Old 04-11-2004, 05:32 PM   #1
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
Default oil is not priming?
ok engines back in most of the stuff is hooked up
i pulled the fuel pump connector off and started cranking, no oil is being pumped, the pan is full, i even put oil into the turbo feed line and into the pressure sensor, and im talkin quarter quart down the pressure hole, filled filter w/ oil
*** is going on?
thanks
alex
Old 04-11-2004, 06:23 PM   #2
Unsung Boxer
Member#: 37196
hmm, does it sound like the engine has compression? does it crank evenly, or just real fast?
IF there is no oil, the piston rings cannot seat, and due to no lubrication, thus keeping it from running. You also have to remember that very little oil comes out of the oil tap.
Is the turbo currently hooked up? Are you tapping your oil at the service plug on top of the block? are you sure you remembered the keyway on the under drive pully? If you didnt, put it in, the gear for the oil pump will not spin.
These are the things to start checking, go from there. If you are really concerned that you dont have oil pressure, DO NOT RUN YOUR ENGINE, as im sure you know. You will spin a bearing, break piston rings, score the cylinder walls, etc.
-Jake
Unsung Boxer is offline   Reply With Quote
Old 04-11-2004, 06:46 PM   #3
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
it had compression just fine, i then pulled the plugs
the turbo isnt hooked up, i have the feed line kinda shoved into the return line, and im using that to check for flow
i really dont have any idea
plz help
thanks
alex
on that key thing for the crank, the oil pump sits on that crank so that the key doesnt matter, atleast mine does, the key only matters for aux devices, ac, etc
Old 04-11-2004, 06:56 PM   #4
kaos200
Member#: 2692
plz help
thanks
alex
he's not talking about THAT key, he means the key that goes on the crankshaft of the motor, its a little half moon shaped piece that slides into a notch on the crank.... But Im forgetting if there is one for the oil pump?....
kaos200 is offline   Reply With Quote
Old 04-11-2004, 06:57 PM   #5
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
i dont think there is, the sides of the pump are flat and it only goes on one way, well, 2, what i mean is that it sits over a circular rod <the crank shaft> with 2 flats made on opposite sides of it...so i dont see how i would need a key for it
Old 04-11-2004, 09:25 PM   #6
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
bump
hoping to have this figured out tomorrow
Old 04-11-2004, 10:14 PM   #7
kaos200
Member#: 2692
ohh yah thats how it is
Old 04-11-2004, 10:19 PM   #8
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
word
Old 04-11-2004, 11:16 PM   #9
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
is there a possibility that i put the starter on backwards??
the belt/crank is turning clockwise
Old 04-11-2004, 11:55 PM   #10
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
jeremy help me?!
Old 04-11-2004, 11:56 PM   #11
kaos200
Member#: 2692
no you cant put the starter on backwards, but the positive/neg could be backwards, however Im pretty sure that would screw up other things (shorts)
Old 04-12-2004, 12:08 AM   #12
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
yeah the neg has to be bolted to that mount on the tranny...so i know i didnt screw that up, theres no diaphrams inside that pump that could have burst from sitting so long then being used is there
Old 04-12-2004, 12:19 AM   #13
kaos200
Member#: 2692
no, its just a gear pump, not a reciprocating pump (ie not like most fish tank pumps)
Old 04-12-2004, 02:03 AM   #14
Unsung Boxer
Member#: 37196
it grounds through the block, so there is no way you can reverse positive and negative, either the starter works or it doesnt.
I guess what im getting at is: How do you know you have no oil pressure. If the cranking is normal, then obviously it has some sort of lubrication. If it cranks too fast, no compression is being bulit.
-Jake
btw, just list as many details as possible, if not sound clips.
Old 04-12-2004, 04:09 AM   #15
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
it goes glug glug glug w/ the plugs in and i can hear air out of the headers, its got compression, its speed is the same as my old engine, glug glug glug
Old 04-12-2004, 06:52 AM   #16
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
also what he was saying to me was that he was using the turbo line to check, like while he was cranking seeing if oil would come out that line, but he said it wasnt.
sorry to speak for you alex, thought that may be helpful.
Ben
Old 04-12-2004, 07:02 AM   #17
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Old 04-12-2004, 07:06 AM   #18
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
Default Re: oil is not priming?
Of the handful of times I've have tried this, I've never gotten oil to pump simply by dry cranking the engine with the starter motor. I just don't think the oil pump does anything at the 100 or so engine RPMs that the starter can pull off.
You may notice that if you have a oil pressure gauge, there's pretty much no oil pressure until at least half a second after the engine fires up. Many people (mostly oil companies) claim that engine wear is greatest from cold starting an engine after it's been sitting overnight.
Just make sure the turbo is primed with at least a few tablespoons of oil, hook everything back up including the fuel pump connector, and fire up the engine.
Good luck,
-WaC
Wayne
wac is offline   Reply With Quote
Old 04-12-2004, 07:10 AM   #19
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
i was kinda thinking this, but with the plugs out, the engine seemed to be spinning around 100 rpm, shouldnt that atleast push some oil out?
Old 04-12-2004, 07:12 AM   #20
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
Only if the oil pickup line and oil pump are full of oil and not air.
Old 04-12-2004, 07:21 AM   #21
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
hmmm
i want to believe this is the answer, but i swear i remember people saying they got oil pressure from cranking, and not like 2 psi, but more
do u have anything else to add?
thanks wac
alex
Old 04-12-2004, 09:35 AM   #22
Storm
Member#: 5218
96L Most Over-
Developed Beater
I'd check for oil somewhere else. Say, a valvecover. Oil should certainly be there by now if you've been cranking for awhile.
It's a PIA, but if you really want to make sure, I'd look in an area that get the most oil before firing it up.
Jay Storm
Old 04-12-2004, 09:38 AM   #23
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
thats always in idea, thanks!
Old 04-12-2004, 03:37 PM   #24
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
popped the valve cover and cranked for like 20 seconds, no oil came out...atleast that i could see
Old 04-12-2004, 07:12 PM   #25
Unsung Boxer
Member#: 37196
yup, sounds like u got no oil. is your oil pump new? old???
-Jake
Car Wont Start... Fuel Pump Not Priming... Any Ideas? dug-e-fresh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 08-09-2011 03:35 PM
fuel pump not priming/ecu not on? attitude Engine Management & Tuning 16 06-24-2005 12:16 PM
fuel pump will not prime, car wont start had to get towed! GregBolby Normally Aspirated with bolt-on Forced Induction Powertrain 17 03-24-2004 11:07 AM
10-30W oil is not good for Upstate NY WRXVII Service & Maintenance 23 12-14-2002 05:44 PM
JC Sports turbo kit is burning oil and IC is not working (its cold!) Andrew Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 05-08-2001 10:55 PM
