Old 04-11-2004, 05:21 PM   #1
supercompact
Member#: 36311
95 Toyota Supra
Default Has anyone broken a rod or cracked a sleeve yet?
So far I have only seen people break pistons in the STI shortblock but everyone seems to think you have to upgrade the rods and sleeves to make mild power (~400hp). I know the sleeves are thinner than the other EJ's but how do we know that the quality of the iron used in the sleeves are not better than the EJ20. Aren't the rods forged from the factory? Even though the rods are smaller than a set of aftermarket rods, who is really going to make 1000hp to push the limits of aftermarket rods? I would just like to know what the limit is of the other parts of the shortblock.
supercompact is offline   Reply With Quote
Old 04-11-2004, 07:24 PM   #2
guinness
Member#: 45885
1997 STI3 TYPE R
Sonic Blue
Wink
Good question.............
guinness is offline   Reply With Quote
Old 04-11-2004, 07:49 PM   #3
Tuning Factory Inc.
Vendor
Member#: 3600
I've only seen piston failures so far but then again, no one has gotten to over 450 whp yet.
Tuning Factory Inc. is offline   Reply With Quote
Old 04-12-2004, 12:11 AM   #4
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
All I have heard of is piston/rod bearing failures so far for the 257. People aren't pushing enough power to oval even the thinner liners...yet.
The weak link in most subaru motors is by far the rod bearings from what I have seen. Followed by the pistons.
mr2guru is offline   Reply With Quote
Old 04-12-2004, 12:15 AM   #5
boogerwrx
Member#: 13448
2002 wrx wagon
The rods are identical to ver7 or 8 2.0 sti rods. They are forged and have the cap locating pins to keep them inline. These rods will take increased boost, but what's the magic number? Would the cylinder ovalise before the rod snaps?
The rods are probably the nicest internal component on that engine. The crank is identical to 2.5 NA motor, have only 1 oiling hole per journal, and sometimes are out of balance by enough to make a difference.
And we all know about the pistons already.
Ron
boogerwrx is offline   Reply With Quote
Old 04-12-2004, 12:37 AM   #6
eightballrj
Member#: 18520
2005 L GT Limited
Ron,
I thought that we talked about the rods being conventional castings. I probably misunderstood ya. Hey, that makes me feel better too. Maybe I might start saving for some nice CP's this summer maybe before imprezafest if I get a good job, haha.
Richard
eightballrj is offline   Reply With Quote
Old 04-17-2004, 04:53 PM   #7
killersti
Member#: 59817
2004 subaru
i snapped the number one rod. I took it to the dealership, and the wouldnt cover it under warrenty because of abuse. The car had 10,698 miles on it. They said that my intake and blow off valve caused it. Then the procedide to tell me that if i wanted to prove them wrong to pay them to pull the engine apart. What should i do????????????
killersti is offline   Reply With Quote
Old 04-17-2004, 05:03 PM   #8
bezerk
Member#: 44809
2008 BMW M3
SATURDAY!!!!!!!!!!!!!!!
ask to test drive one of their stock cars and really show them what abuse can be..
bezerk is offline   Reply With Quote
Old 04-17-2004, 09:25 PM   #9
supercompact
Member#: 36311
95 Toyota Supra
So are you sure that you broke a rod... like you can see it sticking out of the block or is that what they told you it was? I'm willing to bet it was a piston instead of a rod, unless it is obvious.
Old 04-18-2004, 09:16 PM   #10
Crawford Performance
Member#: 42075
I have run 500bhp for quite some time on a stock STI short block with out any problems.
If you are breaking the ring lands on the piston or loosing a rod bearing, It is because of poor tuning not poor parts.
If you snap a rod, that is because of to much cylinder pressure.
And yes, when the rod breaks, It pokes holes in every thing that it can reach.
Quirt Crawford
www.crawfordperformance.com
Crawford Performance is offline   Reply With Quote
Old 04-18-2004, 09:37 PM   #11
supercompact
Member#: 36311
95 Toyota Supra
How many miles at 500bhp? What heads are you using? Its always nice to hear good numbers like that and still running.
