Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 07-06-2000, 08:29 AM   #1
kid22
Member#: 396
2000 2.5 RS-T
22WannaB
Post where can i get an oil line for my turbo?
since i'm making my own kit, i need help as far as the oil line is concerned, can someone help me? thanks
-matt
kid22 is offline
Old 07-06-2000, 09:18 AM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
From what I understand you just need to make one and then weld in some sort of nipple to your oil pan to drain. IIRC, rao still has one from his SC install/removal in the pan if you're interested. I think it might be in Donnie's hands at the moment, but if you pop me off an email I can get more info on the oil pan for you tonite.
8Complex is offline
Old 07-06-2000, 10:11 AM   #3
Aspen
Member#: 145
Banned to
Housework for Summer
Post
depends on if you mean oil supply line or oil return line.
You can get most of the turbo accessories from Turbonetics or any other turbo places. Majestic Turbo, Turbo City, etc.
If you want to cheap it out with the oil return line, you can pick up some heavy duty tubing from your local hardware store.
If you want all stainless braided lines, you can get the Aeroquip or Earl's S.S. braided lines from SummitRacing.
Your Welcome.
Aspen is offline
Old 07-06-2000, 10:37 AM   #4
Jay_UK
Member#: 296
Post
As for conenctions..
the drain does go into the sump.... so you will need a pipe connection or a welded boss fitting. This is low pressure.. so rubber hosing will do.. or braided of course
For oil supply most people tap into the top of the block where the oil pressure sensor is. There are other places/plugs but they are hard to get to.
Simply fit a T into the outlet and run soem braided line from there to the turbo. This is high pressure and you should use some decent hosing...
The turbo will either need a bango bolt and fitting.. or an adaptor to convert to jic to go onto the braided hosing
J.
J.
Jay_UK is offline
Where can I get an electric Sti for my toddler? nacho6706 Off-Topic 24 08-31-2009 11:35 AM
IT: where can i get an alternate firmware for my Linksys? BigWrecKs Off-Topic 1 07-30-2007 03:09 PM
Where can I get an oil drum? ScoobyNubieToo! Off-Topic 17 01-23-2006 08:20 AM
where can I get an EGT bung for the love of christ!? Sputnik 5 Southern California Impreza Club Forum -- SCIC 7 05-19-2005 10:59 AM
