Old 04-11-2004, 09:15 PM   #1
noob w/ a scoob
Member#: 58282
Default 200+hp on 2K 2.5RS W/ out Turbo
Is it possible to get over 200hp out of the stock 165hp engine on my 2000 Impreza 2.5RS? I dont want to make it turbo because then you have to either replace the engine, or put many hours of work into the stock engine to get it so that it wont blow out after a while.
noob w/ a scoob is offline   Reply With Quote
Old 04-11-2004, 11:17 PM   #2
hyp36rmax
Member#: 24537
2006 LanEVO9 RS
SFVoltron White
well on your way to get 200+bhp N|A you will need to work on the same principles in getting a reliable turbo setup.
E.G stronger pistons, block, possibly a port/polish, ems....
im sure im missing some more stuff, N|A tuners please chime in....?
hyp36rmax is offline   Reply With Quote
Old 04-12-2004, 01:39 AM   #3
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
haha i like your name.
but if you say you want to go N/A because its "easyer" or less hours of work your mistaken. you should look into a usdm wrx motor swap, save up and have a shop do it.
or if your really into N/A search the na forums.
RS_to_WRX_swap is offline   Reply With Quote
Old 04-12-2004, 02:00 AM   #4
scotty305
Member#: 8877
2000 Impreza 2.5RS
(sept '01-jan '04)
1.) This question belongs in the "Normally Aspirated" Tech Section. "Normally Aspirated" = "N/A" = "non-turbo." This "Subaru Conversions" section is for people who are doing motor swaps mostly, converting their car to a different engine than it originally came with.
2.) I found LOTS of info, it took me about a minute, maybe two. I'll share my secret search technique with you:
-1- First open the search page , http://forums.nasioc.com/forums/search.php?s=
-2- If you're looking for 200hp, try typing in "200".
-3- For better results, be sure to focus your search in the "normally aspirated" section of the forums using the drop-down menu.
-4- Change the date to "any date" because Subaru has been building "normally aspirated" cars for a lot longer than 3 months.
Here are just a few of the threads I found, all of them are very informative:
http://forums.nasioc.com/forums/show...hreadid=390419
http://forums.nasioc.com/forums/show...hreadid=412497
http://forums.nasioc.com/forums/show...hreadid=449314
Hope that helps,
-s-
scotty305 is offline   Reply With Quote
Old 04-12-2004, 12:31 PM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
i would say yes easly... but your going to need cams and an aftermarket ecu
eventually cobb is suppose to release a reflash for the RS...
Old 04-12-2004, 02:18 PM   #6
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
eventually...
And you don't need an ECU to hit 200 at the crank. Just Cobb spicy cams with bolt ons will hit 200. But tuning never hurt a car...
Old 04-12-2004, 02:31 PM   #7
Boxologist
Member#: 21118
200 crank hp is pretty easy. that would put you at 165hp to the wheels or thereabouts.
to go more u have to open up the engine.
bang for the buck is a reliable and reputable swap.
Boxologist is online now   Reply With Quote
Old 04-13-2004, 07:44 PM   #8
subyrally
Member#: 52662
2009 dgm WRX hatch
86 & 87 rx, 1985 brat
i think i might be near 200 at the crank, ive done sprk plugs, intake and exhaust. and headers. just go one step at a time. good luck.
subyrally is offline   Reply With Quote
Old 04-13-2004, 11:05 PM   #9
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
thats optimistic.
Old 04-13-2004, 11:49 PM   #10
subyrally
Member#: 52662
2009 dgm WRX hatch
Originally posted by RS_to_WRX_swap
thats optimistic.
i try, its still faster than stock, and buttloads faster than my moms car that ive had to drive lately.
Old 04-14-2004, 02:37 AM   #11
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
you may have 165 + 18 hp in the best possible scenario. That's still only 183 hp.
whtlegacy is offline   Reply With Quote
Old 04-14-2004, 09:54 PM   #12
subyrally
Member#: 52662
2009 dgm WRX hatch
such a downer, huh?
Old 04-14-2004, 10:43 PM   #13
Wedge
Member#: 2279
2000 Slingshot
Pastelito Racing
Get a lightweight flywheel......and you'll notice the difference.
(Moreso than intake/exhaust crap)
Wedge is offline   Reply With Quote
Old 04-16-2004, 07:26 PM   #14
awdf00
Member#: 57289
1998 BMW M3
imo, i think its tough and expensive to reach 200 bhp. and with 200 at the crank, you'd actually only get about 145 awhp. or you can get teh NAWZ
awdf00 is offline   Reply With Quote
Old 04-17-2004, 11:16 AM   #15
Boost4U
Member#: 16459
1998 2.5RS
contact "dcoty" and ask him about his car....what a beast!
Boost4U is offline   Reply With Quote
Old 04-17-2004, 10:25 PM   #16
Rebellion
Member#: 8069
2002 Impreza WRX
Sedona Red + Mud!
you're saying exhaust and headers are only 18? should be higher than that. figure those two would be more closer to 25-30. (I think 18 is a whp gain, not crank)
Rebellion is offline   Reply With Quote
Old 04-17-2004, 11:20 PM   #17
subyrally
Member#: 52662
2009 dgm WRX hatch
i want to agree with that
Old 04-18-2004, 02:03 AM   #18
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
well the most N/A exhaust gains I've seen are on Patrick Olsen's Legacy dynoed before and after an MRT resonated, hi-flow cat headerback exhaust system. He got something like 14-16 hp/ 14-16 lb/ft torque at the wheels (I can't really remember.) That would be a little higher at the crank.
Subyrally, you claim to have exhaust and intake mods. An intake will be no more than 2-3 hp at best at peak. I just don't see you having +35 hp at the crank. For what it's worth, I'm also running an equal length headerback MRT exhaust and a rallitek intake. I also have a proECM chip. My car is quicker than stock, but I'm still not going to claim it's at 200hp at the crank.
Would 16x8 1/2 fit on a 99 2.5rs with out spacer? 99WRXEJ20 Tire & Wheel 3 04-05-2004 11:22 AM
turboify a 2K 2.5rs noob w/ a scoob Normally Aspirated with bolt-on Forced Induction Powertrain 9 03-31-2004 05:09 PM
My friends 2k 2.5rs wrx squirrel Member's Car Gallery 17 05-29-2003 07:48 PM
2k 2.5RS brake problem (unfixable?) gerardchau Brakes, Steering & Suspension 3 10-01-2002 04:35 AM
Quick Question: Stock hp @ wheels on 02 2.5RS? 2.5RS_MTN_RCR Normally Aspirated Powertrain 8 09-22-2001 01:32 AM
