Old 10-19-2000, 08:01 PM   #1
krnbk2
Member#: 2724
Question Searching boards all day with no luck....
Hi everyone...
I have been searching the boards all day to find topics that breakdown the differences between the '98. '99, and '00 Impreza 2.5RS.
I have not been able to find it.
I am really interested in buying one but am not sure which would be a better bet...I would also plan on putting a Turbo. (could this effect my descision??)
Any/all help is greatly appreciated!
Thanx,
Pete
krnbk2 is offline
Old 10-19-2000, 08:09 PM   #2
krnbk2
Member#: 2724
Post
I am mainly looking for... which is the better and more reliable car to get for turbocharging?
krnbk2 is offline
Old 10-19-2000, 08:12 PM   #3
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
I think the 98 and it's DOHC and not-gimpy MAF sensor is the best, but the phase II bottom end that they introduced in the 99 is stronger.
8Complex is offline
Old 10-19-2000, 10:30 PM   #4
rsquire
Member#: 265
1998 22B Blue
1986 Ford RS200 White
Smile
No two ways about..
getta a 98 with the hot wire MAF.
no discussion, really.. Just a lot of 1st hand experience. ( owning a 99 hot film MAF Turbo)
Whatever you do DO NOT get a MY00.. coz you up for another $2500 from a errrm "local supplier"
Richard
rsquire is offline
Old 10-19-2000, 10:52 PM   #5
markus
Member#: 438
2004 STi
White on Gold
Post
Strongly disagree here!!
Stay away from Phase I bottom end!!
MY00 + TEC-II + Turbo =
My 2cents.
markus is offline
Old 10-19-2000, 11:04 PM   #6
peepshow
Member#: 1777
2005 LGT
#92 FZippy
Post
I thought that the MY00+ was the consesus on the way to go because of the MAP and rear LSD?
peepshow is offline
Old 10-20-2000, 04:45 AM   #7
krnbk2
Member#: 2724
Post
WOW...now I am REALLY confused
I was told that the MY98 was not very smooth but was better for a turbo.
I am a little confused about the "Phase's" ??
WHich is better and why?
Also is the impreza a good candidate for a Turbo??
Thanx,
Pete
krnbk2 is offline
Old 10-20-2000, 04:54 AM   #8
BugBomb
Member#: 1342
99 OBS & SUXASS
May your line be smooth
Post
Impreza is fine for a turbo. You just have to spend a lot of money. Either spend a lot of money to build the engine up so it can handle the turbo (recommended), or spend a lot of money to constantly rebuild the engine.
BugBomb is offline
Old 10-20-2000, 11:33 AM   #9
dw
Member#: 25
Post
the 99 SOHC is referred to as "phase 2" motors.
dw is offline
Old 10-20-2000, 10:05 PM   #10
markus
Member#: 438
2004 STi
White on Gold
Post
Another difference between the Phase 1 and Phase 2 is that the Phase 1 pistons did not have skirts That is why the piston have been known to "rock" within the cylinder walls which in turn destroys piston rings, cylinder walls, etc..
IIRC the bearing mains were also beefed up on the Phase 2 motors therefore making for a stonger motor which will allow you to make more reliable power.
The SOHC heads on the Phase 2 motors also flow better that the DOHC variants. COBB Tuning has shown that on there flow bench testing.
Simply put, the phase 2 motor is the FAR better choice for a turbo set-up.
My 2cents.
[edit] for spelling
[This message has been edited by markus (edited October 20, 2000).]
markus is offline
Old 10-21-2000, 09:27 AM   #11
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
I agree Markus, but the catch is that mid-late production 98 Forester and 2.5RS had a PhaseII shortblock with DOHC heads.
THAT would be the best 2.5RS to start with as long as you don't care about 1) having the older front fascia 2) quite possibly having an older 4 bolt tranny 3) not having rear LSD (2000+)
Read Trey Cobb's post here to find out how to spot a MY98 "Phase 1.5" : http://www.i-club.com/ubb-files/Forum1/HTML/010028.html
ColinL is offline
Old 10-22-2000, 08:01 PM   #12
krnbk2
Member#: 2724
Post
OK....
say i get a MY99 2.5RS,
What is needed to properly turbocharge it?
and will i need to buy a new MAF every month?
krnbk2 is offline
Old 10-22-2000, 08:08 PM   #13
Member#: 67
1999 Outlasting
the competition.
Post
pete
look in the class. sean is selling his BITCHING 2000 rs with everything yo could want.
[email protected]
tom@kartboy is offline
HTML code is On
Been Searching for a while, but no luck... Hyelude Newbies & FAQs 0 06-23-2009 02:18 AM
for all you with no cats... rgprestige15 Texas Impreza Club Forum -- TXIC 30 05-27-2007 07:10 PM
Long Day With No End in Sight TBOD Off-Topic 0 04-03-2004 12:10 AM
If I didn't have bad luck I'd have no luck at all....... RALLYT-WRX Mid Atlantic Impreza Club -- MAIC 5 01-17-2004 12:40 PM
help...trying to find an old post w/exhaust sound files link, no luck w/many searches couldnthinkaone Normally Aspirated Powertrain 3 02-21-2001 09:07 PM
