Old 04-16-2004, 10:39 PM   #1
Dealer Xing
Member#: 4673
Default Anybody uses 15W-40W motor oil? Is it for trucks only?
Has anybody noticed that the 15W-40W motor oil on the market is usually recommended for trucks or diesel engine(It says on the bottle)? I think it would be a good viscosity for me to use on a turbocharged car(non-subaru). I don't know if it is solely for trucks to use.
Dealer Xing is offline   Reply With Quote
Old 04-16-2004, 10:53 PM   #2
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
bad idea; try 10w40 (std or synthetic) or 5w40 synthetic instead. many many high performance engines in cars and motorcycles use those.
15w cold is going to be not teh good on your valvegear when cold starting if you are somewhere that gets <40 degrees.
ColinL is offline   Reply With Quote
Old 04-16-2004, 10:54 PM   #3
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
btw, why is this an OT thread???
Old 04-16-2004, 11:19 PM   #4
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
15-50W on teh Jetta. Runs great.
Granted, I don't get tons of cold weather although the car does seem to like it more than hot weather.
DrBiggly is offline   Reply With Quote
Old 04-17-2004, 07:58 AM   #5
Dealer Xing
Member#: 4673
What kind of 15W-50 do you use? Mobil 1?
Old 04-17-2004, 08:09 AM   #6
RockVR4
Member#: 50600
1933 Duesenberg
I use Mobil One 15W-50 in my Galant VR4 pushing 24psi.
RockVR4 is offline   Reply With Quote
Old 04-17-2004, 09:52 AM   #7
Scoobyriffic
Member#: 14499
2000 Kona Caldera
1998 Specialized Allez
I know someone with an old BMW 525i that runs 15W-40(50?) Mobil 1. Those are $$$ oil changes.
Scoobyriffic is offline   Reply With Quote
Old 04-17-2004, 09:53 AM   #8
RidinLow
Member#: 329
1995 325i
Arctic Gray
I use 0-40 Mobil 1 in the M3. 7-8 qts of that stuff each time is pricey, but at least I can go 10k mi before changing it.
RidinLow is offline   Reply With Quote
Old 04-17-2004, 10:11 AM   #9
DrBiggly
Member#: 11482
02 WRX
Acute Stickeritis
Mobil 1. I figure with 205k on the clock it's best not to change the oil now for fear the car would just reject it horribly after a transplant of anything else.
Old 04-17-2004, 10:21 AM   #10
mrbigisbudgood
Member#: 54378
2013 Mazdaspeed 3
I ran John Deere 15W-40 synth in my Supra Turbo every summer (yes, for hard working turbo diesels). Probably just rebadged Mobil. The car absolutely loved it. Wife and I put 160k on the car before some redneck backed into it and totaled it out.
mrbigisbudgood is offline   Reply With Quote
Old 04-17-2004, 10:26 AM   #11
Chromer
Member#: 20325
08 Yamaha WR250R
07 Suzuki DL650
I think I recall reading that Gary was running 15W50 or 20W50 in his USTCC car. Of course, that engine is living at a different point on the curve than a street engine...
Chromer is offline   Reply With Quote
Old 04-17-2004, 10:56 AM   #12
HoRo1
Member#: 15618
I run 10-40 Syntec now but will be switching to 15-50 next change. Probably Mobil 1.
Totally the wrong forum!
HoRo1 is offline   Reply With Quote
Old 04-17-2004, 12:39 PM   #13
Projekt
Member#: 15947
91 RX-7
Brave Blue
we can get away with 20w-50 down here uber protection!
Projekt is offline   Reply With Quote
Old 04-17-2004, 12:54 PM   #14
Damn Yankee
Member#: 53066
work bum look a lot
alike, daddy.
I used to run 15W40 in my VW jetta in NH in the summer, then switched to 10W40 for the colder months, ran both great.
Damn Yankee is offline   Reply With Quote
Old 04-17-2004, 02:04 PM   #15
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
what he said. the bike uses 10w40 mobil1.
unloved taurus gets 10w30 castrol gtx
Old 04-17-2004, 02:46 PM   #16
alfaguy
Member#: 14238
2002 WRX Wagon - PSM
Alfas: 89 Milano | 72 GTV
Diesel formulation oils are ultra high detergent. This may or may not be a good thing, depending on your engine.
Other than that, I don't see anything wrong with that viscosity range for warmer months.
Joe
alfaguy is offline   Reply With Quote
Old 04-17-2004, 02:49 PM   #17
Stanley
Member#: 7374
2007 Grandpamobile
BlingBlingBlue
I've been running Rotella T synthetic 5-40 in my motorcycle for a while and I really like it. Motor is a bit quieter, and the shifting is greatly improved over the old dino stuff.
It's marketed as a "fleet oil", and is suitable for diesel or gas engines. It doesn't have the friction modifiers in it that most automotive oils have these days, so it doesn't pose issues with the cycles wet clutch. Plus I can get a gallon of the stuff at Wal Mart for the 2 bucks more than one quart of Mobil One for motorcycles.
Stanley is offline   Reply With Quote
Old 04-17-2004, 04:03 PM   #18
bobturismo
Member#: 42145
6-4 jockin da bish-
es and slappin the hoes.
your oil is too thick for when it is not hot, you need to run what the manufacturer recommends, it's actually slowin you down when it's a nice and cool outside, when the motor should be runnin it's best
bobturismo is offline   Reply With Quote
Old 04-17-2004, 05:18 PM   #19
Projekt
Member#: 15947
91 RX-7
Brave Blue
15 weight is not too thick for north carolina.
Old 04-17-2004, 07:27 PM   #20
WRXedUSA
Member#: 26833
'07 Bugatti Veyron
'03 Chevy Silverado
w3rd.
0W is called for in the winter time on the Great Plains.
Nothing more than 10W in the summAr.
WRXedUSA is offline   Reply With Quote
Old 04-17-2004, 08:47 PM   #21
bobturismo
Member#: 42145
6-4 jockin da bish-
it's not the 15 it's the 50, it's too thick
What grade of motor oil is best for frequent short trips? f4phantomii Off-Topic 12 03-17-2008 11:23 AM
Used 2.5rs motor/tranny.. whats it worth? sith Subaru Conversions 3 05-31-2006 12:23 AM
has anyone used bmw synthetic motor oil racekar Service & Maintenance 12 03-09-2006 05:20 PM
Is it ok to only use two winter tires? Lightning Jack Newbies & FAQs 24 11-11-2004 10:33 AM
15w-50 motor oil tEkkGOD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 02-25-2003 02:14 AM
