Old 04-11-2004, 04:30 AM   #1
Seeing StaRS
Member#: 5294
Exclamation Oil leaking from spark plug wells normal?!
Hey guys I just tuned up my RS yesterday and swapped out the Crampion plugs and oem wires for a nice set of NGK V-powers and Magnecore wires. I'm very pleased with the resulting improvement in power delivery: its far more smoother and rev-able.
However, and this is a big however....
When I was removing the spark plug boots from the motor I noticed oil sitting in the top "lip" of the spark plug well in both cylinders 3 & 1 on the passenger side. In fact, a small trickle of oil ran down the side of the motor from the valve cover hole of cylinder 3 when I pulled the rubber spark plug boot off.
I did not have anything like this in the driver side plug wells. I'm concerned I may have a bad seal or gasket on the passenger side portion of my motor. I haven't *knock on wood* had any issues resulting from this and I don't / haven't had any oil leaking from the area. So any takers on explaining to me whats going on?
I'm freaked out by this
Thanks
Joe
Seeing StaRS is offline   Reply With Quote
Old 04-11-2004, 01:13 PM   #2
Seeing StaRS
Member#: 5294
anybody?
Old 04-11-2004, 01:52 PM   #3
YaZahX
Member#: 11932
1998 CW ITR
2006 NBP SI
its kinda normal, its the seal between the valve cover and the tube for the plugs and wires...
if its alittle dont worry about it yet(although oil can eat through the rubber of the plug wires)
if u should decide to change these seals do the valve cover gasket aswell(and check the 'half moons' on the back of the head(might aswell fix everything in that area once)
YaZahX is offline   Reply With Quote
Old 04-11-2004, 10:18 PM   #4
Seeing StaRS
Member#: 5294
YaZahX thanks for information, I appreciate it
Joe
Old 04-11-2004, 11:33 PM   #5
2pt5RS
Member#: 10853
2013 BRZ LTD
Satin White Pearl
I agree with yazahX as well...mine was doing this and had the valve cover gaskets replaced under warranty.....oddly enough, I got them replaced at 59,400 miles.....JUST before the warranty expired....
2pt5RS is offline   Reply With Quote
Old 04-12-2004, 12:46 PM   #6
Seeing StaRS
Member#: 5294
Were you modded when you had them replaced? Not that I think it would do anything but I have an intake and exhaust and don't want to find out they will deny me a claim.
Old 04-12-2004, 06:31 PM   #7
2pt5RS
Member#: 10853
2013 BRZ LTD
Satin White Pearl
intake/exhaust when I got them done....as well as diff plugs...I had the iridiums at the time....the dealership said nothing, except that my car is loud
Old 04-12-2004, 10:19 PM   #8
Seeing StaRS
Member#: 5294
Glad to hear they didn't trouble you
Joe
Old 04-13-2004, 04:51 AM   #9
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
the spark plug bonnets need to be replaced about every 30k with the valve cover gaskets, they get dry and lose their form due to fuel/oil contamination
Old 04-15-2004, 01:48 AM   #10
Seeing StaRS
Member#: 5294
What exactly classifies as the bonnet? The rubber boots that plug into the valve cover? Or, is this some sort of seal that sits around the hole for the spark plugs?
Joe
Old 04-15-2004, 02:30 AM   #11
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
Joe
there's a seal around the top of each spark plug tube between the tube and valve cover itself, these have to be replaced about every 30K(honda's used to have a seal of the same idea but different shape) or they dry out and lose shape/leak.
Jeremy
Old 04-15-2004, 03:22 AM   #12
Seeing StaRS
Member#: 5294
Jeremy I appreciate your input. So is this a task your average idiot such as myself could handle replacing or a more advanced chore? Thinking about it, I'm still under my 60k warranty so I'm assuming this could be covered. Unless that is its considered a wear and tear item being that it has to be replaced every 30k?
Joe
Old 04-15-2004, 10:22 AM   #13
Section 8
Member#: 821
It easy. 5 bolt heads on the valve cover, and likely any intake that you have. Stuff a towel down under the valve cover and over the cross member so you don't spill oil all over when you take the cover off. If you let the car sit overnight before you start there will be minimal oil. I would still use the towel because oil on the exhaust can easly be prevented, as well as spills on the driveway/garage floor ect.
