Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 04-11-2004, 01:07 AM   #1
ommmjido
Member#: 35746
08 White GRB
Wrong Fitment Crew #001
Default how to adjust Cusco Zero 2Rs?
installed some Zero 2rs today and they're REALLY REALLY stiff. i bought them used so i dont have the tool to adjust the stiffness. do i have to use the specific tool from Cusco to adjust it or i can use some substitutes? if so can i purchase the tool itself from Cusco or where can i get it? aslo how can u tell which setting ur on?
i hope im on the stiffest setting right now coz they r really, really stiff.
ommmjido is offline   Reply With Quote
Old 04-11-2004, 01:16 AM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
The adjustment is on the bottom of the strut. There is a knob that is normally used to adjust it, but I'm pretty sure you could still turn it without the knob with a pair of needle nose pliers or something similar. There are only 5 settings. You may be able to see the numbers on the bottom. They come from the factory set at 3. No matter what you set them to, however, they are still going to be pretty stiff. It took me 2 weeks to get used to them. I left them on 3 all around and absolutely love them now. My fiance is a different story. Although. . she hasn't complained too much lately so she must be getting used to them.
Calvin
cnk is offline   Reply With Quote
Old 04-11-2004, 01:20 AM   #3
ommmjido
Member#: 35746
08 White GRB
i tried turning the d shape knob with pliers, it turned, but nth really happened. i mean there was no click or nth, how am i suppose to know which setting im on, as i see no numbers anywhere?
Old 04-11-2004, 01:29 AM   #4
cnk
Member#: 10757
It's been a while since I last looked at the adjustment screw. I would say to turn it all the way left and then all the way right to see where the endpoints are. The middle of those 2 points would be setting 3 and then the middle of setting 3 and the leftmost endpoint is 2 and the rightmost endpoint is 4.
Calvin
Old 07-03-2004, 10:28 AM   #5
SpaceHamster
Member#: 34113
04 STi
WRBP
Sorry for bringing back an old topic, but I just found myself in the same situation (used 02r's w/ no tool or instructions). Ill go try turning the adjustment knob with a set of pliers, but Im also trying to understand how to adjust the height and camber. Could I convince you (cnk) to take some pics/scans of any manuals you got with 02rs?
SpaceHamster is offline   Reply With Quote
Old 07-03-2004, 01:18 PM   #6
cnk
Member#: 10757
The manuals are pretty useless since they're in Japanese. As I stated above, it's a 5 point adjustment for dampening. As for height, it should be pretty self explanatory when you look at the coilovers. At the bottom mount, there is a locking collar. If you want to lower it, raise the locking collar and then use the spanner wrench to turn the upper most collar directly under the spring so that the entire coilover turns and it goes down. Once you've gotten the height you want, tighten the locking collar. To raise it, turn the middle locking collar instead to raise the coilover out of the bottom mount.
For camber, just look at the mounting plate. There are tick marks to set your camber. You need to get an alignment after you install the coilovers. Then you can adjust camber in or out by loosening the 4 bolts and moving the top of the coilover in or out. There's really no need to use it to adjust camber and the alignment shop shouldn't have to touch it when setting your camber. They should be able to do it with the camber bolt at the bottom of the strut.
My advice since it seems that you don't really know how coilovers work is to just take it to a good racing shop that is familiar with coilovers. Have them set the car up for you and corner balance it. Then leave it alone and don't change anything except the dampening adjustment if you want/need to. If you track your car, then you'll need to do more research on suspension geometry and how to make adjustments. There's really no difference in adjusting these coilovers over any other brand coilovers.
Calvin
Old 07-04-2004, 04:08 PM   #7
virpacalis
Member#: 19214
'07 STI
in the slow lane
On the bottom face of the part that turns there's an indentation that's pointing to a number 1-5. Mine came set at 3. The piece that turns should click audibly one time for each place it's moved.
virpacalis is offline   Reply With Quote
Jacksonville, FL - Cusco Zero-2Rs with 2 sets of Cusco Springs digitalseance Suspension/Brakes/Handling 5 04-28-2009 11:07 AM
Cusco Zero-2Rs (with Hoosiers coming in a few weeks) virpacalis Motorsports 2 05-12-2004 11:44 PM
Cusco Zero-2Rs starting to get noisey downeyer Brakes, Steering & Suspension 7 07-07-2003 12:12 AM
Tein HAs vs. Cusco Zero 2Rs (GC8) moss Brakes, Steering & Suspension 11 11-20-2002 02:12 PM
