Go Back   NASIOC > NASIOC Subaru Models > Forester Forum
Old 04-12-2004, 04:29 PM   #1
DeClerq
Member#: 22404
06 Legacy 2.5i wgn
Default Does this look dumb?
Too much gap? There's about 6" of gap now compared to about 5 1/2" stock. I may look into suspension bits later on, but it's not a priority right now. These are the wheels I had on my RS before I traded it in, figured I might as well use them. I'll probably put snow tires on the stock wheels and use those in the winter.
DeClerq is offline   Reply With Quote
Old 04-12-2004, 04:34 PM   #2
Caddy Daddy
Member#: 11070
2004 SG9, Audi S8
Ducati ST2, BMW R100/7
your rs wheels match the offset for the FXT?
Caddy Daddy is offline   Reply With Quote
Old 04-12-2004, 04:47 PM   #3
DeClerq
Member#: 22404
06 Legacy 2.5i wgn
I have no idea...I supose I should of looked into that before I put them on
Anyway, I'm going to take it out for a spin and see if there's a noticable difference over stock.
Old 04-12-2004, 04:59 PM   #4
Bobshere
Member#: 49835
2004 Forester 2.5 XT
It doesn't appeal to me, but this is very subjective. I suggest you try:
See your FXT/custom height, colors, wheels
See what your FXT would look like in custom colors and different heights, with different wheels
http://www.modifymycar.com/home.html
You can play with different heights without having to do the costly mods first here. Personally I like mine not to low and not too high (too low doesn't look good to me and will detract from FXT SUV attributes; too high won't perform as well as lower will).
Cheers,
Bob
PS: Are you SURE it's just 1/2" ??? I sure looks higher than that!
Bobshere is offline   Reply With Quote
Old 04-12-2004, 05:10 PM   #5
Prod
RIP
Member#: 59328
1967 M35A2
duh, winning
I would either get bigger wheels or bigger tires. That gap is definitely not eye candy.
Prod is offline   Reply With Quote
Old 04-12-2004, 07:40 PM   #6
DeClerq
Member#: 22404
06 Legacy 2.5i wgn
Yeah, the more I look at it, the less I like it. I might just put the stock ones back on for now and maybe get some different (bigger) tires for the Prodrives. I just didn't want to see them go to waste since I paid a lot of money for them.
Old 04-12-2004, 07:52 PM   #7
lakepop
Member#: 3851
2007 Outback Ltd.
Champagne Gold
Unhappy
Wheels look good.......they just don't look good on your machine.
OK...just my .02
lakepop is offline   Reply With Quote
Old 04-12-2004, 07:56 PM   #8
randolph-rs
Member#: 3371
2004 Forester XT
Java Black
those Prodrives will more than likely rub with bigger tires on them, at least that is how it turned out for one other Forester owner I had read about. Those are P7's right? If so you may be in for some headaches. Those wheel wells are quite empty and the best solution of course are bigger tires or a drop. Just take your time so you can get it right and the way you want it.
randolph-rs is offline   Reply With Quote
Old 04-12-2004, 08:02 PM   #9
looney
Member#: 44464
2004 FXT-MT
w/hitch for my c-crib
pictures do not tell every story... or am i missing something here.
please start with wheel diameter, width and tire size...
maybe them you can help me and you at the correct set up...
I have BBS RK 17x7x48mm offset and 225X45X17's.. i know i running about 4% slower so what's up with you..
Peaty...any help...
looney is offline   Reply With Quote
Old 04-12-2004, 08:04 PM   #10
Caddy Daddy
Member#: 11070
2004 SG9, Audi S8
bingo
at any rate i personally find it looking kind of good
Old 04-12-2004, 08:48 PM   #11
DeClerq
Member#: 22404
06 Legacy 2.5i wgn
Peaty...any help...
They are P7's. As stated earlier I'm not sure what the offset is.
The tire size is 225/45/17.
Is yours lowered? If so, any pictures? Since we have the same tire size, might be nice to see how others look w/a similar set up.
As far as what's up with me, I just don't like how much gap I created by swapping out the tires, I'm not concerned about the speedo being off or anything like that, it's all about aesthetics
Old 04-12-2004, 09:46 PM   #12
lucien2
Member#: 1519
1998 Volvo V70R
P7s are +53 offset and are going to rub when you try to go to the correct tire size, I'm afraid.
too much gap for me there anyways.
lucien2 is offline   Reply With Quote
Old 04-13-2004, 10:13 AM   #13
SASniper
Member#: 57913
Is that 35% tint on the windows? Does anyone have pics of 35% on a black 04 forester? I'm interested to see how dark it looks (35% legal max here)
SASniper is offline   Reply With Quote
Old 04-13-2004, 11:38 AM   #14
lucien2
Member#: 1519
1998 Volvo V70R
SAS- search for pics of Peaty's forester; he's got 35% on the back door windows and the rear hatch.
Old 04-13-2004, 06:13 PM   #15
DeClerq
Member#: 22404
06 Legacy 2.5i wgn
Actually it's not tinted at all, it's just a cloudy day.
Old 04-14-2004, 11:42 AM   #16
Erekose
Member#: 59129
2004 Forester
Formerly Tom Bombadil
I wouldn't say it looks bad, just different than what you are used to.
I am in a similar dilema.
With 225/50-17 being very hard to get I am looking at 215/50-17.
I posted on a Japanese message board and one of the readers suggested both would work fine.
In Japan the 215/50-17 is actually more common on both the SF and SG.
Erekose is offline   Reply With Quote
How does this look? speedracer888 General Community 3 03-04-2002 12:24 PM
How does this look? IKE Canada Region Forum 2 11-07-2001 12:17 PM
WRX wheel offset w/body kit, does this look funny to u? JayGold Newbies & FAQs 1 06-13-2001 08:46 PM
Does this look like a EGT gauge ?? Jimmy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 06-08-2001 01:55 PM
How does this look??? (Pix) BrysImpreza Interior & Exterior Modification 32 05-10-2001 09:07 AM
