Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 05-15-2000, 11:13 PM   #1
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
Question Heres a ??? What Rpm do the RS valves start to Float
I am planning on headwork anyways...Stage 2 or 3 port and polish with O-rings. Maybe bigger valves and I am wondering what the Stock Valve springs can handle...or is time to look for those as well...
Scooby South is offline
Old 05-16-2000, 12:06 AM   #2
Tarmac RS
Member#: 1020
Post
I think before you concern yourself with valve float on this particular engine, you need to worry about piston speeds.
What else are you doing to this engine? Unless you are adding cams, you dont have the power in the upper rev's to be worth revving it that high, besides that you can keep your foot buried as deep in the throttle as you want, but the rev limiter is going to keep the RPM's in a safe range anyway..
Tarmac RS is offline
Old 05-16-2000, 12:13 AM   #3
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
Post
Well if you must know I am planning a complete build of the bottom end...Pistons, Rods, some other tricks..So to answer your ??? I am looking to fortify the engine before I go to the world of Forced induction...However; I am also contemplating a COMPLETE VER5 swap...Weighing my options ya know...The complete Swap would include motor, tranny, Diffs, ECU..new Grp N clutch, and ECU upgrade...but thats another story..
Old 05-16-2000, 12:25 AM   #4
Tarmac RS
Member#: 1020
Post
Well there ya go
I dont think too many people can attest to what RPM they'll float since we only see 6200R's. BUT, as long as you are going that far with it, valve springs will be cheap insurance
Old 05-16-2000, 07:32 AM   #5
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
valve float depends entirely on cam specs, valvetrain weight and spring rates. none of which we'll know on your built-up engine, so we can't help.
ColinL is offline
Under normal driving, what RPMs do you rev to (slip the clutch) from a stop? ImportVenom Transmission (AT/MT) & Driveline 20 02-05-2015 01:54 AM
05 rs, @what RPM is the highest torque bnr34rb26dett Newbies & FAQs 2 10-26-2008 01:08 AM
those with nitrous what RPM do you activate it? AndyM Normally Aspirated Powertrain 18 03-31-2002 01:54 AM
At what RPM do you guys shift up or normal driving? myfirstnewcar General Community 46 03-27-2002 12:17 AM
What RPM do you hit fuel cut? Fubaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-24-2002 02:33 PM
