Old 04-16-2004, 09:21 PM   #1
Nicklbrso
Member#: 44887
00 GC6
Default Borla header install
My dad went to install my borla headers on my EJ18. He got all the necessary bolts loosened except for the bolt nearest the cat. It just wont budge. I told him to spray the bolt down with sometying like WD-40 but he doesnt think it will help. What do you guys suggest? Thanx
Nicklbrso is offline   Reply With Quote
Old 04-16-2004, 10:12 PM   #2
Osgood30
Member#: 20437
1999 Impreza RS
STI Ver7
why won't you help your dad put headers on YOUR car
Anyway, I had to hit the wrench with a hammer for half of my bolts, even the ones that its seems like its imposible to get to, just keep on hammering, after a while its going to go. WD-40 is useless in this case. Bolts are almost welded to nuts.
Osgood30 is offline   Reply With Quote
Old 04-16-2004, 10:14 PM   #3
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Grinder, torch, nutbuster, breaker bar, cut off wheel, bigger dad.
Tim Sanderson is offline   Reply With Quote
Old 04-16-2004, 10:25 PM   #4
Nicklbrso
Member#: 44887
00 GC6
My dad even put a longer pipe over the wrench he was using and he said the socket almost broke Osgood what do u mean hitting the wrench with the hammer? Anyone else have any good ideas? I want to get my borlas on!
Old 04-16-2004, 10:34 PM   #5
SjYankee006
Member#: 33943
just use a breaker bar/hammer if need be. worse comes to worse, the head breaks off. then you can go from there.
SjYankee006 is offline   Reply With Quote
Old 04-16-2004, 10:57 PM   #6
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
I use a special wrench with a socket for my pipe extension breaker bar, it can break anything. Make sure to use a steel pipe, and a non-wratched socket wrench (get a craftsman one at sears, costs like $10 and you never have to pay to replace it)
Old 04-16-2004, 11:14 PM   #7
kleinkid
Member#: 27091
2010 STi SE
Go to the next flange aft, break it loose there and get the whole unit on the ground where you can work on it. you can get more torque on your tools in this position. The bolt may break in two pieces, but at least you will have it off. An industrial fastener supply store or even Lowes will have a replacement bolt you can use. That is what I did after struggling with it in place for awhile. Many others have done this also. Those of you who are going to put a new header on should start off like this from the get go.
kleinkid is offline   Reply With Quote
Old 04-17-2004, 12:43 AM   #8
ommmjido
Member#: 35746
08 White GRB
Wrong Fitment Crew #001
yes, get the headers+cat down first, u'll have alot more room to work on it. the position where the headers meets the cat just sucks a$$.
ommmjido is offline   Reply With Quote
Old 08-11-2004, 10:00 PM   #9
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
Hey I'm replacing my headers on my 1.8L soon.. I know the bolts are rusty But is their alot of room to turn any type of tool?
Just my luck is that the bolt will break off.. So if that happens how do I get the rest of it out?
SubaruImpreza_power is offline   Reply With Quote
Old 08-11-2004, 11:18 PM   #10
OneOBS
Member#: 63076
2004 Outback Sport
Red!
You can buy reverse cut drill bits. In many cases, that will get it out. If not, drill out the bolt and use an E-Z out on the rest of it.
OneOBS is offline   Reply With Quote
Old 08-11-2004, 11:20 PM   #11
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
cool thanks.
Old 08-12-2004, 02:33 AM   #12
rawrFERNY
Member#: 51517
2007 Outlander LS
i strategicly used a wrench and the jack in the trunk of the car... use ur imiganation
rawrFERNY is offline   Reply With Quote
Old 08-12-2004, 02:37 AM   #13
rawrFERNY
Member#: 51517
2007 Outlander LS
heres an example... not the greatest illustration but hey it took me less than a minute
Old 08-12-2004, 02:39 AM   #14
rawrFERNY
Member#: 51517
2007 Outlander LS
oh crap i forgot to say... after i removied one of those bolts i realized i couldnt reach the other one in the same way. i ended up taking off the headers and the cat disconnecting it from the catback put it on the floor and put the wrench on there and stomped on it. it worked and it worked well :-D dont forget to disconnect any sensors near the cat.
Old 08-13-2004, 07:57 PM   #15
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
I looked under the car today.. it's not bad at all, not rusted at all I must of confused the Heat shield botls with the headers.. Do I need a 14mm socket for the bolts?
Borla Header Install ttboy19 Engine Management & Tuning 2 07-18-2003 12:58 PM
trouble with borla headers install jslegacy Legacy Forum 8 08-08-2002 12:28 PM
Borla headers instal, Questions Fish Normally Aspirated Powertrain 13 06-01-2001 12:09 AM
Borla Header Installation Buellboy Normally Aspirated Powertrain 4 02-21-2001 05:41 PM
98 GT Wagon Borla Header Installed Scooby2 Legacy Forum 8 02-01-2001 04:38 PM
