with noticable turbo lag or is it just a load of BS. Normally I wouldn't use a fogger to save my life but in this limited role I might give it a try, say on a Baja Turbo. Thanks
FC3S1 is offline   Reply With Quote
Old 04-10-2004, 02:40 PM   #2
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
RS-t's don't have lag
Old 04-10-2004, 02:49 PM   #3
akcel
Member#: 10268
gc8 I ride ride 24s
with the top down low.
lol
akcel is offline   Reply With Quote
Old 04-10-2004, 04:12 PM   #4
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Your turbo is too small.
Old 04-10-2004, 08:34 PM   #5
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
cRayZee is offline   Reply With Quote
Old 04-10-2004, 08:59 PM   #6
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
yeah, there are systems out there like you described. They break down into 2 basic groups, the cheap and scary and the expensive and good.
The cheap scary kind are basically a standard nitrous kit with a boost activated swith that cuts the nitrous at a specified boost limit. The problem with this is that at some point you are running a very large nitrous hit and alot of boost at the same time. Which on very stout motors isn't a problem, but if your motor can handle that, then why not just run the full n20 hit all the time? and ABSOLUTELY avoid these kits like the plague if you are using a RRFPR as most of them use a fuel return clamp to increase fueling. The power delivery on these systems is also pretty violent and wierd.
The good kind use a variable nitrous delivery system to phase out the nitrous as the turbo spools, most of these systems work very well and have a really nice power delivery and they modify injector pulsewidth for the extra fueling. Some higher end standalone systems also offer this type of functionality.
In the end... if you are running a turbo so big your motor won't spool it properly you might want to get out of the 4 cylinder world unless you have LOTS of money and an engineering degree
no-coast-punk is offline   Reply With Quote
Old 04-10-2004, 11:52 PM   #7
Hondaslayer
Member#: 4562
1995 Legacy LSi
But my FXT is still fastar than your car
Edit: Forgot to call you a gun hating pinko-liberal
Old 04-11-2004, 07:49 PM   #8
STi-Nismo Dood
Member#: 4149
MY93 Impreza 6MT
GC8.6 Aspen White
Default Re: NOS tubo spooling system
ESX, and DSS-racing make such applications...
ESX 9 sec. WRX with NOS/turbo, one time they forgot to pre-fog, and it ran 12s... , heard they were using the 100 shot application
DSS, 1g DSM block made 9s on a turbo application, while with NOS it hit 8s.
I would imagine they were using turbos as big as TD10 or T-76 Garrett or something, but the turbos were custom made so its secret.
STi-Nismo Dood is offline   Reply With Quote
NOS zex wet system drumaboi628 Normally Aspirated Powertrain 37 02-25-2008 03:10 PM
FS: NX express nos system.... MORETTES.. PsiRRizzed247 Southern California Impreza Club Forum -- SCIC 1 11-14-2002 10:24 AM
NOS brand nitrous system owners, help me out here! imprezive one Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-04-2002 08:09 PM
Just installed NOS fogger system 99Venom Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 01-21-2002 09:19 AM
