Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 05-15-2000, 03:39 PM   #1
Don Grubbs
Member#: 1373
Cool Rear Swaybar
How much difference is there between the 18mm and 20mm sway bars? Also, I've seen some large price differences between brands. Is there anything to this?
Don Grubbs is offline
Old 05-15-2000, 04:41 PM   #2
uktena
Member#: 1267
Post
Don,
That depends; I had a 1998MY Impreza OBS and an 18mm bar, when I bought the 2000MY 2.5RS I moved it over. It didn't work as well on the RS (probably the limited slip). I have since added STi V6 springs and AGX shocks. Now the bar is totally inadequate. I'm moving to a Cusco 21mm. I all depends on the suspension setup.
uktena is offline
Old 05-15-2000, 05:07 PM   #3
Tim Prudence
Member#: 216
Post
Larger diameter bar = more oversteer (less understeer)
The brands are unimportant, the size can only be compared within the same brand. Because a 21mm bar from one manufacturer could be less stiff than a 20mm from another one.
Tim Prudence is offline
Old 05-15-2000, 05:14 PM   #4
STi Sev
Member#: 2876
99 Impreza
Rally Blue Pearl
Post
I'd recommend the CUSCO 20mm.
small noticable difference than the 18mm
MASSIVE noticable different from 13mmm
STi Sev is offline
Old 05-15-2000, 05:20 PM   #5
Don Grubbs
Member#: 1373
Post
I was asking about difference in brands because I saw that JC Sports has one for $109. Seems pretty cheap.
Old 05-15-2000, 05:30 PM   #6
rrsettgast
Member#: 104
2009 WRX Wagon
Post
I would advise that you do not order from JC Sports, unless you are local to them. Do a search, and you will find many long flaming posts about them.
Stick with what works:
Teague's Auto
SPD Tuning
ISR
Just about everyone else besides JC
Randy
rrsettgast is offline
Old 05-15-2000, 05:37 PM   #7
Nat
Member#: 759
2004 WRX
2000 SV650
Post
I got a 21mm Cusco and just got it in last Sat, and boy is it sweet! Even with stock tires and street tire pressures I feel the car is just about neutral when pushed. I am sure it would feel great at an autocross with more pressure, I want to try it out! If you go with any of the Cusco bars I'd say go with Teagues. I have ordered a bunch from them lately and you can't beat the service...quick, friendly and always willing to help. Last thing, if you get a bar from somewhere else, make sure it comes with bushings! I got screwed over and didnt get any, so I had to go to the shop at work and drill out the stock rubber ones. It ended up being ok, but not optimal...at least it all fits nicely .
Nat is offline
Old 05-15-2000, 06:03 PM   #8
jkyes
Member#: 707
99 Legacy GT
Quick silver
Lightbulb
just get the adjustable one, then as you upgrade your car you can change the settings, and if you like more more oversteer you can set in like that. i got mine from www.mofugas.com good service and price... oh yeah and try doing a search on your topic, you will alway be amazed how much info there is already archived. it is humorous how many people ask the same ?'s over and over again...
jkyes is offline
RCE Rear SwayBar/Technica Brake Lines/Kartboy Endlinks Devil2holla Suspension/Brakes/Handling 7 06-08-2010 08:14 PM
FS: 06 sti 20mm rear swaybar with sti front and rear swaybar bushi nelli-son Suspension/Brakes/Handling 1 09-21-2008 11:37 AM
27mm front/rear swaybar vs. 27mm front/ 25mm rear swaybar kitganzon Brakes, Steering & Suspension 27 07-13-2008 12:03 PM
Cusco Adj. Rear Swaybar Setting with a 22mm Cusco front swaybar? forsaken Brakes, Steering & Suspension 1 11-29-2004 06:11 PM
17mm Front Swaybar + 22mm Rear Swaybar links_courses Brakes, Steering & Suspension 30 05-18-2004 08:12 PM
