Old 04-15-2004, 05:58 AM   #1
HubbieScooby
Member#: 7088
Super Slow
Question BOV problem?
hey guys
we've recently had a very bad rain storm here and i've notice that the BOV started not going off after that storm...i figure that since the BOV is located by the hood scoop that water may have damaged or corroded some internal parts...i was wondering if it was safe to spray a little WD40 into the BOV?? i can't take it off because it's welded onto the IC...
thanks
hugh
HubbieScooby is offline   Reply With Quote
Old 04-15-2004, 09:16 AM   #2
Tats
Member#: 5692
WTF? YES! I am
better than you!
should be okay.
Generally they say to dis-assemble them and lube them with ATF.
Tats.
Tats is offline   Reply With Quote
more BOV problems TaiChih Normally Aspirated with bolt-on Forced Induction Powertrain 15 03-21-2002 01:17 PM
Help: BOV problems virus67 Factory 2.0L Turbo Powertrain 1 08-21-2001 02:28 AM
Help!: BOV problems virus67 Factory 2.0L Turbo Powertrain 2 08-20-2001 05:45 PM
TurboXS BOV Problems!! HELP!!!! Raymond Factory 2.0L Turbo Powertrain 10 08-12-2001 09:01 AM
turboXS BOV problem WRX Power Factory 2.0L Turbo Powertrain 1 07-09-2001 07:50 AM
Message Board Statistics All times are GMT -4. The time now is 09:52 PM.