The boots will be staring you in the face when the valve cover is removed. Pull them off, and replace with the new.
cheeRS,
Greg
Section 8 is offline   Reply With Quote
Old 04-20-2004, 07:16 PM   #14
nkodemus82
Member#: 5119
2009 WRX 5dr
it's an extremely easy job.
just be REALLLLLLLLLLLY careful when you are wrenching those bolts back into the valve (rocker) cover. I stripped one, and had to spend a hard few days learning how I would go about replacing my cams. Much more work than I should have had.
So just be careful! If you are torquing them back on, well, good luck. I think 5-6, maybe 7 lbs is all it took. Really just pushing rubber seals together. I was in idiot, and followed numbers that were obviously (also obliviously) bad.
Only benefit to doing the extra work was that I now know I can install my own cams!
nkodemus82 is offline   Reply With Quote
Old 04-21-2004, 02:08 AM   #15
Seeing StaRS
Member#: 5294
Thanks for the continuing input - any other takers?
Joe
Old 04-21-2004, 03:44 AM   #16
spshultz
Member#: 1415
2005 OBS 3.0R
'12 SantaFe
If this is any indication on how easy it is, I had my 11 year old son do the passenger side valve cover gasket and spark plug tube seals and I did the drivers side. Of course I watched as he did it but if he can figure out how to do it then it's pretty simple.
spshultz is offline   Reply With Quote
Old 04-21-2004, 11:09 AM   #17
YaZahX
Member#: 11932
1998 CW ITR
2006 NBP SI
NICE
Old 04-21-2004, 03:52 PM   #18
obyone
Member#: 16523
this anymore???
Jeremy
I'm not saying you're wrong, as I honestly have no idea, but my dealer never said that those seals needed to be changed. I even asked if there is any maintainance I should have performed while my engine was in pieces.
I asked at 40K miles and again at 65k.
obyone is offline   Reply With Quote
Old 04-21-2004, 03:57 PM   #19
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
if they were smart, they would have replaced them just to prevent a comeback
just my $.02
$10 in parts is worth more then another trip to the dealer
Old 04-21-2004, 04:05 PM   #20
obyone
Member#: 16523
this anymore???
just my $.02
You do realize I am speaking of Lynwood Subaru right?
Old 04-21-2004, 07:16 PM   #21
Yotsuya
Member#: 935
Jack Soo Fan Club
I've had oil in that gap for a while; never got down through the plug boots, though. Another something to do in a few weeks, I guess. Is there a part number for the bonnetts?
I'll have to peek under there; I never considered if there was enough room to remove the valve covers.
Yotsuya is online now   Reply With Quote
Old 04-21-2004, 11:50 PM   #22
Seeing StaRS
Member#: 5294
hey good question... what is the part number?
Joe
Old 04-22-2004, 01:29 AM   #23
YaZahX
Member#: 11932
1998 CW ITR
2006 NBP SI
just my $.02
where i work, when we do the sevice if we notice any oil on the plug we tell the customer it should be done... many times we are looked at to be sneaky for this, but we do tell them its leaking
Old 06-28-2004, 04:49 PM   #24
chrisj
Member#: 582
1999 Impreza RS
I just posted about somthing similar today. Take a peek at the pic and see if we're on the same page. So what are the parts that I need to do this. Is there a seal kit for the upper oiling area or do I need to go in and point to a picture at my Subaru dealer?
Also...what IS the correct torque for the valve covers.
TIA, Chris
chrisj is offline   Reply With Quote
Old 06-28-2004, 05:04 PM   #25
Slack
Member#: 17548
I don't remember the exact torque specs (very low 10~20ft/lbs?) for the valve cover bolts, but I do remember that they need to be replaced with new ones. I just had the same thing happen to me a while ago. Had oil leakage in 2 of 4 spark plug tubes. I replaced spark plugs, spark plug tube grommets, valve cover seal, and valve cover bolts. Was inexpensive and easy to do.
Mick
Slack is offline   Reply With Quote
Found Oil Leak in Spark Plug area Omega2000 Service & Maintenance 2 04-24-2004 12:32 PM
Oil on spark plug wires normal HighTachPrez Normally Aspirated Powertrain 1 05-21-2003 03:36 AM
How much oil leak from turbo is normal? VSM EXtasy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-20-2003 12:52 PM
Oil in the Spark Plug Well! Lygriek Service & Maintenance 3 01-15-2002 02:39 PM
Oil leaking from spark plug area... anyone else had this? BoomerRS Technical Forum Archive 7 06-29-2000 06:16 AM
