Old 04-13-2004, 08:23 PM   #1
kaos200
Member#: 2692
Default Official RS-T Water Injection thread
Im thinking about it, hot summer and cat piss Cali 91 doesnt go over well at 15psi
There's the aquamist kits, but wheres the best place to get those?
I also stumbled onto a link for these....
http://www.snowperformance.net/products.asp?id=1
kaos200 is offline   Reply With Quote
Old 04-13-2004, 09:34 PM   #2
seven881
Member#: 8828
01 BRP 2.2T Hybrid
08 Tundra
I've been pondering these as well. My only concern is finding a tuner who knows how to tune with them installed. It basically allows you to run tuned as if you had higher octane fuel. The draw back is running tuned to the edge with the WI and you run out of H2O or whatever your mix is and boom!
seven881 is offline   Reply With Quote
Old 04-13-2004, 09:45 PM   #3
kaos200
Member#: 2692
well for my case I can tune it myself, and turn the knock sensor on sensitive so that incase for some reason it didnt spray and the knocking started the car wouldnt boost/rev
Old 04-13-2004, 11:07 PM   #4
Andursun0013
Member#: 11616
1998 2.35RS-T
2006 Baja 2007 Leg. Wagon
I really wanna try to just make my on DIY setup, but that still wouldn't solve the tuning issues. If you just had an indicator light as to when the fluid level in the jug was low or empty you could just not beat on your car then and it should be fine. This is assuming it was only spraying when under boost and such.
Kyle
Andursun0013 is offline   Reply With Quote
Old 04-14-2004, 12:11 PM   #5
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
It has always been my impression that WI should be used as preventative medicine and doesn't provide HP per se. Since it does allow for more threshold for boost and advance people use it to add HP. But I just don't think it's a good way to get HP.
Can't you get any toluene Kaos? or some race fuel.. Even us small Canadian towns carry race fuel just a bit more expensive then regular... like double...
HOK is offline   Reply With Quote
Old 04-14-2004, 04:16 PM   #6
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
I agree with HOK.
Using water injection as a mechanism to make MORE power is not safe in my book. If your going to use it to have a safer setup, then fine. But, what happens if the water level in the tank went dry. Say goodbye to your motor.....
My roomate was running the Aquamist 2D kit on his Stage III A4...tuff to get working correctly I think. Plus, it isn't that cheap.
Graham
Graham is offline   Reply With Quote
Old 04-14-2004, 04:25 PM   #7
kaos200
Member#: 2692
any details on his 2D kit? what it has over the others, and if you know where he got it from?
Im using it just to be safe during the summer while Im on boost, or during track days on boost (Id have it switch on at 12psi) so that everything runs smooth and cool.
Old 04-14-2004, 10:06 PM   #8
no-coast-punk
Member#: 49087
1998 RST V8 STi swap
'05 R6 '95 BMW V8 hotness
Water injection is REALLY good, but ONLY if you have the ability to play with your timing (and to some degree fuel maps to take full advantage of the system). Injected water both cools the intake charge (by a huge amount) but it also acts as a buffer for any spontaneous flame fronts (prevents detonation). You can run much more agressive timing curves and higher boost levels (assuming you don't run your turbo out of it's efficiency range) which WILL yield more power. A good example is a local guy in Colorado named Pat Mcrath. He runs close to 450 wheel horsepower out of his supercharged Ford Tarus SHO on a COMPLETELY STOCK MOTOR, some of you may know these taurus motors, but they are really not the strongest things out there. The only detonation safeguard he has is his aquamist kit.... some of you may ask about his longevity.... he did his first dyno pulls over 4 years ago and the car is still running just fine. One way to quell the fears over running out of water is to simply kipe a float type fuel sending unit off a junkyard vehicle and place it in your water tank and rig the thing to an autometer fuel gauge and place in water tank. Aquamist makes 2 types of systems, the cheaper one which simply delivers a set amount of water at all times, and the second system that uses a MAP sensor and