Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 07-06-2000, 05:08 PM   #1
Tim Prudence
Member#: 216
Arrow Those of you using Supra TT fuel pumps, please answer quick question!
Do you have used or new? Is the pump audible from the cabin? How much did it cost?
I found a used pump for $100, but I'm wary of getting it because used fuel pumps can be very LOUD sometimes (though may not exist with this particular pump). Please let me know what your experiences were.
Tim Prudence is offline
Old 07-06-2000, 05:20 PM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
8Complex is offline
Old 07-06-2000, 05:34 PM   #3
Tim Prudence
Member#: 216
Angry
Yeah, I saw that, that's why I'm going with the the Supra pump. It doesn't really answer my question of whether the used pump will be loud and annoying...
Old 07-06-2000, 06:48 PM   #4
Sean McElderry
Member#: 526
1995 Supra Turbo
Red
Post
I got mine from Rallispec...don't really know if it's new or used. I can't hear it from the cabin at all.
Sean
Sean McElderry is offline
Old 07-06-2000, 06:49 PM   #5
Tim Prudence
Member#: 216
Post
could I ask how much you paid?
Old 07-06-2000, 09:48 PM   #6
Andre Vandenberg
Member#: 501
1998 2.? RS Turbo ;)
RBP
Post
Goy my RX 7 pump from "corn on the Cobb" Tuning sorry Trey
After I figured out how to install the COBB RRFPR, the car ran just fine.....
I also have NO worse fuel pick up than what I had with the stock pump.....
Andre
Andre Vandenberg is offline
Old 07-06-2000, 11:19 PM   #7
Sean McElderry
Member#: 526
1995 Supra Turbo
Red
Post
Sure, I paid $250 for the kit with instructions from Rallispec. It came with all the necessary parts to make the pump bolt right in.
Sean
Old 07-07-2000, 12:10 AM   #8
RalliSpec
Member#: 39
98 Prodrive WRC
Post
Our pumps are brand new. Come complete with all parts to retrofit to the Subaru and instructions to do it.
RalliSpec is offline
Old 07-07-2000, 10:33 AM   #9
Tim Prudence
Member#: 216
Post
What's needed for it to bolt in? Am I going to have trouble if I don't get these parts from Rallispec?
Old 07-07-2000, 10:51 AM   #10
Sean McElderry
Member#: 526
1995 Supra Turbo
Red
Post
There are instructions on what to do...perhaps Rallispec could send these to you...dunno.
You need to cut 1/2" off the bottom of the pipe that runs from the top of the fuel pump holder to the actual pump itself.
You need to trim part of the plastic holder for the fuel filter bag.
You need a large ring clamp to hold the new pump in place and a couple of small clamps to hold the rubber fitting on the pipe.
Oh, and a small clip to replace the stock fuel filter clip that you might destroy while removing the stock fuel filter.
If you have any questions, feel free to contact me via email. Good luck!
Sean
Old 07-07-2000, 12:20 PM   #11
ARG
Member#: 386
1999 Impreza RS-S
Rally Blue & Supercharged
Have a Nice Day?
If any part of the fuel pump touches the fuel pump bracket, you will most likely hear it. I bought a used RX7 TT pump for $100 and I can't hear it at all. I made sure that the pump used the original soft rubber base. If you notice how the original Subaru pump was installed, the pump body itself did not touch anything. It was completely insulated by the rubber base pad and upper rubber O-ring. When I installed the Mazda pump, I had to cut about 1/2 inch off of the existing down tube. That was because the Mazda pump was much larger and taller the the Sube pump. I installed the Mazda pump with a two inch section of high pressure fuel injection line and secured it with special fuel injection clamps. DO NOT USE THE SCREW TYPE CLAMPS. The pump has sort of a "loose" fit because of the rubber base and 2 inch section of fuel line, but it is very secure, and doesn't make a sound. I am VERY happy with the RX7 pump.
ARG
ARG is offline
Supra TT fuel pump for sale! PAWRX Private 'For Sale' Classifieds 1 12-04-2003 05:31 AM
Supra TT fuel pump part # PHATsuby Normally Aspirated with bolt-on Forced Induction Powertrain 2 04-30-2003 12:28 PM
A Fuel Pump Equivelant to a Supra TT Fuel pump? RobPA Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-04-2002 04:27 PM
Supra TT Fuel Pump preza Normally Aspirated with bolt-on Forced Induction Powertrain 7 01-30-2002 01:17 PM
Where can I buy a Supra TT fuel pump? Sean McElderry Technical Forum Archive 5 06-28-2000 08:30 PM
