Old 04-16-2004, 02:03 AM   #1
wm07
Member#: 26529
04 STi
Default BFGoodrich g-Force T/A KDW-2?
I am thinking to get BFGoodrich g-Force T/A KDW-2 245/40-18 for my street/autox tires. At Tirerack, KDW-2 has higher dry and wet traction ratings than Kuhmo MX and KDW-2 also has higher treadwear. If MX is consider to be competitive, would KDW-2 be a better choice based on the Tirerack's rating? Here is a link:
I am running 18" wheels, so Azenis is out of the picture. So, has anyone have any experience with KDW-2s? and would it be competitive in autox(STU)? Thanks!
wm07 is offline   Reply With Quote
Old 04-16-2004, 02:52 AM   #2
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
They should be alright but tread blocks will probably squirm like crazy and I have seen them chunk from getting too hot.
afpdl is offline   Reply With Quote
Old 04-16-2004, 03:26 AM   #3
wm07
Member#: 26529
04 STi
or may be MX still the better choice?
Old 04-16-2004, 08:35 AM   #4
Orion
Got the F out
Member#: 4797
01 01 RS, 00 RS
2008 WRB FSXT 5mt
much better choice.
i used to run the original KDW and as a pure performance tire it was superior in every way to the Ver 2. the 2 has a tread designed more with car shows in mind, but they still designed it to handle fairly well in dry and wet.
the orig. KDW was considerably slower in the dry to Azenis, KD, and others, but it made up for that by not dropping off in the wet near as much as they did.
Orion is offline   Reply With Quote
Needed!: BfGoodrich G-Force T/A KDW 2, 225/45/17 Need 2 tires only! moosecakes Private 'Wanted' Classifieds 7 03-24-2010 11:37 PM
Bridgstone SO-3 or BFGoodrich g-Force T/A KDW 2? Randog77 Tire & Wheel 16 08-15-2005 05:00 PM
BFGoodrich g-Force T/A KDW 2 + Wagon?? roninwarior007 Tire & Wheel 2 05-10-2004 11:28 AM
BFGoodrich g-Force T/A KDW-2 Tires MisterX Tire & Wheel 4 02-13-2004 03:29 PM
Anyone using the BFGoodrich g-Force T/A KDW-2? doppelganger Tire & Wheel 1 11-17-2003 12:48 AM
Message Board Statistics All times are GMT -4. The time now is 05:20 PM.
