Old 04-13-2004, 02:56 PM   #1
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
Default 3 Inch IC piping too big?
I'm putting on my front mount and I have 2.5 inches from the turbo to the IC and then 3 inch from the IC to the TB...
Is this too big ? what you guys think?
HOK is offline   Reply With Quote
Old 04-13-2004, 03:15 PM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Personally, I think it's too big. I would think that since the charge air was just cooled and made more dense, it's velocity would be even less and create more lag. There is a possibility, though, that the larger diameter out piping of the IC will cause the air to flow through it more smoothly/slowly and provide better cooling, though.
Old 04-13-2004, 03:40 PM   #3
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
id probably keep it the same throughout it, but i dont kno wmuch bout flow
Old 04-14-2004, 12:49 AM   #4
Unsung Boxer
Member#: 37196
good luck plumbing 3" piping... its fricken huge and wont likely fit through there.
-Jake
Unsung Boxer is offline   Reply With Quote
Old 04-14-2004, 01:07 AM   #5
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
already did... hehehe
But I'm still afraid it won't spool...
Old 04-14-2004, 02:33 AM   #6
Kostamojen
Member#: 2272
2016 Commodore SS
Heron White
Check what the other FMIC's are running for WRX's and such, they tend to run closer to 2"-2.25", not any 3" piping. That will have major lag.
Old 04-14-2004, 03:12 AM   #7
kaos200
Member#: 2692
id say on a setup making a good amount of power, 2.25 into the IC, 2.5 out (at most 2.75)
I need to upgrade
kaos200 is offline   Reply With Quote
Old 04-14-2004, 12:03 PM   #8
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
mmm I do know that most other subarus have 2.25 .5 inch piping, but has anyone tried 3 inch? Well we are half done anyways... but then it snows... can you beleive this... Mid april and 2 days ago it was 20 C and now its snowing
the drag track was going to open this friday... i guess not now...
Any fluid / flow dynamic gurus out there? One of the reasons I did this was the size of the TB is very close to 3 inch, 73 mm?? No restriction
Old 04-15-2004, 07:48 PM   #9
Compressed
Member#: 12271
2012 4Runner TE
KDSS!
3" seems a bit big. I know that most of the DSM guys with very hardcore setups are running 2.5" piping.
I would think that the place to have the 3" piping would be from the turbo to intercooler as the air is way hotter then and therefore displacing a greater volume. Then do like 2.75 or 2.5" piping to the TB.
Sounds like you have it mostly done though, so do some testing and see how it is. Do you have any data for smaller piping setups?
Compressed is offline   Reply With Quote
Old 04-15-2004, 11:20 PM   #10
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
3" is way too big, you will probably be able to flow ALOT of air (I sure hope you are shooting for at least 20lbs of boost) but will probably be down on quite a bit of torque due to the total lack of any real flow velocity.... it should do OK if you have no problems with a super laggy drag racer but you should find a way to step down a bit.... using the larger piping at the turbo outlet would have been much better. I wish I could give you some specific numbers but gas flow involves some really really scary math... I quit my desire to be a mechanical engineer once I hit that stuff.
*edit*
if you want to run any numbers yourself here is where you can get the info
http://www.lmnoeng.com/Flow/bernoulli.htm
but remember, your total flow area will go up with a square of diameter, but your flow velocity will drop at close to that same square rate, just remember, people much smarter than I are building supras in quad digit horsepower and torque figures using 3" charge piping.... so it's pretty overkill
no-coast-punk is offline   Reply With Quote
Old 04-16-2004, 12:09 AM   #11
SubaFastR
Member#: 5786
Works fine for my setup. No lag and lots of cool air.
SubaFastR is offline   Reply With Quote
Old 04-16-2004, 12:22 AM   #12
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
Yes yes.. i have succumb to the losing too much velocity.... theory....
That link is pretty good... what happened was as i sat there looking at the piping I figured that if a Rally car can pump out 300 + with a tiny tiny 1.5 inch restrictor or whatever I should be able to do 300whp with 2.5 inches heh... I believe that the 3 inches won't make THAT big a difference between 2.5 I would say... i will be making a final decision this weekend when we are building the car...
But err.. SUbafastR you have 3 inch Intercooler piping???!!?