Old 04-18-2004, 10:06 PM   #12
Member#: 42075
I do not know how many miles are on the motor because there is no odometer in this thing! What I can tell you is that it has been out to the desert eight to ten times for an average of three days per trip. The heads are off a 2.5 n/a motor, Twin cam style. It runs on 110 octane fuel at 20psi. It dose wheelies in fourth gear as easy as it dose in second gear. Bla-Bla-BLa.
Old 04-18-2004, 10:28 PM   #13
supercompact
Member#: 36311
95 Toyota Supra
Oh, Nice. I was thinking it was a street car. LOL!
Old 04-18-2004, 11:06 PM   #14
tm999xxx
Member#: 34408
07 Spec B
SoapBox?
awesome pic
tm999xxx is offline   Reply With Quote
Old 04-18-2004, 11:38 PM   #15
Member#: 42075
Well,,,,,,,,I drove it on the street once, dose that count?
Old 04-30-2004, 04:07 PM   #16
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
Close enough...
Old 05-01-2004, 04:19 PM   #17
eightballrj
Member#: 18520
2005 L GT Limited
Quirt... did you pop any wheelies on the street?? HAHA I bet the paddles dont hook too well on concrete though, LOL.
Old 05-01-2004, 09:36 PM   #18
Member#: 42075
First, Second, Third and Fourth gear wheelies to be exact
But not with the paddles. On the street, they make my teeth chatter and blurrrrrrrrr my vision.
Old 05-02-2004, 02:54 AM   #19
hotrod
Member#: 14141
2002 Impreza WRX
LOL
They probably also make a really annoying whappity whappity whappity sound too !!
If your beating out bearings due to poor tuning, does this engine tend to be more prone to killing a specific bearing?
Larry
hotrod is offline   Reply With Quote
Old 05-02-2004, 03:38 AM   #20
totoherbs
Member#: 7321
.... 122 IggPoints
Originally posted by hotrod
LOL
Larry
Ya, its kidney killing fun... I remember going down a street on a quad a few times.... besides the pain it causes you the road kills thoes rather expencive tires real quickly.
Old 05-02-2004, 12:00 PM   #21
Member#: 42075
LOL
Larry
I usually see #4 to be the first to go, followed by #1. This failure is usually caused by some other form of abuse, not just poor tuning.
I pulled down a motor last weed that detonated so hard, the wrist pin broke in half It just happened to be #4, but every piston in the motor was cracked.
Quirt Crawford
Old 05-02-2004, 12:26 PM   #22
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Wow... any chance of a pic of the broken wrist pin? I've NEVER thought anyone could break one of these Subaru wrist pins...
Old 05-02-2004, 12:36 PM   #23
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
2005 Chrysler Town & ****
If Nick has not broke on yet, I call BS
JP
Old 05-02-2004, 03:44 PM   #24
Member#: 42075
I got one even better than a broken Subaru part.
The broken parts that I am speaking of are from CP
When I get them back from CP, I will post the pictures for ya.
Quirt Crawford
Old 05-02-2004, 03:47 PM   #25
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Ahhh, no wonder... Subaru piston pins are BEEFY. I bet CP lightened them a bit and made the walls more thin (a good idea, but not if they're made too thin).
Ain't that the truth.
Has anyone broken STI RA gears? quickscooby Transmission (AT/MT) & Driveline 20 01-14-2004 05:00 PM
Has anyone broken third gear?? Night Kid Transmission (AT/MT) & Driveline 4 11-23-2003 03:06 AM
Has anyone ever dislocated and/or broken their ankle? Castor Troy Off-Topic 11 09-17-2003 09:49 PM
Has anyone broken the stock rear endlinks? Rich10 Brakes, Steering & Suspension 10 08-29-2003 01:03 PM
Has anyone broken an STi 6spd? stilesg57 Transmission (AT/MT) & Driveline 17 07-15-2003 01:12 PM
