Old 04-11-2004, 12:18 AM   #1
henzly23
Member#: 35286
2015 Impreza Hatch
Default Gauges hooked up to dimmer.. will this cause problems?
I installed Blitz AC gauges this week(Boost, Oil Temp, EGT) and tried a couple wiring methods. The one i decided to stick with was running the gauges lighting through the dimmer to dim the gauge lights with the rest of the interior lighting. My only concern came when testing them out..
I don't have the temp sensors for EGT or Oil temp hooked up yet so I am not getting any readings to display. However when I dim the lights in the car the needles on those two gauges move along with the changing current flowing to the lights. My questions is will this behavior disappear when the temp sensors are hooked up, OR will dimming the gauges equate to inaccurate temp readings? Not sure if anyone else has ran across this problem or had similar questions. Tried searching but had no luck.
Matt H
henzly23 is offline   Reply With Quote
Old 04-11-2004, 01:28 AM   #2
it8ezbngrn
Member#: 35590
You sure its hooked up right. usually it is a seperat circuit, at best they share the ground wire.
it8ezbngrn is offline   Reply With Quote
Old 04-11-2004, 02:11 AM   #3
henzly23
Member#: 35286
2015 Impreza Hatch
the wiring schematic shares a gound.. its hooked up right
Old 04-11-2004, 07:39 AM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
It sounds like you have everything connected to the dimmer ground which is not a direct ground. It's a fixed positive, variable negative circuit. The ground for the metering circuits should be direct to chassis, the lighting should be connected to the controlled dimmer ground. You can refer to the factory wiring manual if you have one or can get access to one.
Will a JDM 4EAT hook up to a USDM WRX? TrunkMonk Transmission (AT/MT) & Driveline 2 10-16-2014 11:22 AM
Will this cause problems ???? z38er Built Motor Discussion 7 09-12-2009 12:35 PM
Will this cause emissions problems? AM5562 Newbies & FAQs 4 03-25-2008 05:31 PM
What will hook up to the Cobb Catback TXBlueBeast Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-12-2003 09:04 PM
Anyone w/ WRX install an egt gauge hooked up to the ecu? cmb Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-04-2001 02:47 PM
