Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 05-14-2000, 04:26 PM   #1
tulit
Member#: 338
09 STi
Post Jacking Car
Does anyone have any tips on the best way to go about jacking up the rear of the car?
(ie where to put the jack, jack stands, etc.)
Would a 2ton jack be safe?
Ditto for jacking up the front...
Thanks.
tulit is offline
Old 05-14-2000, 04:32 PM   #2
Imprezer
Dynamic Uno
Member#: 1
2011 Impreza WRX STi
Post
Rear Diff.
Imprezer is offline
Old 05-14-2000, 04:34 PM   #3
tulit
Member#: 338
09 STi
Post
Should I put a 2x4 or something between the jack and the diff?
And wheres the best place for the the jack stands?
Thanks.
tulit is offline
Old 05-14-2000, 05:03 PM   #4
rao
Member#: 52
2005 Legacy GT
98 BMW 540i LS2/T56
Post
YoOu definately want to use a 2x4 under the diff. There are places for jack stands just forward of the rear wheels and just behind the front wheels, just look under the sills and you will see the cut-outs.
rao is offline
Old 05-14-2000, 06:18 PM   #5
HRE | giulio
Member#: 481
Post
i'm not an expert but i dont think the rear diff was designed to hold the weight of the rear of the car.
rao's advice is best- use the spots designated for stands.
HRE | giulio is offline
Old 05-14-2000, 10:23 PM   #6
ImprezaRS dot com
over boosted again
Member#: 1458
2017 WRX Limited
2015 Forester XT, Tribeca
Post
I bought two jackstands capable of 6 tons for $29.95 (as a pair) at Checker autoparts, to install my Stromung exhaust when it arrives this week (Thurs?).
I plan to use the jack stand slots on the frame, not the diff. I will first install the muffler and try it out for a bit. The midpipe is having the flanges welded on this week and then it's being shipped. Then I'll install the midpipe afterwards and see how much it helps in addition to the stromung.
Larry Ganz
www.ImprezaRS.com
ImprezaRS dot com is offline
Old 05-14-2000, 10:30 PM   #7
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
I lifted my car up by the diff protector that I had put on to get my sway bar on and it worked great. I would have used jackstands but a friend of mine had them and no way I was waiting to get my sway bar on. BTW, the protector didn't budge at all.
8Complex is offline
Old 05-14-2000, 11:02 PM   #8
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Post
The diff is bolted to the rear crossmember by two very big bolts. No problems lifting the car from the diff (use a slab of wood to protect the diff). I finished installing Primitive's rear diff plate a little while ago, and now I just use that to lift the car at the rear. Very strong piece that Primitive rear diff plate.
Revision is offline
Old 05-15-2000, 07:06 AM   #9
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Arrow
If I need to get the wheels off the ground I use the diff protector. If I don't have to work on the wheels I use Rino Ramps, they work really well and aren't all that expensive.
Peaty is offline
Old 05-15-2000, 09:00 PM   #10
tulit
Member#: 338
09 STi
Post
I went out and bought a jack kit (2.25 ton jack and 2.25 ton jack (axle) stands . Notice these are metric tons. Equiv to about 4 imperial tons)
The instructions that came with the axle stands said to leave the jack on the car while working on the car. Is this right? I thought the jack should only be used to low and raise the car, and not actually support it.
Thanks.
tulit is offline
Old 05-15-2000, 09:04 PM   #11
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
Well, jack + stand + stand = 3 points to hold the car up from falling on you. You can leave it on the stands without worry (as long as they're secure), but that jack is always a nice failsafe.
8Complex is offline
Old 05-15-2000, 09:27 PM   #12
CNC84
Member#: 642
Post
With 2600 lbs. give or take I would definitely rather be safe than sorry anyone ever seen that home movie of the car falling and cutting the guy in half? Don't want that to happen to me. Rather be safe than sorry.
Chris
CNC84 is offline
Old 05-15-2000, 09:55 PM   #13
tulit
Member#: 338
09 STi
Post
So I should use all 3 then? How do i tension up the axle stands? should i lower the jack just a few millimeter below the axle, so if it does for whatever reason fall, it falls onto the jack instead of my face?
hehe. Thanks.
tulit is offline
Old 05-15-2000, 10:39 PM   #14
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
Raise jack, put jackstands in place, lower car so it's supported by the jackstand, leave jack raised. That way, if the car falls off the jackstands, it should land on the jack instead of your face.
RidinLow is offline
Old 05-16-2000, 09:12 AM   #15
Julian
Member#: 1182
MY00 RS
BRP
Post
If the car falls after you placed it on jack stands, then you didn't place it on jack stands properly. Once you drop the car on the stands, you should be able to shake the car, bump it, get in it, get out of it, all without the car moving at all. I would trust jack stands over a hydraulic jack which could fail. Better safe than sorry, sure, but often you need SOME room underneath the end you jacked up...and three big pieces of metal get in your way.
Julian
Julian is offline
Rapist shoots judge, stenographer, officers, jacks cars, manhunt begins... december03 Off-Topic 23 03-12-2005 09:47 PM
Where to jack up my car with a floor jack? Sordid Philosopher General Community 1 11-17-2002 04:52 PM
Jacking car up by rear diff - OK??? mykrrrr Newbies & FAQs 18 12-01-2000 11:35 AM