I was debating that with that large a IC piping i need a 2.5 or 2.25 uppipe... any pics?
Old 04-16-2004, 01:16 AM   #13
no-coast-punk
Member#: 49087
Turbo restrictors sit before the turbo inlet so the turbo is sucking through the restrictor, this gives the air stream a TON of velocity which is how they are able to pull 500+ lbs of torque out of a 2 liter motor... but the torque peak is at like 3000 RPM's and the motor totally chokes out above anything like 4500. The key to developing power is to maintain a certain pressure (flow velocity and flow area) within your intake plenum (technically your intake piping is part of the plenum) too much pressure and you will see rally car like torque curves, too little and you will see some crazy top end power without much torque (such as your typical honda motor). This is why just about every company out there has played around with variable geometry plenums to keep that pressure in an ideal range, problem is you either have to make such a system huge, or restrictive with lots of turbulence. I dunno, it's late and I'm tired and rambling alot, just keep in mind that your intake assembly can greatly affect how your motor behaves, it depends what your goals are with the car, if you really are shooting for nothing but a straight line creature.... piping that size might not be all that bad, as long as you do what others have said and use larger piping as close to the turbo as possible to take advantage of the hot air trying to move faster. sorry if this last post didn't make much sense
Old 04-20-2004, 02:58 PM   #14
SubaFastR
Member#: 5786
The intercooler's inlet and outlet where 3", so I figured I'd just keep it that size on the exit.
Old 04-20-2004, 04:39 PM   #15
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
wow that is the same way I was going to do my piping!!! how is it working?
Thanks, Micah
Old 04-20-2004, 04:48 PM   #16
SubaFastR
Member#: 5786
Well, I make more power than the top mount and there is no extra lag at all!
Old 04-20-2004, 04:54 PM   #17
Homemade WRX
Member#: 33782
96 bastard child
is that a TD04 turbo?...how hard/easy was it to spin it...any drilling needed to re-mount the wastegate?
Thanks, Micah
Old 04-20-2004, 06:13 PM   #18
kaos200
Member#: 2692
I guess copying my piping route worked out for ya?
Old 04-20-2004, 08:53 PM   #19
SubaFastR
Member#: 5786
What are you smoking monkey boy? Your piping looks nothing like mine. Lay off the bananas.
Old 04-20-2004, 08:55 PM   #20
kaos200
Member#: 2692
thats cute, remember, you had your piping routed exactly like mine?
but thats cool, must be nice to go full throttle all day and not exceed the speed limit
edit: cus Im not THAT mean
lol
Old 04-20-2004, 09:00 PM   #21
SubaFastR
Member#: 5786
Thanks, Micah
It's actually the VF39. It was really easy to clock, but it is not the same story with a stock WRX turbo. I did drill one hole in the wastegate mounting plate.
Old 04-20-2004, 09:04 PM   #22
SubaFastR
Member#: 5786
lol
Your intercooler is half the size of mine and has it's pipes routed to the middle of the core while mine are at the top. You have your turbo in a completely different spot. So, having the pipes go beside the radiator is copying? Whatever... you bought your entire intercooler setup from Don. I made mine by myself in my garage.
Old 04-20-2004, 09:19 PM   #23
kaos200
Member#: 2692
whatever you say Kevin
Old 04-20-2004, 09:26 PM   #24
Homemade WRX
Member#: 33782
96 bastard child
oh well....back to the subject....if it makes you feel any better I thought of running it that way without anyone's input...I'm others have done it
Old 04-20-2004, 09:48 PM   #25
SubaFastR
Member#: 5786
Air conditioning is out if you do it this way. I found a way to get it back and will work on it once it is hotter.
WTB an axle back 3 inch exhaust or 3 inch mid pipe knighter MAIC Private Classifieds 0 10-21-2008 12:21 AM
anyone make a 3 inch intermediate pipe methinkadoo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 07-16-2005 08:55 PM
Looking for 2 90 deg 2 inch IC pipes blue-sun Mid West Subaru Owners Club Forum -- MWSOC 4 04-13-2005 06:42 PM
Divorced (divided) wasgate vs reg 3 inch down pipe?? NORCAL STI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 11-09-2004 02:04 PM
Who makes 3 inch mid pipe w/o resonator for sti?? NORCAL STI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 12-15-2003 01:37 PM
