05-25-2000, 11:06 PM | #1 |
Member#: 1130
Vehicle:2013 STI Hatch DGM |
AFC + 2.2l
Is there any improvement on the 2.2l with the adition of the apex unit "AFC".
I know it works on the 2.5l, But whats up with the 2.2?
05-25-2000, 11:26 PM | #2 |
SCIC
Moderator Member#: 85
SCIC
Got it on my 1997 Hot-wire MAFed 2.2L.
Works and can be helpful. Can't quote figures or numbers for you but what year do you have? Rich |
05-26-2000, 04:46 PM | #3 |
SCIC
SCIC
Interesting I thought our TB's were bored as big as possible stock? Tell us more. Also how much for the honed Intake manifold?
05-27-2000, 12:46 AM | #4 |
Member#: 1130
1995 with intake bored throttle body, honed intake manifold and custom exhaust. so she is definitely flowing.
05-27-2000, 10:09 AM | #5 |
Member#: 1130
Nope, TAD motorsports did it, and it wasn't a huge bore, but enough to see and notice. As for the extrude hone, I can't find the receipt and I am not sure. But it was definitely worth it. For the 2.2l, I don't have to squeeze the throttle as much to stay at speeds, climb hills, and gas mileage went up!!! I went through extrude hone in S.California. I live in the bay area, And it took three weeks. thats the only bad thing.
05-27-2000, 01:15 PM | #6 |
SCIC
SCIC
I'm In So. CA right now SLide and I find that interesting. Let me know if you find the recipt so I know the cost.
Rich |
05-28-2000, 09:58 PM | #7 |
Member#: 1130
I looked and can't find it. Give them a call. But back to my origional question... ? I need to know if its worth it and what about set-up. Are there diagrams for wire set up or is it easy. What about settings?
[This message has been edited by slide (edited May 28, 2000).] |
05-28-2000, 11:24 PM | #8 |
SCIC
SCIC
Slide I have all the connections that would work for your car. Setting it up will be easy and it is rather helpful. I am having more problems getting my ITC to work(I finally installed it after having it for 3 months) and the car wond turn over when the sensors are jumped through the ITC. I would say you will find some benefit in having it.
Rich |
WRX catback on 2.2l OBS catpipe...the weld broke :| Quick dia ?s | kaisersouse | Normally Aspirated Powertrain | 0 | 06-01-2010 08:20 AM |
2.5 injectors in a 2.2l SOHC OBS? cams for 2.2l? | kaisersouse | Normally Aspirated Powertrain | 3 | 04-02-2006 09:10 PM |
Will the Apexi Super AFC II work in my 97 impreza 2.2L? | Oftenwinter | Newbies & FAQs | 6 | 01-18-2006 10:43 PM |
Turbo Legacy project - 2.2L SOHC heads, EJ257 shortblock, WRX turbo, S-AFC | jey | Normally Aspirated with bolt-on Forced Induction Powertrain | 10 | 01-19-2005 05:46 PM |
anyone install S-AFC on 2.2l OBS??? | IMPREZAmike | Technical Forum Archive | 5 | 08-28-2000 03:09 AM |
