Old 04-14-2004, 11:22 AM   #1
Tommi
Member#: 45174
Default What oil is recomended for warmer weather, 10W 30 or 5W 30?
Tommi is offline   Reply With Quote
Old 04-14-2004, 11:25 AM   #2
soso3
Member#: 36794
89 T I T A N
Typically heavier oil (ie 10w) for hotter weather...
soso3 is offline   Reply With Quote
Old 04-14-2004, 11:54 AM   #3
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
MAD REX is offline   Reply With Quote
Old 04-14-2004, 01:50 PM   #4
DrDRum
Member#: 41589
Suff erer Club
Founder (RGSSC)
Higher number for higher temps is how I remember (5w vs. 10w)
DRum
DrDRum is offline   Reply With Quote
Old 04-14-2004, 02:07 PM   #5
rankink
Member#: 12901
2005 STi/95 VX
Pastelito Racing / SFSOC
Ran both down here in South Florida with no noticable differences.
rankink is offline   Reply With Quote
Old 04-14-2004, 08:33 PM   #6
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
10w-30 or 10w-40 is good for warmer weather.
mr2guru is offline   Reply With Quote
Old 04-14-2004, 10:34 PM   #7
mexicanpizza
Member#: 16779
2008 God's Gift to
Turbo Wagons (MS3)
What oil would you run if it were 70-80 and sunny year round?
mexicanpizza is offline   Reply With Quote
Old 04-15-2004, 01:12 AM   #8
mr2guru
Member#: 10334
91 RX7 LSx swap
'09 CC 3.6 4motion
If you drove hard maybe 10w-40.
Old 04-15-2004, 01:58 AM   #9
InfamousDX
Member#: 25413
I'll be switching to 10W-30 once it warms up in the Tri-State area. Anyone have an explanation of the 2nd number in the 10w-30 ?
Old 04-15-2004, 02:41 AM   #10
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
Arrow
drees is online now   Reply With Quote
Old 04-15-2004, 07:47 AM   #11
Tommi
Member#: 45174
Thanks for the info fellas...
Old 04-15-2004, 08:15 AM   #12
Big_Hitter
Member#: 10831
2011 Ferd Ranger 4x4
2009 FXT VF52/E85
I run 10-30 all the time here in Houston.
Big_Hitter is offline   Reply With Quote
Old 04-15-2004, 11:06 AM   #13
s_nold
Member#: 22649
2008 Spec.B
I run Mobil 1 15W-50...all year long.
the W in oil grades stands for winter, many people mistake it for "weight"
s_nold is offline   Reply With Quote
Old 04-15-2004, 12:01 PM   #14
Thumper23
Member#: 11571
10W-30
when I lived in CO, I used 5W-30 in the winter
but I knew of guys who were running 0W-30 in the winter
Thumper23 is offline   Reply With Quote
Old 04-15-2004, 12:21 PM   #15
drees
Member#: 25905
2003 Silver Wagon
The benefit of using an oil with a lower spread between it's cold/hot weights is that it requires fewer viscosity index improvers which will make the oil more shear stable. This means the oil won't thin out very quickly and is more stable.
In reality, you can safely run anything from 0w30 to 10w30 in any conditions since they are all nearly the same viscosity when fully warmed up (hence the 30).
Technically, when looking at the specs of M1, the 0w30 weight oil is actually slightly thicker than the 5w30 and 10w30 at hot temps!
The newer oils in the M1 line to look at are the 0w40 and the new Truck&SUV 5w40 oils. These have the benefit of still having extremely low pour points and being thicker when hot. The Truck&SUV formula reportedly has a stronger additive package in it so it should also hold up better with longer drain intervals.
Old 04-15-2004, 01:18 PM   #16
InfamousDX
Member#: 25413
So is anyone in the hot areas of the US using 10w-40 or 5w-40?? Just wondering. Thanks for clearing this up guys.... since 5w and 10w are about the same, except when cold, I'll just stick to the same 5w-30 year round
Eneos 5w-30 or 5w-40 maruksai Normally Aspirated Powertrain 9 05-03-2010 07:39 AM
what do you recomend for wrx o4 vf22 or 18g tubo help puppet4950 Newbies & FAQs 4 11-24-2007 09:43 AM
5w-30 or 5w-40? Sir-Knight Normally Aspirated Powertrain 3 03-30-2007 01:12 PM
What oil to use for 120 deg weather? sky69lark Service & Maintenance 6 07-28-2005 02:41 PM
What oil is best for 2.5rs's? Friscorice88 Newbies & FAQs 26 09-02-2004 07:38 PM
