Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 05-14-2000, 07:43 PM   #1
Sean McElderry
Member#: 526
1995 Supra Turbo
Red
Question Exhaust + Turbo + Boost + Performance???
Hello everyone. I've decided to take the plunge and get the Minnam Stage II turbo kit. My dilemma is here: I am unclear on what an exhaust will do to the performance. In more detail:
If I get a 3" pipe from the cat back to the muffler, and I get a straight-thru muffler, the car should have enough room to breathe, right? Now, in the latest SCC, when they switched to a performance muffler, the boost went up 2psi. Why?
That's my first question. Secondly, if I were to keep the stock exhaust, can I simply tune the wastegate setting to provide the same amount of power (as with a performance exhaust)?
If this is so, I don't see the advantage of going with a larger pipe and performance muffler. Is there one?
Thanks, guys.
Sean
Sean McElderry is offline
Old 05-14-2000, 07:45 PM   #2
MattC
Member#: 158
2011 STi
PBP 1999 2.5RS RBP
Exclamation
I am running the Rallispec exhaust in 3", and have no problems with it. The car pulls much harder up top, and I don't think I lost much if anything down low. I am running a Minnam Stage [email protected] presently.
MattC
MattC is offline
Old 05-14-2000, 07:57 PM   #3
Strepto
Member#: 252
2001 Arctic White
Camaro SS #1800
Post
If you keep the stock exhaust the amount of back pressure will be enough to hinder your performance. Turbos need a larger pipe to flow air more easily. If you have back pressure on a turbo it can't spool easily, therefore hindering performance. With a turbo you're pushing more air and it needs a place to go. If the pipe is too small the air gets "stuck" causing back pressure because it can't move at a quick enough rate through the pipe.
This is my understanding of why you need a larger diameter exhaust on a turbo system. It's probably not the best explaination explaination, and I'm sure others will help out.
Strepto is offline
Old 05-14-2000, 08:07 PM   #4
cOz
Member#: 576
1995 Volvo 850 Turbo
Dark Green
Post
With a free flowing exhaust like rallispecs it will be easier to keep your egt's down and help prevent detonation and parts of your engine being overheated, melting becomes a problem if they are to high.
cOz
cOz is offline
Old 05-14-2000, 08:52 PM   #5
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
With the less backpressure you are allowing the turbo to spool easier creating less turbo lag and the turbo will heat up less. The best my old turbo Volvo ran was when the cat. rotted and fell off leaving a 6" section of pipe out of the turbo pointing straight to the ground (note: loud).
8Complex is offline
Old 05-15-2000, 07:06 AM   #6
Sean McElderry
Member#: 526
1995 Supra Turbo
Red
Question
Thanks for the responses, guys. I've heard the exhaust that Minnam uses on their turbo systems. For some reason, it sounds like it's backfiring all the time (under hard runs). Is there a reason for this? It's much louder than your typical gurgle/pop.
Thanks!
Sean
Old 05-15-2000, 03:04 PM   #7
Sean McElderry
Member#: 526
1995 Supra Turbo
Red
Question
Anyone?
Old 05-15-2000, 03:55 PM   #8
MattC
Member#: 158
2011 STi
PBP 1999 2.5RS RBP
Post
My car burbles and exibits small backfires when off the throtle. Sometimes when I am shifting through gears you will hear a quick POP! Never while I am on the gas tho. I personally love the sound. It scares the hell out of the person you are about to race. VROOM! VROOM! POP! POP! POP!
MattC is offline
INTELLIGENT POWER BOOSTS PERFORMANCE and EFFICIENCY of NEXT GENERATION PORSCHE 911 TU AVANTI R5 Non-Subaru News & Rumors 11 08-08-2009 02:56 AM
Car tuner school aims to boost performance Tea cups Non-Subaru News & Rumors 4 06-04-2009 09:01 PM
Turbo back exhaust from wrx-performance.com suby44 Newbies & FAQs 0 09-09-2002 08:11 AM
Free trixs to boost performance georgiamiata Legacy Forum 7 04-13-2002 06:42 PM
