Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 07-02-2000, 10:05 PM   #1
sc00by25rs
Member#: 1406
2013 HKS boosted BRZ
Exclamation is there a way to bypass the maf sensor on a 99 2.5 rs
i blew my maf sensor again but this time with my new intake pipe. is there a way i can bypass or maybe hardwire the maf into thinking that it works so i dont have to buy another sensor?
sc00by25rs is offline
Old 07-02-2000, 10:38 PM   #2
rrsettgast
Member#: 104
2009 WRX Wagon
Post
Not the brightest idea in the world...to say the least. You NEED your MAF to be working.
Randy
rrsettgast is offline
Old 07-03-2000, 05:02 AM   #3
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Post
Two questions.
What Intake are you using?
What part number are you using for the MAF?
Forget trying to bypass your MAF. That will cost at least $2000.
Revision is offline
Old 07-03-2000, 05:43 AM   #4
Tony
Member#: 287
2005 9-2X Aero
Desert Silver
Post
You can out it into limp-home mode by unplugging the sensor. This will give you a conservative fuel map and rpms limited to 3400. Not great but you will be able to drive your car to the dealership to buy your new MAF.
No convert to MAP you'd need either a TEC-II or an ECU and MAP sensor off of a MY00. And probably a few more bits but I dunno.
Tony
Tony is offline
Old 07-03-2000, 08:05 AM   #5
sc00by25rs
Member#: 1406
Post
im already in limp home mode.... i have the minnam intake pipe and a cone filter. i am in orlando now i was wonderingif it would be ok to drive about 300 miles back to ft. myers like this.
Old 07-03-2000, 08:50 AM   #6
Tony
Member#: 287
2005 9-2X Aero
Desert Silver
Post
I don't see why you couldn't. Since the rev limit is now at about 3500 just be careful not to hit it too much since you'll be dumping unburnt fuel into your cats.
In "limp-home mode" it doesn't like a cold car. So I'd warm the engine up before heading out, otherwise it'll stall a few times. Don't use the A/C in traffic, only at crusing speed. It can't hold idle with it on.
Good luck, sorry to hear about your MAF.
Tony
Tony is offline
Old 07-03-2000, 09:16 AM   #7
SubieFL
Member#: 1622
2000 Impreza 2.5 RS
Question
Sc00by25RS,
Did you go to the Subie meet this weekend at Race Rock? Someone blew their MAF sensor for the third time over the weekend and I was wondering if it was you.
SubieFL is offline
Old 07-03-2000, 09:27 AM   #8
MPREZYA
SCIC
Member#: 85
Lightbulb
I almost have to ask this question since the subject is there and someone mentioned in a way but doesn't the 99 and 00 model's share the same ecu pin connectors? If so all you may need to do is "wire chase" with the shop manual and see if the pins have changed anywhere and if so swap them and then replace the MAF with a MAP from a 2000. I think that is the only big engine sensor difference between the 2 years. Heck I remember Kevin Thomas using a 98 RS DOHC ecu on his 1997 SOHC 2.2L and the only problem IIRC was the difference between the cam sensors of the 98 DOHC and the 97 SOHC (of course he is now back to the stock 97 ecu). I would think that may be a viable option if you continuously blow mafs but it might not me a cheap one. Just throwing the idea out there for the 99rs members.
Rich
MPREZYA is offline
Old 07-03-2000, 09:37 AM   #9
sc00by25rs
Member#: 1406
Post
it wasnt me that blew it at the meet it was mike with the turbo 2.5rs.
Old 07-04-2000, 05:36 PM   #10
SKiDaZZLe
Member#: 19
Post
scooby25rs,
where you at the meet? when did your MAS break? I drove 200 miles home on the hiway with a disconnected mas..
here are some tips... run around 75MPH, and not faster...because you will most likely hit the 3500 limit and sputter like crazy!
it is the most unnerving sound/feeling. good luck.
michael
SKiDaZZLe is offline
Old 07-04-2000, 09:06 PM   #11
sc00by25rs
Member#: 1406
Post
skidazzle:
yeah i was there, this is andy. i bought ur minnam pipe from you. then i put it on that night and blew it.
i got home ok, kinda slow. but im still in limp around town mode.
Old 07-06-2000, 10:32 AM   #12
Aspen
Member#: 145
Banned to
Housework for Summer
Post
You could convert your maf system to a map speed density system with the HKS VPC(Vein Pressure Converter) for under $1000 but good luck in wiring it up and also tuning it.
Aspen is offline
What's the proper way to clean the MAF sensor? Fierysun Service & Maintenance 6 05-16-2009 07:16 PM
Is there a way to put the gauges from an STI in a 03 RS? jonnysubby Electrical & Lighting 16 09-29-2005 01:19 PM
Is there a way to test the O2 Sensor? F15DOC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 07-08-2005 01:07 PM
is there a way to trick the ECU into thinking your o2 sensors are hooked up?? ammoniaman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 04-14-2004 12:16 AM
