Old 04-12-2004, 09:22 PM   #1
hossak8
Member#: 20503
'98 2.5RS
'05 WRX
Default What caused p0340?
'98 2.5 RS........Started car, drove 3 miles running fine, stopped car for 10 minutes. Tried to restart, engine cranked, but would not turn over for first 2 tries (approx. 10 cranks per try). On third try it fired up and ran fine. Checked code and showed P0340.....camshaft position sensor A, bank 1 circuit malfunction. Is this a bad sensor, or circuit? Where are these located? What could the problem be? Thanks
hossak8 is offline   Reply With Quote
Old 04-13-2004, 07:08 PM   #2
hossak8
Member#: 20503
'98 2.5RS
'05 WRX
Started car today. No CEL, but not firing on all cylinders; I'm suprised this did not give me a misfire CEL. Looked under hood, and coil pack was arcing from the base of one of the terminals, along the housing, and down to the mounting plate. Obviously I'll replace the coil, but does this have anything to do with the P0340. I'm wondering if the coil arcing could have been arcing to the camshaft position sensor last night and interfering with its signal, as this would give me a "no-start" condition. Quite a relief to see that arc......simple solution.......hopefully.
Old 04-13-2004, 11:54 PM   #3
ttboy19
Member#: 38043
2004 impreza rs4sale
'10 Legacy 2.5GT
Ask your local suby mechanic. Make sure you use the phrase, "my friend's too embarrased to ask..."
ttboy19 is offline   Reply With Quote
Rear tires going bad? What caused it? What are some good tires? elitescouter Newbies & FAQs 46 05-02-2007 11:14 AM
Help! What causes the cat. converter to break? slamck Normally Aspirated Powertrain 11 01-23-2002 02:55 AM
What causes exaust "POP!" trojan9x Normally Aspirated Powertrain 18 06-06-2001 05:11 AM
('93-'01) Turbo kit and CE light issues - what causes it and how to prevent it? Jessie James Impreza Forum 4 06-05-2001 09:12 AM
what causes fire out of the exhaust? wop Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 05-02-2001 06:11 PM
