Old 04-10-2004, 05:40 PM   #1
chrisgru
Member#: 45908
Default Outside temp gauge on '04 STi
Hello all-
Does anyone know if it is possible to calibrate the outside temperature gauge on my '04 STi? Seems like it reads at least 15 deg lower than it should.
Chris
chrisgru is offline   Reply With Quote
Old 04-10-2004, 07:34 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Just a guess but is there a mode selection to change the reading between Farenheit and Celsius?
Old 04-12-2004, 04:59 PM   #3
chrisgru
Member#: 45908
Default Adjustment for outside temp gauge on
The display already shows F and not C so that is not the problem. Where is the sensor for the outside temp gauge? Maybe there is an adjustment setting near the sensor.
Old 04-12-2004, 05:13 PM   #4
JIN
Member#: 27731
Is there? I would love mine in Celsius!
Jin
JIN is offline   Reply With Quote
Old 04-12-2004, 08:48 PM   #5
tails
Member#: 51875
2007 STi
If you look at the bottom of the larger opening in the front grill (where air flows through the radiator) I believe you'll find the temp sensor. It's a small black numb just to the right of the cars center, directly in front of the radiator.
Your temp difference may be explained by the wind-chill. If this is indeed the temp sensor, it will be exposed to significant wind & other elements.
tails is offline   Reply With Quote
Old 04-13-2004, 08:41 AM   #6
bmorton
Member#: 43528
2004 Outback Sport
The temp sensor, like any other inanimate object, isn't affected by windchill. My OBS's temp display is very accurate when the car is moving, but it doesn't adjust to changes in temperature right away. If on a 0 C morning I leave my garage with the display reading 8 C, it takes a couple of miles for the display to slowly count down to 0.
bmorton is offline   Reply With Quote
Old 04-21-2004, 01:00 AM   #7
vf39hipsi
Member#: 55794
that's funny b/c mine reads about 15-20 degrees to warm
vf39hipsi is offline   Reply With Quote
Outbacks have a outside temp gauge? tkarabian Outback Forum 9 07-04-2005 11:22 AM
Outside temp gauge stuck at 56 degrees! Icepick Electrical & Lighting 5 12-19-2004 12:06 PM
Outside Temp Gauge only works when harness is unplugged! WR^2X Electrical & Lighting 2 06-19-2004 11:45 PM
Outside temp gauge DougG Electrical & Lighting 0 06-13-2004 03:58 PM
