Old 04-12-2004, 06:09 PM   #1
wildbill99
Member#: 58493
2000 impreza 2.5 rs
silverthorn
Default turbo plus supercharger
i hope someone can answer my question. now this isnt just concerning subarus. alright let me see if i have this right. the main plus side to a supercharger (roots type) is that it produces power from idle and doesnt get as hot as a turbo. the negative is that it tapors off at the top end unless you install a bigger pulley but then you need more initial horsepower. the pluses of a turbo is that you can control how much boost you make easier but it only works from the mid to high range and can get extremly hot. now here is my question. can you install a high boost turbo plum it through a intercooler and then to the intake of a roots supercharger. in my thinking the suction of the air through the supercharger should make the vanes of the turbo start moving faster while at the same time creating its own boost and by the time the supercharger is tapporing off the turbo should be spooling really good and creating its own boost. i have never seen this done so im assuming there is a reason why and i just want to know what it is and nobody i know can give me a good answer. lets just say the engine we are doing this bullet proof and there is no money or space restraints why cant this be done. thanks
wildbill99 is offline   Reply With Quote
Old 04-12-2004, 06:44 PM   #2
phattyduck
Member#: 32955
'03 WRX Wagon
'89 3S-GTE Alltrac Camry
Its called twincharging... its been done before on some cars. Try searching the web.
Your theories on how it works is a bit off, but the reasons you want to do it (low end torque and high end power) are why its been tried in the past.
-Charlie
phattyduck is offline   Reply With Quote
Old 04-12-2004, 07:06 PM   #3
Unsung Boxer
Member#: 37196
this is also similiar as to why they use sequential turbo setups on some cars.
Try doing a search for the Meguire's Integra Type R. It uses a Supercharger and a turbo charger.
-Jake
Unsung Boxer is offline   Reply With Quote
Old 04-12-2004, 09:19 PM   #4
powerlabs
Member#: 45790
2006 Corvette C6 Z51
SUPERCHARGED
This might be a little off topic, but the two diesel engines that ran the backup power generators at the Nuclear Power Plant I worked on as an intern this fall had a supercharger running on the intake and a turbo on the exhaust. The supercharger got the (16 pistons, 6000HP) diesels started and then at something like 3 - 5PSI a wastegate opened and they switched over to a massive turbo. The idea there was to have the engines up and running at 100% power within 30 seconds from a cold start. Doubt the SC/Turbo combo would be very practical on a car though; if nothing else, it would take up tons of space and cost a LOT...
powerlabs is offline   Reply With Quote
Old 04-13-2004, 06:23 PM   #5
MeshmeZ
Member#: 58908
'07 STI
This is probably the most realistic way to get low and high end. you put both a tiny and a big turbo on the same exhaust line so that the tiny one spools fast to add boost quickly at low rpm and then the large turbo catches up later on to give the boost at higher rpm.
As for the supercharger/turbo combo it seems like it would be a bit tough to do. having already compressed air go into the superchargers intake seems like it would cause problems.
what POWERLABS is talking about sounds like the supercharger is effectivly disconnected when the turbo charger kicks in. as he said, i think this would be a bit impractical on a car
MeshmeZ is offline   Reply With Quote
Old 04-13-2004, 10:25 PM   #6
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
Lightbulb hhmm
cant say I havnt thought about it It sounds like a good idea...but there are always ins and outs to everything. and it seems like it would be more work than it would be worth....for the added money of the supercharger, you could effectivly tune nitrous into the mixute, helping spool the turbo much faster.
I know someone posted a while ago about tractor racing and nitrous. These guys inject nitrous directly into the exhaust housing of the turbo, in turn creating a SHIATLOAD of INSTANT boost and a torque curve flatter then the state of kansas!
IllNastyImpreza is offline   Reply With Quote
Old 04-13-2004, 10:31 PM   #7
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
ehh... its not cost effective. You can have a twin scroll give you the low, full spool by 2.5-3k, and high end. If you just want low you have have a high C/R with a small turbo and have huge low end tq with a little power up top. All for a lot cheeper....
