Welcome to the North American Subaru Impreza Owners Club Wednesday May 6, 2015
Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 04-10-2004, 08:41 PM   #1
jmcomp124
Member#: 57357
Question Turbo Hood Scoop- How does it function? Any special care during car wash
This is my "very first Turbo car" with a hood scoop, so I have a newbie concern.
I used to take my Jeep to a touch-free car wash (with wax and the works) and I am thinking of taking the FXT to the same place too.
If the water and wax gets inside the hood scoop, will that cause any problems in the long term? They usually require that the engine be left running (in neutral) during the wash. I was almost thinking of stuffing some cloth (silly thought) into the hood scoop to prevent the water/wax from getting in, but with the engine running I thought it may not be a good idea. Before I take it to the car wash, please educate me on how the "functional hood scoop" actually works.
Thanks,
-Jai
jmcomp124 is offline   Reply With Quote
Old 04-10-2004, 11:12 PM   #2
irmiger
Member#: 54241
2004 Forester XT
Java Black
The hood scoop requires no "special" care at all and automatic car washes are just fine. The high-pressure water jets usually aren't angled enough to get inside the scoop and bend the intercooler fins. If wax buildup is a concern, then a periodic cleaning with an aluminum- and rubber-safe degreaser should periodically clean that out.
The scoop is a pretty simple thing so it's easy to understand. It directs air into the turbo's intercooler which, in turn, cools the air going into the engine itself. The reason for cooling the air is that as the turbo compresses the air, the air heats up. The cooler you can get that air, the more power you develop.
Simple huh?
irmiger is offline   Reply With Quote
Old 04-10-2004, 11:29 PM   #3
jmcomp124
Member#: 57357
Simple huh?
Thanks for the explanation. Makes sense, the cooler you can get the air, the more air molecules you can fit in (Ideal gas law PV=nRT..thanks to Avagadro, Charles and Boyle's law) and hence better combustion resulting in more power and a faster Forester
What happens to the water that get's into the intercooler?
Rain, snow etc?
-Jai
Old 04-14-2004, 03:46 PM   #4
DriftZero
Member#: 39616
Everyone has
stories they bore me
No problem with wate getting in the IC. If you like the look of the hood scoop but find its a bit small for your taste, the Japanese 02-03 Sti hood scoops can fit your forester.
SOD
Eli
DriftZero is offline   Reply With Quote
Old 04-14-2004, 03:53 PM   #5
Chromer
Member#: 20325
08 Yamaha WR250R
07 Suzuki DL650
It doesn't "get into" it, it gets "onto" it and drips off the bottom. Same thing as getting water sprayed on your radiator.
Chromer is offline   Reply With Quote
Old 04-14-2004, 05:35 PM   #6
looney
Member#: 44464
2004 FXT-MT
w/hitch for my c-crib
nice to know we have a mad scientist among us...
looney is offline   Reply With Quote
Old 04-15-2004, 09:53 AM   #7
Peaty
Techno Sapien
Member#: 449
2010 Legacy 3.6R Lim
Azurite Blue Pearl
Peaty is offline   Reply With Quote
Old 04-16-2004, 12:59 AM   #8
Ghostrider600
Member#: 37992
06STI 09STI 09LegSE 99RS
FWIW, if you're really concerned about the efficiency of your intercooler, you'd have to take it off the top of the engine and swap to a Front-Mount intercooler (heat rises, etc, and even when you're moving, there's still some minimal residual heat-soak into the IC just from radiant heat from the engine itself--though the airflow counters this, moving the IC far away from the heatsource, and into maximum airflow is the best--it just sucks when you get backed into...)
Ghostrider600 is offline   Reply With Quote
Old 04-16-2004, 01:40 AM   #9
Blugin
Member#: 5270
2008 EvoX MR
Red
Don't be woried about pressure wash bending fins eiher...I've pressue washed many an intercooler with no ill-effects... Don't even worry about the hood scoop. Just pretend you don't have one.
Blugin is offline   Reply With Quote
Old 04-16-2004, 07:56 AM   #10
DriftZero
Member#: 39616
Everyone has
Yea good point Blugin.
SOD
Eli
Reverse hood scoop....how bad would it be with a top mount? jsavage Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 06-06-2005 01:47 AM
sellin car to affordable..how does it work? btn_turtle Alaskan Impreza Club Forum -- AKIC 15 06-05-2005 02:12 AM
Turbo-back exhaust...how does it work? Silver_SportTrac Newbies & FAQs 7 02-24-2002 04:02 AM
Vent covers and hood scoop during car wash codemunky Technical Forum Archive 4 07-05-2000 07:48 PM
Is the hood scoop on the WRX functional? AKGC8 General Forum Archive 12 06-05-2000 03:40 PM
