Old 04-16-2004, 09:24 PM   #1
Nicklbrso
Member#: 44887
00 GC6
Default Unorthodox UP install
I want to install my Unorthdox underdrive pulley tomorrow. How big of a job is this? Do I need to take the radiator off in order to take the old pulley and install the new pulley? I read scooby mods install on the pulley but just wanted some additional info. Also on scooby mods he says "put the car in 5th gear and hold the brake while someone loosens it" What is the purpose of this? Any other suggestions? Thanx
Nicklbrso is offline   Reply With Quote
Old 04-16-2004, 09:59 PM   #2
obyone
Member#: 16523
First: Radiator fans need to come off, Remove all belts, get a HUGH ASS BREAKER BAR FOR THE crank pully. That bitch is on there like 140lbs sq/in, bitch and moan that the damn thing doesn't want to come off, rinse repeat.
obyone is online now   Reply With Quote
Old 04-16-2004, 10:02 PM   #3
Nicklbrso
Member#: 44887
00 GC6
So how do you recommend I get that god damn pulley off?
Old 04-16-2004, 10:23 PM   #4
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
it's 92 foot pounds.
get a 3 foot breaker bar and rest it on the frame in front of the battery. put the socket on the bolt. get in the car and turn the key for about 1/10th of a second.
OR,
there is a flywheel inspection cover on the passenger side rear of the engine(manual tranny). Remove it and wedge a pry bar against the housing and one of the flywheel bolts on the front side of the flywheel. Put large breaker bar on the pulley bolt and loosen it.
Make absolutely sure that the new pulley engages the key in the keyway or you will jag it up and be bummin.
Use second method to tighten pulley bolt to 92 foot pounds.
Goodluck and have fun.
Tim Sanderson is offline   Reply With Quote
Old 04-16-2004, 10:58 PM   #5
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
The Radiator fans DO NOT HAVE TO COME OFF with an EJ18!!!!
There is plenty of room to get to the crankshaft bolt.
Use a breaker bar for this job as well as that header job, you need a 22mm socket for it though (without an extension, extensions wont fit)
Old 04-16-2004, 10:59 PM   #6
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
You dont have to do this either.
Old 04-17-2004, 12:13 AM   #7
1 Lucky Texan
Member#: 46320
06 WRX Sportwagon
Uh, I've read that does work, but be CERTAIN to pull the trigger wiring from the coil pack or otherwise disable the ignition!
also
Triple check the torque, some manuals for some subies have it listed wrong (low).
1 Lucky Texan is offline   Reply With Quote
Old 04-17-2004, 01:47 AM   #8
Machine Age Victim
Member#: 29961
2008 Honda Element
1975 Triumph Spitfire
Machine Age Victim is offline   Reply With Quote
Old 04-17-2004, 01:48 AM   #9
ExecNav
Member#: 30554
08 LGT Spec.B
01 Impreza RS-T
ExecNav is offline   Reply With Quote
Old 04-17-2004, 09:48 AM   #10
Nicklbrso
Member#: 44887
00 GC6
I knew some jerk like Machine age victim would come along and say "why is his dad doing his installs?" Well if you really want to know my dad came home yesterday afternoon at 2:45. He insisted on trying to install the borlas for me. I said alright but I have to work at 4. So I could not help him. Now machine age victim knows the story of my life and can now flame others as well. You did not help this thread at all.
Old 04-17-2004, 12:00 PM   #11
Machine Age Victim
Member#: 29961
2008 Honda Element
Originally posted by Nicklbrso
....You did not help this thread at all.
now you know how it feels what goes around...
http://forums.nasioc.com/forums/show...hreadid=531709
Good Day
oil blew up every where after up install xmelanko Newbies & FAQs 6 10-05-2008 03:47 PM
SD- need dp/up install!! sandiegowrx Southern California Impreza Club Forum -- SCIC 2 04-29-2004 10:18 AM
Who will give me phone advice for UP install? jroberts Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-06-2003 09:41 PM
Unorthodox pulley installation woes bombtrack Normally Aspirated Powertrain 4 10-06-2001 06:11 PM
Unorthodox Pulley Install - how do you break that F*&#ing bolt???? Tim Harris Technical Forum Archive 19 06-02-2000 09:55 PM
