Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 05-15-2000, 06:04 PM   #1
Xscreamer
Member#: 711
1993 Rx7 R1
Yellow
Exclamation Super AFC vs Fuel Pressure Riser (must read)
Ok the Apexi AFC is looks great and is the best way to fix a MY99's "lean" problem in the high rpms with a modified intake and exhust. The only problem is, is installing it and buying the parts to install it which al together equals a lot of money. My question is will a fuel pressure riser fix this problem since it's more cost efficent.
~Brandon
99' Black RS
Xscreamer is offline
Old 05-15-2000, 09:23 PM   #2
MPREZYA
SCIC
Member#: 85
Post
The S-AFC is an easy install as well as it allows fine tuning not blanket tuning of the fuel like the pressure riser. The SAFC or Hyper-R SFC will allow you to tune things for later mods like forced induction making it an overall better value over chip's like JC's and the FPR's. Those lack the fine adjustability of the Hyper-R and SAFC leading you to either have the chip reprogrammed or to add more fueling compensation with a different regulator. I am sure alot of others will agree on this.
Bottom line= go with the SAFC or Field SFC.
Rich
MPREZYA is offline
Old 05-16-2000, 05:50 AM   #3
HRE | giulio
Member#: 481
Post
you dont need much to install an SAFC. I did it myself. just get a 10 mm wrench (to get off the ECU kick plate), some snap-on wire taps, 2 wire crimp connectors, and a splicing tool. Install in like 5 mins! Just make sure you tap the right wires
HRE | giulio is offline
I need a defi/greddy fuel pressure sensor (Vendors read). BADWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-31-2003 06:35 PM
Looking for Directions for Fuel Pressure Riser. yebokmj Normally Aspirated Powertrain 1 03-05-2001 09:47 AM
Fuel Pressure Riser Kit Delicious Tuning Technical Forum Archive 0 08-25-2000 05:25 PM
Weapon R Fuel Pressure Riser and Icon Delicious Tuning Bay Area Impreza Club Forum -- BAIC 0 08-21-2000 03:55 PM
How to contact bell eng... fuel pressure riser kit needed DJIMPREZA Technical Forum Archive 1 05-15-2000 03:04 PM
