Old 04-16-2004, 10:00 AM   #1
Bobalouy
Member#: 827
99 2.5rs,BDP,
02 WRX wagon WRB
Default WRX Oil pan on a 99rs
Can any one confirm if a wrx oil pan will fit on a 99rs? Or what I would have to do to make it fit.
Thanks
Anthony C
Bobalouy is offline   Reply With Quote
Old 04-16-2004, 10:06 AM   #2
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
it will
Old 04-16-2004, 10:23 AM   #3
Bobalouy
Member#: 827
99 2.5rs,BDP,
02 WRX wagon WRB
With out any modification? I saw a post about changing the water pump? and something about the dip stick?
thanks
Anthony C
Old 04-16-2004, 11:01 AM   #4
Darshu
Member#: 1676
98RS w/ EJ257/Dom
2014 Tesla Model S P85
No changes required. Old one off, scrape some gasket, new one on.
Darshu is offline   Reply With Quote
Old 04-16-2004, 11:02 AM   #5
Safir
Member#: 3873
. Paradise is
like Disney with hookers
I put a WRX oil pan on my 2001 - bolted right up. I'd imagine it would be the same for a 99.
the hardest part was getting the screws out/in on the back portion with that stupid crossmember in the way.
edit: i rea about changin teh dipstick as well, so i bought a WRX dipstick and didnt need it. the dipstick attaches to the head so on your DOHC you MIGHT.
Safir is offline   Reply With Quote
Old 04-16-2004, 12:58 PM   #6
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default Standard
The DOHC 2.5's came standard with the WRX oil pan. I've had my WRX oil pan on four differant EJ series engines with no problems and no needing to change dip sticks.
Joshua
yebokmj is offline   Reply With Quote
Old 04-16-2004, 01:05 PM   #7
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
We fit one on my MY00 without an issue.
We put one on Revision's MY99 and had to slightly bend the oil dipstick tube to fit in. No idea why, should have been exactly the same as the MY00.
Old 04-16-2004, 01:12 PM   #8
Bobalouy
Member#: 827
99 2.5rs,BDP,
02 WRX wagon WRB
Great thanks guys!!
Anthony C
Old 04-17-2004, 02:10 PM   #9
Unsung Boxer
Member#: 37196
Just to clarify to you, I hope your not trying to use the WRX oil pan as a means of oil drain back...
Turbo oil drain-back on a WRX normally goes to the head, its us AFI guys who tap the oil pan for direct drain back.
Im not sure if that is why you asked the question, but it was my question at one point, and I just wanted to clarify that if you were confused.
-Jake
Unsung Boxer is offline   Reply With Quote
Old 04-17-2004, 02:49 PM   #10
Bobalouy
Member#: 827
99 2.5rs,BDP,
02 WRX wagon WRB
Yeah Im taping the wrx oil pan, So I dont have to worry about taking mine off taping it and putting it back on, in the middle of the turbo install.
Anthony C
Old 04-17-2004, 05:05 PM   #11
Unsung Boxer
Member#: 37196
thats what i did. There are many methods for doing this. One you may want to consider is Brazing:
1. Buy a Brass Barbed fitting (5/8" if you want to match the turbo outlet)
2. Drill a hole for the fitting (you choose placement, make sure you think it thru, or you'll be sorry)
3. DO NOT USE A NUT on the inside. alot of people used Buldge style fittings, I think it runs risk of leaking and falling into oil pan. This is where brazing comes into play.
4. Remove paint from around the hole.
5. Use propane torch and brazing rod to braze (soldior/weld) the fitting to the pan.
6. Sand it down, fill with water to check for leaks.
7. Paint (use bondo to fill in pinholes if necessary)
mine looks like it is a stock piece now that its painted. It has worked great.
-Jaek
Old 04-18-2004, 01:09 AM   #12
squirrelmasta
Member#: 33445
2005 Chevy Silverado
Cherry Red
Dealer said that an 02 WRX pain wouldn't fit on my 99RS. said the bolt ups were different. im just buying another 99 pan, $65, and tap that. Peace.
