Old 04-11-2004, 08:59 PM   #1
turbocolin
Member#: 43539
95L 97L 03hedgehog
02 wag 180mph monster
Default need help jdm wrx engine into my 95 impreza l
hey i am doing a swap in my 95l and i am at a standstill
i cannot seem to figure out ow to install the jdm wiring harness into my car i am so confused
my entire car is gutted
i have the japanese wiring and jap ecu from a 94 wrx
i have the turbo crossmember
and i need to get the engine
can anyone help me figure out what to do
turbocolin is offline   Reply With Quote
Old 04-11-2004, 09:24 PM   #2
arcadian
Member#: 59310
Maybe you should get it installed by a mechanic? You might want to search the sticky topics, but I wish I could help you, but that the best I can do.
Keep us updated on your progress, BUMP!
arcadian is offline   Reply With Quote
Old 04-12-2004, 12:33 PM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
(pokes tread with ten foot poll)
(drops poll and runs away)
read the sticky treads at the top
Old 04-13-2004, 03:04 PM   #4
Puckaveli
Member#: 1518
00 2.5RS
Are the "JDM" diagrams you have in english? If they are your diagrams are for the UK which are 90% accurate.
Do you have the wiring diagrams for your US car also?
Which JDM wiring harness do you have, the engine harness or bulkhead harness, many n00bs get them confused.
Is your JDM wiring harness uncut?
Make a list of all the pins from your USDM ECU and all the pinouts of the JDM ECU. Then you will go through and match up the pins US vs JDM. Like this one. http://scoob2.no-ip.com/dl/ecu.xls most of the wires in the top 26 rows will be direct cut and splice. It get tricky once you get into what sensors share what power sources and grounds.
Puckaveli is offline   Reply With Quote
Old 04-13-2004, 07:28 PM   #5
turbocolin
Member#: 43539
95L 97L 03hedgehog
it is from a jdm wrx ra 1994 and i have no wiring diagrams as of yet
Old 04-14-2004, 09:52 AM   #6
Puckaveli
Member#: 1518
00 2.5RS
So do you have the wiring harness that plugs into the injectors and such on the engine and the wiring harness that the ECU plugs into?
You really need both wiring diagrams before you can begin with the wiring.
wrx swap into my 06 impreza outback?? shade1569 Subaru Conversions 0 12-31-2009 01:16 PM
JDM EJ20 into a 95 impreza wrxracer25 Subaru Conversions 12 01-18-2007 02:21 PM
Need help understanding WRX engine options jkbrand Newbies & FAQs 2 02-10-2006 04:18 PM
95 jdm wrx swap into my 98 2.5rs almost done spoonfedb18a1 Subaru Conversions 2 09-29-2005 11:09 PM
Did WRX interior in my 95 impreza L awd_dreamin Interior & Exterior Modification 19 04-20-2004 02:20 PM
