Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 04-04-2000, 02:22 PM   #1
josh
Guest
Member#:
Question Getting car corner weighted-besides SPD's align #'s, any suggestions???
I am having my car corner weighted and alighned tomorrow, and was curious if anyone had any suggestions for alignment specs besides Mike's at SPD. I used his settings before, and like them. I am just curious if anyone had better luck with any other settings.
Also any hints or must do's for pre corner balance prep is appreciated.
keep in mind i have GAB coil overs, and Toyo Proxis T-1 Plus's. I need new tires soon, but that doesn't have anything to do with the balancing.
josh
Old 04-04-2000, 02:26 PM   #2
Wintrode
Member#: 180
Post
Try shooting an e-mail to Rallispec, they set Tony's car up with a serious alignment. Plus, Dave has probably aligned a lot more imprezas than most people out there.
Wintrode is offline
Old 04-04-2000, 07:46 PM   #3
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
SPD's alignment settings are for "fast road", like much of Mike's philosophy. Whether you are autocrossing or roadracing, you're going to want more negative camber. A LOT more, in my humble opinion. I'd consider at least -2 degrees in the front for a serious autocross machine, and -3 or more for roadracing depending on tire temps.
ColinL is offline
Old 04-04-2000, 08:12 PM   #4
Joe Hogan
Member#: 699
2002 golf TDI
Post
You might try 1 or 2mm toe-in (1/16" or 1/8 total toe-in) at the rear and zero toe at the front.
The RS is a front steer setup (tie rods ahead of the axle center line) so I don't think toe changes much with speed and gains toe-out with compression.
Zero toe allows for "active" steering but great turn-in. By "active" ... the car will hunt over uneven pavement, follow the crown of the road and dart when braking.
If you toe out in the front these traits get worse to an annoying level plus tire wear becomes a problem.
In the rear if you toe out the car becomes unstable under hard braking and "spooky" in hard turns. You will never really feel what will upset the rear and break it loose.
I tried toe out in the rear for a few AX events and spun the car regularly.
It is my understanding the RS has some passive rear steer which changes the rear toe when heavily loaded. This helps the rear around in a turn.
Basically I think toe out in the rear makes the car too unpredictable.
Also do not lower the car too much. The suspension geometry is optimal at about 1 to 1.5" lower than stock. Apparently the rear is more tolerant to lowering than the front.
Excessive lowering screws up the roll centers.
FWIW
Joe Hogan
[This message has been edited by Joe Hogan (edited April 04, 2000).]
Joe Hogan is offline
Old 04-04-2000, 08:43 PM   #5
RalliSpec
Member#: 39
98 Prodrive WRC
Post
Alignment settings are always a compromise so you need to determine exactly what is most important to you...
maximum cornering
maximum tire wear
or straightline stability
For a still somewhat reasonable street setup that isn't too bad at the autox we set the car as follows:
1.25 degrees negative front camber
0" front toe out
3/32" rear toe out
For a more aggressive setup that gets a little twitchy on the street we use:
1.5 degrees (or whatever the maximum the front eccentric bolt will allow...just keep it dead even side to side)
1/16" front toe out
3/16" rear toe out
Toe out sacrifices straight line stability but improves turn-in. Rear toe out also provides a small amount of additional oversteer tendency.
Proper corner weighting will also pay off big and we just invested in top of the line corner weight setup.
RalliSpec is offline
Old 04-05-2000, 06:16 AM   #6
boxerman
Member#: 644
Post
When you corner weight the car, have it set up for an event. Remove jack and cr*p in trunk.
Corner weight with 1/2 tank of gas and driver or equivalent weight in drivers seat.
Tim
boxerman is offline
Old 04-05-2000, 07:19 AM   #7
Tony
Member#: 287
2005 9-2X Aero
Desert Silver
Thumbs up
The alignment settings Rallispec set my car to was:
Max. neg. camber in the front = 1.4-1.5 degrees
3/32" toe out front
1/8" toe out rear
I asked them for the all-out-autox-screw-the-twitchyness-and-tire-wear kinda alignment. I'm planning on alteast 30 autoxes this year, I can live with the setup on the street. Actually it isn't that bad, hunts ruts in the road like crazy but OK as long as you don't try anything dumb in the rain, etc. The tires are gonna wear out from autox anyway so I'm not worried about that aspect. The alignment alone made more of a difference than the 20mm bar did alone. YMMV.
