Old 04-11-2004, 11:28 AM   #1
trd20
Member#: 58970
1999 Impreza 2.2rs
Default what kind of power can i expect to get out of a 99 l coupe 2.2 ltr?
topic^^^
a rex swap is my last option, i would like to see if i can get it up around 200 give or take some.
is it posible?
and if so some suggestions on how to do it and what parts to use or look into would be gret thanx.
trd20 is offline   Reply With Quote
Old 04-11-2004, 12:05 PM   #2
Osgood30
Member#: 20437
1999 Impreza RS
STI Ver7
sure you can get that, with turbo, and a thick wallet.
Osgood30 is offline   Reply With Quote
Old 04-11-2004, 12:07 PM   #3
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
There is not much for the 2.2L engine. If you had a 2.5, maybe you could get up to 200. The problem is that no one makes cams or anything else for the 2.2L that will significantly increase your HP.
If you want to stick with the 2.2- try adding a turbo charger. Just don't blame me when you blow a piston or the block. If you run 7psi you could get around 200Hp at the crank and would not have to worry too much.
Do a search on this forum to find what parts you'll need. There are a few people that have put out pretty good lists.
speedyHAM is offline   Reply With Quote
Old 04-11-2004, 01:14 PM   #4
trd20
Member#: 58970
1999 Impreza 2.2rs
what can i get up to without turbocharging?
Old 04-11-2004, 01:59 PM   #5
nunyo
Member#: 35575
'07 Subaru OBS
Silver/Gray
Not much to be gained without going forced induction. I've heard that an axle back and an intake make for a noticeable improvement over stock.
There's always NOS.
nunyo is offline   Reply With Quote
Old 04-11-2004, 02:18 PM   #6
trd20
Member#: 58970
1999 Impreza 2.2rs
ell for the price of custom turbo setup for a 2.2 i might as well just do a rex swap....if i can find an engine and notworry so much about relibility
Old 04-11-2004, 08:34 PM   #7
linsavy
Member#: 11620
1997 GF4-STiV3 clone
Maybe, just maybe, those guys will finish the supercharger before our cars die of old age. Otherwise an intake, light crank pulley, mid-pipe and catback are the most reasonable options. Borla makes a header but I can't say if it actually does much. Stick with 2-2.25 inch pipes.
Use NGK copper plugs and some Mobil 1.
If you want more hardcore, swap bumper beams for the ultra lite bumpers of death.
The car benefits from suspension upgrades very well. That's where my money went. Lighter wheels with a smaller circumference tire is also a great help as is swapping the front brakes and rear brakes for some RS ones.
linsavy is online now   Reply With Quote
Old 04-11-2004, 10:35 PM   #8
2pt5RS
Member#: 10853
2013 BRZ LTD
Satin White Pearl
you might want to look into either some 1.8L heads or 2.5 heads....both are dual port, compared to single port on the 2.2 this will give you a boost in torque, which we all know is what helps make cars fast......
2pt5RS is offline   Reply With Quote
Old 04-12-2004, 01:03 AM   #9
imprezin04
Member#: 39482
2000 Impreza RS
SRP
i have a 96 L coupe and i was wondering the same thing. But my car is an auto. How how fast would i be running 1/4 mile stock with my 137 hp? 17secs? can i get my 2.2L to run like low 16's high 15's? exhaust, intake, headers? pulleys? about how much would it cost? or should i save my money and get a rex swap as well? i think i read in a magazine that they do have a turbokit for the 2.2, but would it be worth it? also, any parts from the legacy ej22t interchangeable with my engine? thanks
imprezin04 is offline   Reply With Quote
Old 04-12-2004, 09:14 AM   #10
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
auto Impreza L's are not drag cars no matter what N/A mods you plan on doing. putting $1500 into suspension will provide a much greater fun factor than $1500 of N/A engine mods on a 2.2l. i think the general consensus is that turbocharging a 2.2l or 2.5l is rarely reliable.
whtlegacy is offline   Reply With Quote
Old 04-12-2004, 09:29 AM   #11
Storm
Member#: 5218
96L Most Over-
Developed Beater
You know this for certain? Is there some proof to this? Looking at the ports on both heads, I don't think the singleport flows that bad.
I think the 99 2.2 had dualports anyway.
Jay Storm
Old 04-12-2004, 10:40 AM   #12
linsavy
Member#: 11620
My 5spd 2.2L with K&N, snorkus ectomy, pulley, 2.25" mid-pipe and WRX catback, on 195/55/15 Toyo/Legacy Turbo wheels ran 16.8 in the quarter mile. Spare and jack removed and 1/4 tank of fuel. A perfect launch might be good for a few 10ths better.
Start saving for the swap. A 2.5l N/A will go in fairly easily and it can be modded up to 200hp. This will still run quite a few bucks.
Old 04-12-2004, 03:31 PM   #13
xtorted-legacy
Member#: 19568
1995 Impreza L
Brilliant Red
not to steal the thread, but is the 95 2.2L dual port exhuast ports?
Either way, i posted on rs25.com and most people feel the 2.2L is more duable than the 2.5L since the ej25 is an overbored ej22 with the same smaller rods, and with the additional weight or larger pistons creates problems along with the thinner piston walls. Personally, i am going to stick with the 2.2L and mod the suspension because i dont care about 1/4 mile times. I wanna go curve up twisties, autox or go off road. Preferably the last one. If i want more power and when i can afford it, i will swap a usdm wrx engine and call it a day. I wanna run all day long and hard and not worry about tuning or if i am gonna detonate and blow up. And the money it would cost me to swap a 2.5L in, i could put into suspension or tranny, i want the Sti-ra tranny with front lsd, upgraded center diff , a beefier rear lsd(L's dont have one to begin with) and the quicker ratios . But thats me.
xtorted-legacy is offline   Reply With Quote
Old 04-12-2004, 04:37 PM   #14
Opie
Floresbian
Member#: 470
2016 Legacy 3.6R
'15 FXT, '16 Crosstrek
Talking
Build a 2.2T
Opie is offline   Reply With Quote
Old 04-12-2004, 09:19 PM   #15
trd20
Member#: 58970
1999 Impreza 2.2rs
interesting stuff indeed
Old 04-13-2004, 07:06 PM   #16
2pt5RS
Member#: 10853
2013 BRZ LTD
Satin White Pearl
Jay Storm
my buddy got a set of 1.8 heads for his 98 2.2 and is going to put them on b/c they are dual port. the dual port helps with torque, especially at low end
Old 04-13-2004, 10:48 PM   #17
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Thats stupid, the 1.8 heads have no flow.
Old 04-13-2004, 11:48 PM   #18
ttboy19
Member#: 38043
2004 impreza rs4sale
'10 Legacy 2.5GT
If it fits, you can swap anything.
ttboy19 is offline   Reply With Quote
How much power can I expect to gain by changing my air filters? Malasubidude Newbies & FAQs 17 07-16-2008 12:54 PM
what kind of power can i expect mtchll50 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-01-2008 02:02 AM
When you go to a strip club, what do you want to get out of it? Jessie James Off-Topic 67 04-12-2007 12:11 PM
How can executives expect to get away with fraud? MeddlingKids Off-Topic 12 12-17-2004 05:45 PM
So what can I do to get rid of the severe drop in my rear? BrysImpreza Forester Forum 10 12-17-2003 11:23 PM
