Welcome to the North American Subaru Impreza Owners Club Monday August 3, 2015
Old 04-15-2004, 05:54 AM   #1
HubbieScooby
Member#: 7088
Super Slow
Have a Nice Day? boost leak causing lag?
hey fellas
after installing my borla headers i've been experiencing noticable turbo lag (ludespeed stage 2)...i went under the car and tighten every nut and bolt from the heads to the uppipe...and everything seems to be tighten...there were no noticable carbon deposites anywhere...i'm not sure if it's boost leak or my BOV...sometimes the BOV doesn't even go off even if i give it WOT on first gear...i have a HKS SSQ by the way...in second gear it would go off a little chirp then a lot of flutter...i'm running a 4.5lbs spring by the way....should i check the wastegate area too?? this is killing me ....
thanks
hugh
HubbieScooby is offline   Reply With Quote
Old 04-15-2004, 09:18 AM   #2
Tats
Member#: 5692
WTF? YES! I am
better than you!
You will experience more lag with the borlas than the stock y pipe but I'm not so sure that is your problem......check all your vacuum hoses. Maybe one came loose.
Tats.
Tats is offline   Reply With Quote
Old 04-15-2004, 03:23 PM   #3
HubbieScooby
Member#: 7088
Super Slow
the only vacuum line i can think that is loose is the one i have just hanging from my cruise control module...but i've kind of capped it off where there is no leak....i'm thiking that my BOV could play some role in loosing boost....or my stage 2 intercooler running on stage one boost...4.5lbs..but only seeing about 3lbs...
Turbo lag? boost leak? Penguin_02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 01-25-2010 04:02 PM
Can a boost leak cause a knock? Deserted1 Engine Management & Tuning 2 04-18-2009 01:02 PM
boost leak cause high egts? WRXout Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 09-16-2004 11:03 AM
Would this cause a boost leak Hypnotic Perf Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 03-18-2002 09:04 PM
can a boost leak cause high egts? WRxednEffect Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-06-2002 11:22 AM
