#1 |
Member#: 50410
Vehicle:1993 Festiva Blue |
Hey all. I just bought a new VF22, and was wondering about it's placement relative to things.
I have heard that if a VF22 was put in in any other direction aside from how it's supposed to on a subaru, that it will have problems feeding/draining oil. Is that true? I would also like to know about clocking. Will making the compressor and exhaust side face the same direction screw up any oil/cooling/balance settings? Thank you in advance for any replies. Joel
#2 |
Member#: 37196
I too, am considiering direct replacments for the WRX turbos, please give up your info!
-Jake |
#3 |
Member#: 12469
Vehicle:2000 2.5 RS BRP |
Hey, I just bought a new VF22 too! Hopefully I'll have it by Thursday. I've never heard of any problems that you describe, but if anyone has info, it'd be great to have it out. I asked Larry Ganz about clocking the VF22 and he said that there isn't any problem with doing it.
#4 |
Member#: 50410
Oh. Cool. Then I will do just that.
Just so I know what's going on, all clocking consists of is unscrewing the clamp from the center housing to the turbine housing, and rotating right? Thanks, Joel |
#5 |
Member#: 12469
Don't know, I don't have the turbo yet, and haven't had that close of a look. When I clocked the TD04, I removed the snap ring under the compressor housing and removed the compressor housing. Then I had to cut a little notch in the center section to accommodate the key on the compressor housing after rotating it to where I wanted it.
| Thread Tools | |
| Display Modes | |
| is the vf22 closer to a 16 or 18 g turbo | moorebl | Factory 2.0L Turbo Powertrain | 18 | 05-09-2005 05:26 PM |
| how much more hp does the vf22 put out over the vf23 | godfather2112 | Factory 2.0L Turbo Powertrain | 3 | 02-09-2005 07:17 AM |
| Durability on the vf22??? How many miles? | Davenow | Factory 2.0L Turbo Powertrain | 4 | 02-25-2004 08:51 PM |
| Man the vf22 is sooo laggy (not- mini review) | Davenow | Factory 2.0L Turbo Powertrain | 23 | 09-17-2003 02:10 PM |
| Opinions on the VF22???? | BLUETURBOWRX | Factory 2.0L Turbo Powertrain | 0 | 11-02-2002 07:22 PM |
