05-26-2000, 02:59 PM | #1 |
Member#: 216
Placing EGT probe behind turbo
Is it ok to place my EGT probe behind the turbo (just because it will be easier to do so)? Will I still be able to get reliable temperature readings that I can use for tuning? I know the readings will be about 500F lower. Does anybody have there EGT probe mounted behind the turbo, and what kind of EGTs are you running?
05-26-2000, 03:26 PM | #2 |
Member#: 270
Tim, Sorry mate but it would be self defeating putting the EGT after the turbo. The turbo is powered by the drop in enthalpy of the exhaust gas which comes more from the heat than the pressure drop across the turbine.
quote:"I know the readings will be about 500F lower." To get an accurate temperature drop across the turbine, you'd need the isentropic efficiency of the turbine yet that value changes depending on its RPMs. Basically, the whole point of an EGT gauge is not to be guessing cylinder temps. Just put the probe 2" from the head in one of the headers. After all the work involved installing a turbo, why skimp on effort here. Andy - RalliSpec, ltd. |
05-26-2000, 03:46 PM | #3 |
Member#: 6
Vehicle:2013 BMW M3 Coupe Interlagos Blue |
Andy ~~ Say wha'? Good to see you guys have a couple of minutes to stray online again.
Tim ~~ Andy is right, why go through all the effort of turbocharging and then do a less than sufficient job installing the EGT probe? I've got some pictures on my site of the install RalliSpec did on my car. Clean and effective. SteveS http://www.lagging.com/ |
05-26-2000, 04:01 PM | #4 |
Member#: 67
SCIC
Vehicle:1999 Outlasting the competition. |
tim
bring it by and i'll tig up the bung. and put it where it needs to go no problem [email protected] |
05-26-2000, 04:22 PM | #5 |
Member#: 216
kartboy rules
05-27-2000, 03:56 AM | #6 |
Member#: 296
Hi guys..
In the ideal world you should run EGT probles by the ports of each cylinder and monitor each one. But this isnt really practicle for most road cars, the second best is in the headers, before the turbo. As a last resort after the turbo. I have seen temp differences (drop) of about 100 degrees across the turbo (average)... Lagging the headers/HPCing will make a difference too. Mine is mounted in the headers.. but I have aftermarket equal length, HPC'ed and fully lagged ones J. [This message has been edited by Jay_UK (edited May 27, 2000).] |
05-27-2000, 08:36 AM | #7 |
Member#: 626
Vehicle:2001 Impreza 2.5 RS Black Diamond Pearl |
Just wondering what kind of headers are you turbo guys using?
05-27-2000, 06:42 PM | #8 |
Guest
Member#:
Put it after the #4 cyl(drivers/rear) header. Most subbies tend to fry #4 first.
Mark with EGT after #4 |
EGT Probe in Turbo cars | maxiav | Normally Aspirated with bolt-on Forced Induction Powertrain | 14 | 05-14-2004 01:30 PM |
any consensus on best place to hook up EGT probe? | jmott | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 23 | 12-27-2001 01:44 PM |
Best place to mount EGT probe ? | Eric SS | Normally Aspirated with bolt-on Forced Induction Powertrain | 6 | 11-25-2001 06:34 PM |
Places to get EGT probe installed? | redobs | New England Impreza Club Forum -- NESIC | 13 | 08-14-2001 11:26 AM |
WRX/best place for egt probe? | Darryl | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 28 | 05-05-2001 03:49 AM |