several controls. This system allows you to set how many lbs of boost the water begins spraying at, and allows you to set a ramp angle so as more boost is delivered so is more water. This system works extremely well with electronic boost controllers, when not running the WI system simply run conservative amounts of boost, when the WI is armed run as much boost as your motor will take with the WI to keep detonation at bay at higher boost levels. Things get really fun when you get a standalone system that allows for 2 separate fuel and timing maps, with this type of standalone simply get the cheaper water injection kit and dyno tune the car with a normal map and one map with very agressive timing. The benefits of water injection are even greater when you start mixing things like methanol in your water tank. Not only will the increased deltaH of the methanol suck more heat out of your intake charge, but will also raise the effective octane of your fuel. One benefit of WI and separate timing maps over race fuel and separate timing maps is that it allows for SAFER more agressive tuning. If you run race gas and an agressive timing map you have to make sure that absolutely every last drop of the 91 octane pee fuel is purged from your fuel system before firing the car up with the race gas and race maps. Yes, in the end a dedicated race fuel map will always allow for higher power levels, but on a daily driven car where it is nowhere close to practical to purge the fuel system before and after every track day it will allow some suprisignly high boost levels and timing maps. BTW I keep mentioning aquamist because they have the most consistent metering of just how much water is flowing out of any system on the market, they also have the highest line pressure (better water atomization, and at high boost levels the boost itself isn't cramming the water back into the water line with no actual water getting delivered).
no-coast-punk is offline   Reply With Quote
Old 04-14-2004, 10:28 PM   #9
kaos200
Member#: 2692
sweet... now
[repeat]
where to get the aquamist kits?
[/repeat]
Old 04-14-2004, 10:47 PM   #10
seven881
Member#: 8828
01 BRP 2.2T Hybrid
08 Tundra
Old 04-14-2004, 11:00 PM   #11
no-coast-punk
Member#: 49087
http://www.aquamist.co.uk/
there is their official website where you can go to their distributor page and find the dealer nearest you
charged performance is the biggest subaru specialist among their dealers, but all their dealers can order any aquamist part you need.
Old 04-20-2004, 08:30 PM   #12
kaos200
Member#: 2692
Im thinking about getting the 2D kit,
granted my TEC has an output to control it so I could use the other kit, but Id rather keep it for something else.
Old 04-21-2004, 09:46 AM   #13
Boostup!
Member#: 552
SOHC RS-Turbo EJ257
Tec-2 Aquamist 2D
I bought my 2D kit a year ago from PPE Engineering. Good price and good service. They handle group buys too.
Boostup! is offline   Reply With Quote
Old 04-26-2004, 08:53 PM   #14
kaos200
Member#: 2692
those kits are almost $800!
Old 05-01-2004, 09:48 PM   #15
steak
Member#: 38981
lol crazy i do a search for water injection and kian comes up :P
kian, you should see my setup...its all DIY and it works absolutely perfect. didnt cost NEAR 800 bones either.
im injecting propane, water, alcohol and also pioneering h202 injection with a guy named twitch from h2oinjection, pm me if you have any questions as to why any of this works or what it does.
in 91 i trust. pre-ignition and knock are a thing of the past
*edited for my fat fingering of the keyboard*
steak is offline   Reply With Quote
The Ultimate DIY Water/Alc Injection Thread hippy Water/Methanol Injection, Nitrous & Intercooler Cooling 33 03-08-2008 04:11 AM
alky injection/water injection... i dont understand vipernj Water/Methanol Injection, Nitrous & Intercooler Cooling 3 09-05-2005 01:50 AM
Power difference between water injection and alky injection? scooterforever Water/Methanol Injection, Nitrous & Intercooler Cooling 10 06-21-2005 06:58 PM
ANOTHER Water Injection thread... WRXGuyInUSA Engine Management & Tuning 11 06-07-2004 02:32 PM
BIG water tank for water injection DarthChicken Water/Methanol Injection, Nitrous & Intercooler Cooling 14 07-25-2002 04:58 AM
