Old 04-12-2004, 03:24 PM   #1
EstebaN WRX
Member#: 48856
1995 Impreza WRX
Default problems with the gas meter readings
I have a 1995 Impreza and Ive been having some problems with the gas meter readings.
If the tank is filled full it lasts for about 200 km! and then, my fuel gauge suddenly
drops from full to empty; somehow, it seems to be affected.
Any ideas of what the problem could be? or how to fix it?
Thanks in advance!
EstebaN WRX is offline   Reply With Quote
Old 04-12-2004, 05:11 PM   #2
satrya
Member#: 5887
2002 GDAA (bugeye)
797 (blaze yellow)
Fwiw, I had a similar problem with my my1995 impreza many years ago. The readout would stay on the full side longer than usual and move to the empty side faster than usual. The fuel sender was replaced iirc.
If you have a factory service manual, you might want to check how to diagnose it. If not, you either adapt to it or have it repaired by a dealer.
satrya is offline   Reply With Quote
Old 04-12-2004, 05:41 PM   #3
EstebaN WRX
Member#: 48856
1995 Impreza WRX
The thing is, it`s very difficult to trust any factory service manual around here.
On the other hand, I`ve checked the whole fuel pump installation myself but I can`t seem to understand which part of the system measures the fuel flow. Any idea?
Old 04-13-2004, 10:03 AM   #4
skyhawk
Member#: 36255
04 WRB WRX
Drive 2 Work,Work 2 Drive
It shouldn't have anything to do with fuel flow.
It sounds like you have a sticky float inside the tank.
If your tank is designed like my 04 WRX you will have 2 floats. One on each side. You will need a service manual to make sure the resistance in the potentiometer is correct also.
skyhawk is offline   Reply With Quote
Old 09-11-2007, 10:16 PM   #5
tanayast
Member#: 158806
Interesting....
My fuel gage seems to drop about 1/8 after parking it overnight. I haven't got a chance to check the actual fuel consumption (just got the car a couple days ago). Oh, it's also a 95 Impreza (L AWD Auto).
tanayast is offline   Reply With Quote
Old 09-12-2007, 02:09 AM   #6
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
I agree with Skyhawk about a stuck float. My guess is one of the two is stuck in the full position. You may be able to remove the float and free it up. By checking the voltage at the senders when the tank is full and then again when half empty you should be able to figure out what reading isn't changing and remove it for service.
Problems With Rotated Turbo Maf Readings stretchedk7 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 02-24-2009 10:06 AM
Problem with EcuFlash & Enginuity reading maps differently! akira02rex Open Source Reflashes 3 03-19-2008 03:04 PM
Anyone else having problems with Chevron Gas? Tizzle North West Impreza Club Forum -- NWIC 53 06-27-2006 03:32 AM
Question/Problem with amp fuses. Please read. Andrew Car Audio, Video & Security 0 05-25-2001 10:55 PM
Problems with Pumping Gas KC Technical Forum Archive 32 07-01-2000 01:10 AM
