Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 09-12-2000, 01:41 PM   #1
cakagan
Member#: 251
1998 Impreza 2.5 RS
Question Warning signs of wheel bearing failure?
For the past couple of days I've been hearing a squeaking noise coming from my front wheels. After awhile the noise goes away, but I'm concerned. I checked my brakes and no stones are stuck in the calipers, etc. Could this be a sign that my wheel bearings need to be replaced? Anyone know the part number(s) and how difficult it is to replace them myself (ie, special tools, etc)? I'd rather do it myself if no special tools are needed.
Thanks,
-Kagan
cakagan is offline
Old 09-12-2000, 05:01 PM   #2
andyC
Member#: 1607
2002 Silver
double you are ecks wagon
Post
The sound that my wheel bearing made before they went out was more of a humming sound, that was the rear though...
andyC is offline
Old 09-12-2000, 05:12 PM   #3
direwlf
Member#: 1479
1999 Impreza 2.5RS
Silverthorn Metallic
Post
After you've been driving for awhile, get out and see if the centres of the wheels are really hot (right over the hubs). This is usually the first sign something is wrong. The bearings will be very hot and will start to howl right before they go.
direwlf is offline
Old 09-12-2000, 05:13 PM   #4
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
Squeaking... nah, that's probably not a wheel bearing. Usually it's a hum, then a drone, the roaring, then it seizes and you do an Explorer impersonation.
ColinL is offline
Old 09-13-2000, 07:11 AM   #5
Bob OM,Md
Member#: 1349
Exclamation
ColinL's description is right on the money. I remember vividly the progression of deterioration of my wheel bearing and the subsequent replacement of the wheel bearing and the hub asembly the second time. It is definitely NOT a squeak.
Bob OM,Md is offline
Old 09-13-2000, 09:10 AM   #6
cakagan
Member#: 251
1998 Impreza 2.5 RS
Post
So could this be a problem with my brakes? I installed Raybestos (I know, I know) on all four corners, and they squeal every time I apply the brakes. Could they be dragging?
-Kagan
cakagan is offline
Old 09-13-2000, 09:59 AM   #7
joostin420
Member#: 1046
2016 WRX Limited
crystal white pearl
Lightbulb
mine made a loud squealing noise for a day, drivers side front wheel. i brought it in to the dealer and sure enough new wheel bearing, no grease was left in it they said. had the car about 2-3 months.
justin
joostin420 is offline
Old 09-13-2000, 10:47 AM   #8
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
some brake pads squeal as a normal part of their operation. the original equipment pads only squealed when they were near the end of their life.
your new raybestos may be the former.
ColinL is offline
Old 09-13-2000, 10:51 AM   #9
andyC
Member#: 1607
2002 Silver
Post
is it tough to replace wheel bearings yourself? I took mine to the mechanic and it was about $350 for both of the back wheels.r
andyC is offline
Old 09-13-2000, 10:52 AM   #10
cakagan
Member#: 251
1998 Impreza 2.5 RS
Post
I will never again put those kinds of pads on my car. I was short on cash at the time they needed changing and will be replacing them very soon with Mintex or similar...
-Kagan
[This message has been edited by cakagan (edited September 13, 2000).]
cakagan is offline
Old 09-13-2000, 10:53 AM   #11
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
Post
They're easy... you can take the hub off yourself, then i just brought my hub, and the bearings i got at a low price to a machine shop, and they did it for $30 a side.
JGard is offline
Signs of impending Turbo failure? HamrTym Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-27-2006 03:25 PM
Signs of wheel bearing going bad? DDMan Brakes, Steering & Suspension 7 03-22-2003 01:29 PM
Signs of wheel bearing failure??? GTOWNR Legacy Forum 4 02-27-2002 12:51 PM
Rear Wheel Bearing Failure Piquet North West Impreza Club Forum -- NWIC 5 02-23-2001 02:04 PM
Update: Wheel Bearing Failure #2 Bob OM,Md Technical Forum Archive 11 08-15-2000 05:42 AM