-Eli
squirrelmasta is offline   Reply With Quote
Old 04-18-2004, 02:24 AM   #13
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
The oil pan bolt pattern is exactly the same among all of the EJ-series motors. Don't let anyone tell you any different.
Old 04-18-2004, 01:18 PM   #14
Unsung Boxer
Member#: 37196
a lesson ive learned in life is that the dealer is generally stupid in all aspects.
they tell you things like this because either they dont know, or they dont want to be responsible for selling/recommending the wrong part.
The refused to help me in any way w/ my RS front end conversion, telling me that the bumper and hood wouldnt fit.
-Jake
Old 04-18-2004, 02:28 PM   #15
squirrelmasta
Member#: 33445
Cherry Red
so does the WRX pan have a line to the turbo and a return line?
-Eli
Old 04-18-2004, 02:34 PM   #16
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
oil feed is pressurized oil not the oil in the pan
theres no fittings/bungs on the wrx pan
Old 04-18-2004, 03:18 PM   #17
squirrelmasta
Member#: 33445
Cherry Red
so, is there an advantage to the WRX pan over a RS pan?
Old 04-18-2004, 06:45 PM   #18
Safir
Member#: 3873
. Paradise is
the WRX pan has an additional baffle that the RS pan does not - less sloshing in the pan and less likely to suffer oil starvation at the track.
Old 04-18-2004, 08:32 PM   #19
25rstautoxr
Member#: 43958
99 RS Asphalt-01RS
Dirt-01 Forester swapped
I have a 99rs with a wrx pan no problems. I had ludespeed pan and had two pin size holes thats why I replaced it. the wrx pan I had reinforced just to make it stronger. That fixed one of my oil leaks
leak free know
chris
25rstautoxr is offline   Reply With Quote
Old 04-18-2004, 09:10 PM   #20
squirrelmasta
Member#: 33445
Cherry Red
do you still need to tap the WRX pan like you would have a RS pan then? If some one could please add pictures to this i think that would help me ALOT! i'm very confused as far as all the oil lines go. Thank you.
-Eli
Old 04-18-2004, 10:37 PM   #21
Bobalouy
Member#: 827
99 2.5rs,BDP,
02 WRX wagon WRB
Old 04-18-2004, 11:29 PM   #22
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
^^^ That is Andrew (Revision)'s WRX pan that went onto his MY99. Mine was tapped exactly the same as that.
Old 04-19-2004, 07:08 AM   #23
Safir
Member#: 3873
. Paradise is
Mine is done identically to that as well, except I had it tig welded instead of brazed.
my web host is down ATM, when it is back up i will post a pic.
The wrx gets teh oil feed and drain for the turbo from the block - so yes you still have to tap a WRX oil pan, but it is more convenient to tap a new pan ahead of time than to pull your old pan, get it good and clean (oil + the heat of welding/brazing = not good), tap it, and then reinstall it.
Old 04-19-2004, 10:54 AM   #24
squirrelmasta
Member#: 33445
Cherry Red
Where have people gotten their oil lines from? or are you guy's using acutal metal lines?
-Eli
Old 04-19-2004, 12:59 PM   #25
Safir
Member#: 3873
. Paradise is
I went to my local parker store and got some -1AN steel braided line and an earl's 45 degree -10AN fitting for the pan side, and there was a nipple on my turbo for the drain so i just used a hose clamp and some silicon sealant for good measure.
anyone change a wrx oil pan to sti oil pan? 1WRX2NV Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 12-30-2007 09:32 PM
I can put a WRX oil pan on a STi motor, right? TROLL Built Motor Discussion 9 12-12-2006 03:55 AM
WRX oil pan on a turbo legacy? serious Subaru Conversions 7 11-14-2005 09:35 PM
WRX Oil Pan on RS?? Crimson Normally Aspirated with bolt-on Forced Induction Powertrain 8 07-20-2003 07:40 PM
More WRX oil pan on a RS pics /w turbo oil return Revision Normally Aspirated with bolt-on Forced Induction Powertrain 0 09-08-2002 04:40 PM
