Old 04-16-2004, 10:05 PM   #1
MyScoobie28
Member#: 59185
2014 Impreza WRX
Default n/a powa
hey, who has the most power from their normally aspirated 2.5rs? i just wanna know the power and the mods cuz i wanna see if its worth it to swap an ej20t engine instead. thanks
MyScoobie28 is offline   Reply With Quote
Old 04-16-2004, 10:27 PM   #2
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
To enter the realm of turbo'd power via n/a you would be spending more than the cost of a ej20t swap.
Cams, higher compression, injectors, fuel pump, engine management, intake, header, exhaust, head work, underdrive pulleys, on and on.
Tim Sanderson is offline   Reply With Quote
Old 04-16-2004, 10:35 PM   #3
SjYankee006
Member#: 33943
if you have the $$... just do a swap. for the record, without major engine work, i think 190 - 200hp is about the most. maaaybe...
SjYankee006 is offline   Reply With Quote
Old 04-17-2004, 11:59 AM   #4
nySulli
Member#: 32617
2008 STi
you can get over 200 hp with a setup similar to the stage 3 cobb power package, but thats 4 grand plus install and cat/header coated if you want it, which already starts getting you in the range of an ej20 swap, or just throwing a turbo on your ej25, a full swap, or just a turbo kit with an sti shortblock and slightly built rs heads are the ways to make serious power, not staying NA
nySulli is offline   Reply With Quote
Old 04-19-2004, 01:34 PM   #5
dcoty
Member#: 3149
01 V7 GC/R32 sky
I was running a 14.10 in my RS (2.6L, 11:1 comp and 8K redline). But i found out I had the wrong cams in my car (the cobb spicy cams, not the more aggressive racer cams) which make power to 8,500 rpm. So it explains why my power dropped above 7k.
But Im putting the motor back in on the 1st of may and the car is also completely gutted too now, it wasnt before (no AC, cruise, interior etc). So im hoping for a nice new time when she is up and running!
It is $$ to do N/A, but its a lot of fun! If you arent obsessed like myself and you just want good power, do a swap or turbo you RS.
Start with the bolt ons, and if you want a good gain, cams and heads give you a good fun car.
Dan
dcoty is offline   Reply With Quote
Old 04-19-2004, 02:55 PM   #6
powerlabs
Member#: 45790
2006 Corvette C6 Z51
SUPERCHARGED
Are you selling your spicy cams dcoty? I'm interested
powerlabs is offline   Reply With Quote
Old 04-19-2004, 03:32 PM   #7
dcoty
Member#: 3149
01 V7 GC/R32 sky
Powerlabs....Ill keep you in mind, i just may have to let them go, I also have a set of street cams too. I still have to send back a set of cams to Cobb for the core refund.
Dan
Old 04-19-2004, 04:26 PM   #8
powerlabs
Member#: 45790
SUPERCHARGED
On their page it says that you get a refund if you send them in within 30 days Good luck though! Sorry for getting a little bit off-topic, but how long did it take for you to get your cams once you ordered them?
Old 04-20-2004, 01:25 PM   #9
dcoty
Member#: 3149
01 V7 GC/R32 sky
Not more than a week or so to quebec, so it should be pretty quick to you.
Dan
The miata has stopping powa! And Patrick...my car IS louder. Blindeye_03 South East Region Forum 14 03-30-2004 01:14 AM
VF 34 4444444444 powa! rex02 Alaskan Impreza Club Forum -- AKIC 25 06-15-2003 01:29 AM
PE Powa! L2W Alaskan Impreza Club Forum -- AKIC 31 06-09-2003 03:41 AM
RIDGECREST 2003 - awsoma powa darkangelgrafix Southern California Impreza Club Forum -- SCIC 9 03-03-2003 01:29 AM
OT: M Powa hits the rollers RyanC New England Impreza Club Forum -- NESIC 22 10-29-2001 09:14 PM
