Welcome to the North American Subaru Impreza Owners Club Saturday October 22, 2016
Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 05-15-2000, 06:33 PM   #1
Member#: 344
2004 Impreza WRX
Java Black Pearl
Unhappy Loss of A/C at idle with Unorthodox Pulley?
Since the weather has been getting warmer, I've started using the air conditioner, and noticed recently that when the car (1999 Outback Sport) is idling, the aircon shuts off and the fan only blows uncooled air. The cold air flow resumes once the car is moving. Is this normal? It just occurred to me that it could be the result of the A/C not getting enough juice at idle because of the pulley.
Anyone else have this problem?
Impresario is offline
Old 05-15-2000, 06:52 PM   #2
Mr. Gasket
Member#: 1427
I have the pulley and have not had a problem at all, yours may be a faulty AC, maybe out of gas or something...
Mr. Gasket is offline
Old 05-15-2000, 07:08 PM   #3
Member#: 642
It can't be gas if it was it would never be cold it would just blow hot air I would definitley have it checked out I wouldn't think that an underdrive pulley would cause that but you never know.
CNC84 is offline
Old 05-15-2000, 10:04 PM   #4
Member#: 297
Yes its the pulley causing the A/C not to work very well. The Air conditioner compressor runs off the pulley or crank shaft. When you put the smaller diameter pulley on, you slowed down the speed of the compressor. My A/C does that too (I have the UR pulley). I wouldn't take it to the dealer unless you want to pay for them to tell you that you need to put the stock pulley on and maybe they will void you for future warranty issues because they will know you have put the pulley on.
Akiata is offline
Old 05-16-2000, 07:18 AM   #5
Member#: 102
Hmm.... I have the UR pulley on my 99 OBS too. So far no problem. It might blow less air. But it is definitely cool air. I thought the cool air is with the CFC free gas?\ instead of the a/c fan.
Gambit is offline
Cooling issues at idle with aftermarket radiator KevinHeist Service & Maintenance 17 10-09-2007 01:15 AM
Boost at idle with Cobb AP V2 - what are you reading? Sausage AccessPort 2 06-27-2007 12:43 PM
Knock signal at idle with Delta Dash maugustine Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 09-05-2002 02:18 PM
V8 gargle at idle with new intake... RaceCarRiot Normally Aspirated Powertrain 10 12-28-2001 01:37 PM
Loss of power with Unorthodox pulley fellfrosch7 Car Audio, Video & Security 11 12-24-2000 10:09 PM
