Old 04-14-2004, 06:21 PM   #1
wildbill99
Member#: 58493
2000 impreza 2.5 rs
silverthorn
Default STi dohc heads on a 2000 rs
first off is it possible to put the new dohc heads off the STi on my 2000rs. second what are the +&- and is the money spent worth any and all gains recieved. let me know
wildbill99 is offline   Reply With Quote
Old 04-14-2004, 07:07 PM   #2
jeffg
Member#: 2958
2001 WRX (GC8)
would need a lot of ECU changes.. and probably the STI intake manifold, which is more changes.
In short a SOHC can be made into a DOHC, but the STI is a bad candidate.
J
jeffg is offline   Reply With Quote
Old 04-14-2004, 07:42 PM   #3
MeshmeZ
Member#: 58908
'07 STI
what would be a better candidate?
MeshmeZ is offline   Reply With Quote
Old 04-14-2004, 09:23 PM   #4
nySulli
Member#: 32617
2008 STi
any head swap is going to be a huge pain in the ass, i'd suggest just building up your stock heads
nySulli is offline   Reply With Quote
Old 04-14-2004, 10:56 PM   #5
obyone
Member#: 16523
this anymore???
J
THe STI heads are meant for Turbo so they are low compression chambers.
obyone is offline   Reply With Quote
Old 04-14-2004, 11:43 PM   #6
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
wildbill99 - if you want gains on your SOHC set-up, you might as well do proper headwork, cams etc to get more power.
GTBGUY is offline   Reply With Quote
Old 04-15-2004, 07:41 PM   #7
Compressed
Member#: 12271
2012 4Runner TE
KDSS!
Bad idea if you are going NA. If you want to turbo your car, they would be sweet but I would reccomend a ej257 or ej22t block for the STI heads then.
Compressed is offline   Reply With Quote
Old 04-16-2004, 05:02 AM   #8
obyone
Member#: 16523
this anymore???
Yup...the heads are not the only weak point if you're going to turbo your RS. The block can't take too much boost without cracking a wall or something. So you'd end up having to swap out the heads and block...Esentially, almost an entire engine swap, but with twice the hassle.
Will 04 STi wheels fit on my 2000 RS subygirl2.5 NWIC Private Classifieds 13 03-02-2006 10:17 PM
2.5L DOHC heads on EJ22T block 4wheelflyer Subaru Conversions 35 11-27-2003 02:37 PM
DOHC heads on 99+ EJ25? trojan9x Normally Aspirated Powertrain 8 05-12-2003 08:08 PM
DOHC heads on a 2.2L I am pretty positive they fit but... MPREZYA Normally Aspirated Powertrain 2 11-28-2000 07:30 PM
98 DOHC heads on 99/00 bottom End The_extreme Technical Forum Archive 21 06-21-2000 09:30 PM
