Old 05-03-2000, 08:52 AM   #1
BLITZKRG-RS
Member#: 1332
2004 STi
Post ATT: OPIE, Tein S-tech/KYB AGX
Hey dude,
i know you have the S-tech/AGX set up, are u experiencing the ride height being uneven?? my driver front seems to be lower than the passenger front. and after checkin' thru the archives regarding the weight distribution. i found Impreza's left front weighs less than right front. so what do u think?
BLITZKRG-RS is offline
Old 05-03-2000, 09:31 AM   #2
Opie
Floresbian
Member#: 470
2016 Legacy 3.6R
'15 FXT, '16 Crosstrek
Post
I'm not having any problems with the Tein/AGX setup. The car sits level, no sagging, no noises. The last time I measured the height of the car everything was fine. I'll check again when I get home tonight and post the measurements here.
Opie is offline
Old 05-03-2000, 09:36 AM   #3
kkeetha
Member#: 332
Post
I have this set up also and I don't think that I have this kinnd of problem.
kkeetha is offline
Old 05-03-2000, 11:18 AM   #4
BLITZKRG-RS
Member#: 1332
2004 STi
Post
thanks guys,
also, do u guys have the soft s-tech sprngs or the medium springs? i know there are 3 types. hard, med. and soft.
cal
Old 05-03-2000, 07:01 PM   #5
Opie
Floresbian
Member#: 470
2016 Legacy 3.6R
Post
I've got the medium springs, I measured them tonight and they are level. My lazy arse didn't write down the measurements and all I can remember is the rear is around 24.5" from the pavement to the top/center of the fender well. I think the front were between 26 & 27" but I'm not sure and to lazy to go measure again
Opie is offline
Old 05-03-2000, 07:44 PM   #6
Eric
Member#: 48
1999 Impretza 2.5
Post
You should measure ride height from the center of the wheel (the middle of the tiny center cap) to the metal in the center/top of the wheel well. There is a small black plastic piece that runs along the bottom, measure to the metal, not the plastic.
BLITZKRG-RS, you may have a bad spring, ask for an exchange. You could try moving the spring to the other side of the car and see if the problem follows it.
Eric
Silver 99 RS
Eric is offline
Old 05-05-2000, 10:08 AM   #7
BLITZKRG-RS
Member#: 1332
2004 STi
Thumbs up
Thanks guys!
i've already swapped the spring/shocks from one side to another b4 i posted this msg. but its still the same! the driver side is lower than passenger side...
i know its not my weight that made the springs go bad! (lol, i only weigh 130).. im in process looking further onto other weak suspension parts. so far i've already noticed the rear lateral link is slightly bent(my mechanic showed me the bent section while the car is on the lift), so that could cause the car to sit unevenly. causing LR to sag and RF to lift up a little.
i have the new lateral link from Dale Teague waiting to be put in. i hope this will cure the problem.
later
cal
HTML code is On
(NoVA)WTT: TEIN Springs on KYB AGX Adjustable Gas Struts eastcoastGC8G Suspension/Brakes/Handling 4 02-05-2010 01:35 AM
02-03 WRX Tein S-tech/KYB AGX combo for sale blueandgold SCIC Private Classifieds 10 11-23-2007 09:39 PM
FS: 02/03 WRX Tein S-techs/KYB AGX (low miles) livnlegacy TXIC Private Classifieds 14 07-27-2006 08:54 PM
Tein S-Tech + KYB AGXs? karazyman Brakes, Steering & Suspension 8 03-09-2004 01:43 AM
to all those with s-tech/kyb agx suspension stimpy Technical Forum Archive 5 06-22-2000 11:49 AM
