Old 04-10-2004, 08:56 PM   #1
saar
Member#: 43770
2013 Impreza WRX Lim
2001 Impreza WRX STi
Default strange oil problem...
Hello...I am buying a 00 2.5rs this week....guess i should mention i have owned a Rs before...so this will be my second....the rs i am buying has 68,000km's on it ...and has been treated well...however when i took it out for a test drive today....once we got back ..there was white smoke under the hood....the girl whos selling it just had the oil changed at a place other than where she noramally takes it ..( a random oil place as opposed to a suby dealership..) and they used a generic oil fitler ..not subaru..anyways...it was not leaking oil on here drivway when we left....but after we got back..a few drops came out...i crawled under the car..and saw as little oil forming a drop on the filter...so i wiped it off...started the car....two minutes later another little drop started forming...wiped it off..and did it once more...anyways...anyone have anyidea what this could be ...? i am getting it inspected at a dealership tommorow...but should i be expecting bad news..? any help is really appreciated...oh ..and also..there was no smoke coming from the tail pipe...but some was coming out(or off) of the cat right after the header...thanks again..
saar is offline   Reply With Quote
Old 04-10-2004, 09:05 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
use oem filters
It there could also be a leaking crank seal, wich is very common.
Jay
Old 04-10-2004, 09:07 PM   #3
saar
Member#: 43770
yeah...thats what most of my friends figured..thanks for the replie...i was told if they dont properly seal the filter..all the oil pressure can push some oil out the seal..
Old 04-10-2004, 09:10 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Make sure the filter isn't double-gasketed, this can happen if the rubber gasket from the old filter sticks to the filter base on the engine and the new filter gets installed on top of it. If this happens it will cause a leak.
Old 04-10-2004, 09:17 PM   #5
saar
Member#: 43770
so the smoke coming off the pipes and from under the hood would be from the oil buring off the piipes..? it would seem hard for the oil to get from the filter to the cat though...
Old 04-11-2004, 04:10 PM   #6
Scooby Blue
Member#: 12112
MY00 RS
When you drive around, the will oil get blown everywhere. When I installed my fumoto valve, it leaked at first. I got the yummy smell of burnt oil!
Scooby Blue is offline   Reply With Quote
Strange boost problem with a strange dealer diagnosis. Help? Computergeek24 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 10-09-2006 12:34 PM
strange vent problem kastle Legacy Forum 2 07-12-2002 10:31 PM
Strange electrical problem oldleg Service & Maintenance 1 05-21-2002 10:02 AM
('93-'01) Strange leakage problem Loki Impreza Forum 2 06-29-2001 02:04 PM
