Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 05-15-2000, 01:10 PM   #1
Max
Member#: 788
1989 GMC 1500
Post SAFC Question
Does anyone know how to tune the SAFC using the 02 sensor value? Like, whats a safe reading? How low is too low for gas mileage type driving? Which way is lean or rich? The Apex'i manual pretty much sucks nooksack.
Max is offline
Old 05-16-2000, 04:42 AM   #2
SteveS
Member#: 6
2007 BMW Z4 M Coupe
Interlagos Blue
Post
The manual does suck, but in its defense, the S-AFC is not intended to be used for monitoring the A/F ratio (off the O<sub>2</sub> sensor). I'm assuming you've done the "Blue Wire" mod as far as hooking into the O<sub>2</sub> sensor.
When idling or cruising, the readings should bounce around between 0.0 and 1.0v. In reality you probably won't see above 0.9v when it's in this state, closed loop. Under WOT conditions, you should see the readings stabilize above 0.83v. If you are running NA, anything above 0.80v is probably safe. If you see this number drop below 0.80v under WOT conditions, your car is running lean.
Hope this helps.
SteveS
http://www.lagging.com
SteveS is offline
Old 05-16-2000, 05:36 AM   #3
HRE | giulio
Member#: 481
Exclamation
i thought it was .85 - .87 ?
Oh yeah, for MY00, you have to use a diff # entirely, but i dont know what it is.
g
HRE | giulio is offline
Old 05-16-2000, 06:13 AM   #4
SteveS
Member#: 6
2007 BMW Z4 M Coupe
Interlagos Blue
Post
giulio ~~ I was stating what I feel to be absolute minimum readings. I really think that if the car is NA, then 0.80v is the MINIMUM reading I would want to see. Targeting 0.85v+ is what should be done. Thanks for clearing that up.
And yeah, MY00 first O<sub>2</sub> sensor is a wide band sensor. The 0.0-1.0v range is not applicable.
SteveS is offline
Old 05-16-2000, 10:42 AM   #5
HRE | giulio
Member#: 481
Post
so is it safe to run at .83v at all rpms?
How do you do the "Blue Wire Mod"? SAFC Question. Fred Zaplitny Normally Aspirated Powertrain 40 09-09-2005 11:00 AM
APEX SAFC question DemiGod Engine Management & Tuning 1 11-18-2003 10:44 AM
SAFC questions jkyes Legacy Forum 3 07-18-2002 02:47 PM
SAFC Question bman1069 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-02-2002 02:45 PM
SAFC Question Impreza25RS Normally Aspirated Powertrain 3 11-05-2001 06:33 PM