Old 04-14-2004, 10:20 AM   #8
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I read in SCC where there was a twin charger MR2 (AW11). they have also used this on diesel inboard motors. They actually had the supercharger controlled by a AC clutch
Old 04-14-2004, 12:17 PM   #9
Darshu
Member#: 1676
98RS w/ EJ257/Dom
2014 Tesla Model S P85
http://www.supercars.net/garages/PeP/76v2.html
Lancia Delta S4 The days of Grp. B rally were nuts.
Darshu is offline   Reply With Quote
Old 04-14-2004, 04:07 PM   #10
ataac_flat04
Member#: 19050
2005 Black STi
Happily rowing 6 gears
Detroit Diesels are made that way, turbo blowing boost into a supercharger. Easy way to get higher pressure ratios without expensive single components. I.e. it's cheaper to have two compounded turbos making 50 psi than it is to get one turbo to make 50psi boost. -Chuck
ataac_flat04 is offline   Reply With Quote
Old 04-15-2004, 10:32 PM   #11
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
If you want the best of both worlds and are adventerous enough (which it sounds like you are) fit a lysholm blower to your car, higher efficiency than a turbo even at very high flow rates with better response characteristics and low end than a roots blower. Audi used to run these things back in the 40's and 50's on their le-mans cars around 40-50lbs of boost and set a few oval track records that weren't broken until the 80's, very cool stuff, I would scrap my turbo hardware in a heartbeat if someone could come up with a better way to fit one than the old rimmer kits. You don't see them too much because they are banned in just about every form of motorsports out there... including top fuel.
www.whipplesuperchargers.com
sells standalone blowers and various pulleys.... there are a few other companies out there that sell the blowers but whipple makes the most bulletproof.
no-coast-punk is offline   Reply With Quote
Old 04-18-2004, 12:50 AM   #12
ImprezaRSX
Member#: 10955
07, 06,01,93 I have
4 domtuned subys
Powerlabs, if you're talking about KAPL's Kesselring site you're almost correct about the way the turbo is a supercharger. It's gear driven and the only thing that adjusts whether or not it's a turbo or super is exhaust pressure. The gear driven feature helps to scavenge the cylinders on the exhaust stroke when it's starting and pressurize the cylinders on the intake stroke.
oh, and it's 10 seconds to full output.
and they are 2400HP.
This works great on an engine that only goes from 0 to 900 rpm. However, trying to get a system like this to work on a high reving engine is almost impossible.
Notice I said almost. I've been working on this for about a year now.
ImprezaRSX is offline   Reply With Quote
Old 04-28-2004, 11:30 AM   #13
powerlabs
Member#: 45790
SUPERCHARGED
ImprezaRSX: I'm not familiar with the site you mentioned. My description was regarding the two backup diesel generators located inside the turbine building of Vermont Yankee Nuclear Power Plant (now Entergy Nuclear Vermont Yankee (ENVY)), where I worked last fall as a co-op. There are two actual separate boost systems on those diesels; a turbo on the back and a supercharger up front. The supercharger spins at all times but a blow off valve bleeds it after a certain RPM is reached.
The start up time to full output power is specified as 30s max (any more and the generator is deemed faulty and in need of repairs). You could be right about the HP figure though, I remember it being HUGE but there were several numbers (max, mean, median, max for 1 hour, 3 hours, 24 hours, etc) on the thing. I think 6000 was the absolute tops, and it might have been Kilowatts, not HP..
Now for a REALLY powerful motor, the 3 stage steam turbine that ran the main generator had a (1ft dia almost) shaft that was transmitting about 780thousand HP Not much torque though, I remember those turbines had to be brought up to speed at only a couple rpm/sec.
possible to twin-turbo or supercharge a WRX? mborg Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 06-15-2001 01:55 PM
Turbo or Supercharger? Pros&Cons?... bryant aka sky Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 06-12-2001 06:44 AM
Canadian Turbo or supercharger whistlertrekker Legacy Forum 5 04-04-2001 02:14 PM
Turbo or supercharged? Dr. Spud Funk Normally Aspirated Powertrain 2 03-01-2001 10:39 PM
What is more reliable, turbo or supercharger?? WRXkid General Forum Archive 7 07-21-2000 09:13 AM