Tony
Tony is offline
Old 04-05-2000, 02:47 PM   #8
josh
Guest
Member#:
Thumbs up
Thanks guys! I will look these over and cme to a decision when I get it balanced. I am thinking of going pretty aggressive. Hell, why not, the car is already stiff as hell, and I am using my racing bucket to commute in(yeah, my kidneys have gotten alot stronger the past month!). I think I can handle the twitchyness.
Thakns again guys, and more advice on this is apprecialted.
josh
Old 04-05-2000, 02:53 PM   #9
Nat
Member#: 759
2004 WRX
2000 SV650
Post
Don't want to clutter up the thread with a question, but can a car be driven with coilovers only being setup by ride height? I want to get a set of Teins in a month or so but don't know a shop around the area. I know this would affect handling when the car is driven hard, but as long as I set the car to stock ride height at all corners and get an alignment will I screw anything up but maybe tires?
Nat is offline
Old 04-05-2000, 02:59 PM   #10
josh
Guest
Member#:
Post
Nat.
I have had my coilovers in for about 3 months set only by ride height. Balancing is not required, but it is nice to have done. After I get it done I am going to measure on a template all the corner heights. Then i can play with different heights by making sure each corner is raised/lowered equal amounts. Keep in mind tho, everytime you change ride height, you screw up the alignment settings.
josh
Old 04-05-2000, 03:03 PM   #11
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Talking
Technically that's true but do the math and you'll see that for small height changes the difference is hardly significant. And if the changes are the same for L&R sides, then the net effect is even less significant.
ColinL is offline
Old 04-05-2000, 03:09 PM   #12
josh
Guest
Member#:
Post
yes ColinL,
small height changes do not, in the big picture, change that much. BUT lowering the car TOO much does. I lowered my car pretty signigigantly(enough to scrape almost ALL driveways), and noticed the handling sucked. I raised it up a cm and BLAMO! it was like a new car. So, yes Colin you are right about small, finite changes. Just be careful with the big, gross changes.
josh
PS our cars handle REALLY well the closer they are to stock height.
Old 04-05-2000, 03:20 PM   #13
Tim Prudence
Member#: 216
Post
If it's not too much trouble could you let us all know what height you settled on front and rear (and where you took the measurements from).
Thanks in advance,
Tim
Tim Prudence is offline
Old 07-08-2000, 05:50 AM   #14
cj917
Member#: 627
MY96 outback wagon
Question
joe,
what's your reason for toe-in in the rear? (besides what most other people are doing: toe-out in either front or rear to sacrifice the straightline stability for better turn-in)
for those who have tried, what difference is there comparing front and rear toe-out when you leave the other one at zero? and why does Rallispec recommend a slightly more toe-out in the rear than the front?
thanx in advance!
cj917 is offline
Old 07-08-2000, 02:07 PM   #15
RalliSpec
Member#: 39
98 Prodrive WRC
Post
Excessive rear toe will cause unpredictable oversteer characteristics, particularly under braking...very difficult to control properly and definitely not recommended.
Excessive front toe will cause straight line instability...car will be darty over bumps. Acceptable up to a point.
With that said...we generally set up the rear toe with about 3/32" total toe out. This is still within factory specs and with 0" toe up front is stable and predictable under all conditions...we have found this provides good nuetral handling and reasonable turn in. For more aggressive setups we have played around with various changes to both front and rear toe and have found that increasing rear toe beyond the factory range is not advisable (sorry about the confusion...the previous post was written by one of the other RalliSpec members and not by myself (Dave). I perform all of the alignments that come through the door and since we have tried various setups there is some confusion as to the recommended setup at this point. For more aggressive setups we generally go with more front toe-out up to about 1/4" total for autox. Beyond that and the additional drag and tire wear become unacceptable. Also keep in mind that what we are talking about is low speed tight corner handling improvements as would be seen in autox or city driving. High speeds require a more stable platform and so toe nuetral or slight toe-in is generally more desirable. And of course, like most things it is really a matter of taste and driving style. Like any tuning there are compromises to be made.
any suggestions for a place for corner balancing/alignment? jonnylin1 North West Impreza Club Forum -- NWIC 3 05-21-2010 05:29 PM
good free weight set for home use? any suggestions? STiTuner Off-Topic 7 04-08-2004 11:07 PM
corner-weight & alignment ? spidey02wrx Tri-State Area Forum 5 03-18-2003 06:28 PM
Alignment specs and corner weight specs hokiewrx Brakes, Steering & Suspension 8 03-14-2003 07:29 AM
corner weighting vs alignment tmr Technical Forum Archive 2 10-10-2000 07:32 AM
