Welcome to the North American Subaru Impreza Owners Club Monday April 27, 2015
Old 04-16-2004, 11:47 AM   #1
asbWRX04
Member#: 58665
2004 Impreza WRX
Platinum Silver
Default Lowering my Suspension where to go to get springs installed & what springs to buy
Hi,
I am a new owner of a Subaru WRX 04' sedan. I am looking to upgrade the tires possibly the rims as well. I think it looks cool and sportier lowering the suspension with new springs as well.
I am thinking about ordering either Eichbach's or Prodrive.
1.) What springs do you guys reccomend? (I still have stock rims and tires at the moment - will be upgrading soon)
2.) Where would I go to get these new springs installed (what kind of shop - will a regular tire shop be able to do it?) Also, what can I expect to pay?
3.) Would new performance tires on stock rims and a lowered suspension be the way to go on a budget?
Thanks for your quick input!
AmRiK
asbWRX04 is offline   Reply With Quote
Old 04-16-2004, 11:52 AM   #2
thrdeye
Member#: 24569
2011 Impreza WRX
1)Prodrive is awesome.....don't know if they are out for 04s yet, but if not wait for it.
edit: I should add that eibach makes the prodrive springs, but the eibach pro-kit and the prodrive springs are a bit different (i.e. prodrives are linear, eiback is progressive IIRC). Spring rates are different too, and the prodrives are designed with the stock struts in mind.
2)Try to get someone local (with tools, space and whatnot) to help you out and do it yourself. It is pretty easy, and you'll get to learn about your car. An impact gun comes in handy for spring installs.
3)absolutely. The stock wheels are only 16.5 lbs and tires will do a lot for the car.
thrdeye is offline   Reply With Quote
Old 04-16-2004, 12:02 PM   #3
poison
Member#: 37678
I have Prodrives and love them.
Most mechanics will install springs. I called a couple random places by my house and they quoted me from $200-300. Midas, Discount Tire, and others will do it. You can also just go on your local forum and see if someone will do it for you. that worked for me, I had a great install for cheap.
Someone correct me if I'm wrong, but the linear nature of the prodrives handle better than the progressive Eibachs, and from what I've seen, they even out the wheel gaps better that Eibachs. I don't know if the '04 Prodrives are out yet; if they aren't and you use 02-03 springs, you will need 02-03 top hats to make them fit your 04 struts.
I have not upgraded tires yet, and that is the only bad thing about the springs: they really made the RE-92's the weak point of the whole suspension/handling equation. I can't wait to upgrade. I will be keeping the stock 16's, though. They are light, strong and look decent and almost disposable, they are easy to find cheap if you ding one.
poison is online now   Reply With Quote
Old 04-16-2004, 12:13 PM   #4
YinUCSD
Member#: 44945
06 LGT wag
Prodrive all the way! IMO they are better than the eibach prokit because of the linear rate, close to sti spring rate afaik, the even fender gap look (more even than eibach), and the fact that they are designed to work with the factory struts, its not optimal, but no other springs are designed as well for subarus specifically, other than subaru parts of course.
yes new sticky tires are the BEST upgrade you could do for any car as far as handling is concerned. and yeah the stock rims are uber light. new tires and prodrive springs were the first two things i did to my car and it made such a big difference. then i upgraded the rear swaybar. that would be a good route for you. although a proper alignment would do wonders for handling, just be sure to get that done after the springs.
YinUCSD is offline   Reply With Quote
Old 04-16-2004, 12:19 PM   #5
thrdeye
Member#: 24569
2011 Impreza WRX
yep...-1.5 camber in the front for the prodrives.
I also recommend a rear swaybar. Combined with the prodrives, best suspension you can buy for under $500
Old 04-16-2004, 12:34 PM   #6
Mr.Hanky
Member#: 22053
2002 Black WRX Wagon
Stage 3, Element Tuned
Lotís of guys rave about there Prodrives so I feel a need to represent the minority, Eibachs.
Eibachs are progressive, which means they are a little cushier on the street.
They are one of the only manufacturers to offer wagon specific springs.
They are about $100 cheaper than Prodrives.
I have them on my wagon and love them.
Yes your wheel gap will still be off, personally that does not bother me, it is still better than stock. So far I have no rub with my Kuhmo 712ís in 225ís with a 17X7 48 offset rim, but that could change with a different tire brand.
It all depends on you and what you want to do with the car. Some say that progressive springs are inconsistent under load so they go with linear springs.
Steve..
Mr.Hanky is offline   Reply With Quote
Old 04-16-2004, 01:13 PM   #7
YinUCSD
Member#: 44945
06 LGT wag
a side note about alignment. i just got mine done yesterday and asked for -1.5 deg camber front and 0 deg rear, zero toe all around. they could only dial in -1.2 deg camber all around, they said i needed camber bolts if i wanted to get any closer to -1.5 in front and 0 in rear. this is for a wagon so i dont know if the same is true for sedan.
also if you have a wagon, a rear strut bar makes a big difference given the lack of rear tray in the wagon.
Old 04-16-2004, 01:43 PM   #8
Mr.Hanky
Member#: 22053
WORD!
I agree, although many do not, this has been a long ongoing argument.
Old 04-16-2004, 06:00 PM   #9
e28fixer
Member#: 25037
Prodrive springs/Koni strut inserts/Whiteline rear swaybar/Whiteline rear strut bar... That's what I'm running on my '02 wagon along with 225/45-17 tires. Looks awesome, handles awesome. The wife's Miata with the Mazda sport suspension will still destroy it in the twisties though. Oh well... I drive both. Life is good.
Scott
e28fixer is offline   Reply With Quote
Old 04-21-2004, 09:12 PM   #10
meridock
Member#: 37868
2010 Corvette Z06
Originally posted by asbWRX04
Hi,
AmRiK
pm 'RH DUDE.' he is a moderator and lives in Nova. we worked a deal to do 2 sets of spring installs last week with him... IMpact gun for hire...
Also... If you want stock STi springs I can hook you up!
meridock is offline   Reply With Quote
Where to go for car audio install/purchase? Brewmaster New England Impreza Club Forum -- NESIC 16 02-12-2006 08:09 PM
where to go for a clutch install in CT? jpsimon New England Impreza Club Forum -- NESIC 5 12-19-2005 08:11 AM
Where to go next w/ audio install flyingmachine Car Audio, Video & Security 6 12-01-2004 04:57 PM
Help! where to go and get new seat covers? Freeman Southern California Impreza Club Forum -- SCIC 5 07-13-2004 02:23 AM
Where to go for tuning and installs? 1quikrex New England Impreza Club Forum -- NESIC 0 04-17-2002 09:40 PM
