Old 04-12-2004, 05:19 PM   #1
WRXonmind
Member#: 28630
02 WRX
Default HELP.. car won't stay running
I just installed a PE 1818, fuel pump, modded injectors, and perrin fuel rails on my car last week. I set the injectors to 800 on the utec and pulled some fuel and it seemed to idle alright. I've put on about 70 miles it now test driving it. I've have a dyno tune the this weekend and it's a 2 hour drive so I wanted to make sure it was running alright. So i'm coming back from work today and I come up to a stop sign, an it just dies. I restart it and it stays running for about 10 seconds and soon as I give it gas it dies again. I popped the hood and check all the fuel lines, the maf sensor, and boost lines but everything was still hooked up. I try it a few more times and get the same results. It's over at friend's house now, i'm going to start taking it apart tomorrow to see if I can find the problem. Anyone have a clue to what it can be? My fuel pump, my injectors not seated correctly, or what??
WRXonmind is offline   Reply With Quote
Old 04-12-2004, 05:22 PM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
Did you go through the usual stuff? Check fuses, hoses, etc.? Do you hear the pump prime when you turn the key to ON? If your injectors weren't seated correctly, you would smell the gas pretty easily and would be able to see it spraying out under the hood.
Calvin
cnk is offline   Reply With Quote
Old 04-12-2004, 05:27 PM   #3
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
Its not likely that all four injectors aren't firing. I'd check the fuel pump first. No CEL, right?
Pete
eastcoastbumps is offline   Reply With Quote
Old 04-12-2004, 05:40 PM   #4
WRXonmind
Member#: 28630
02 WRX
Haven't checked fuses yet, checked all hoses. It would start fine but after a few seconds the rpm would just start dropping so I would give it gas and it would die compleltely. I only got to do try a few times before the battery was out of juice. Alright so injectors are seated fine cause there is no fuel spraying. I don't remember if I heard the pump priming or not. I don't get why it drove fine for 70 or so miles and now nothing. There car is about a half hour away, so i'll try it again tonight or tomorrow morning.
MY97 Impreza 2.2L -- Cleaned MAF, now car won't stay running Nihilator Normally Aspirated Powertrain 29 09-06-2015 04:12 PM
Car won't stay running! HELP!!! Zefy Normally Aspirated Powertrain 1 01-17-2010 09:56 PM
Car won't stay running TylerC21 Service & Maintenance 5 08-21-2006 08:42 PM
Hydra: Car won't stay running after install 03scubaru Other Engine Management 11 07-24-2006 04:38 PM
My car won't stay running.....Utec Pacobeagle Engine Management & Tuning 5 09-18-2005 07:33 AM
